[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (version 1.0.5 2013/10/30)
Thanks Received: 3170
2013/10/31 - 18:27
Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M9 PRO (aka Max-M9pro) for both WiFI and 3G models. This custom firmware is based on new official update version 1.0.5 dated 2013/10/30. According to PiPO this release should "fix skype and netflix bugs".
(update_M9pro_1.0.5_20131030.img)
Build information:
Kernel: @Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #353 SMP PREEMPT Mon Oct 28 10:51:40 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20131030.104929:eng/opinions-on-teclast-p90hdst-keys
ro.rksdk.version=RK31_ANDROID4.2.2-SDK-v1.04.00
  • root with latest SuperSU version 1.65 (free version)
  • NEW!  optional ClockworkMod (CWM) Recovery easy install package
Notes:
- Certificate Center and original PiPO launchers have been kept in the firmware
Unfortunately, I don't have an actual Pipo M9 pro to test and build an optimized firmware for this device. I am interested in buying one with the help of the community. Please check this page if you want to contribute to the funding of a PiPO M9 Pro that will help us to offer better firmwares. Our funding is now complete (100%) thank you all for your support.
Download: kasty-pipo-m9_pro-422-105_20131030-rooted4.zip
segundus, Terryfried, cooltraxx, agaam, wheelman, Regas, triplehead, 0n3j0k3, cardvr, rodeomb, fredetoulouse
Xikin
2013/10/31 - 18:33
Downloading now, will flash in about 20 minutes :)
Thanks for the rom !
slackerlx
Forum Posts: 52
Thanks Received: 9
2013/10/31 - 19:26
Thank you.
@admin
Please don't buy Pipo from AliExpress. Expensive and unreliable plus inability to use PayPal. Here is where you can get it cheaper and faster and through PayPal
http://www.banggood.com/PIPO-M9-Pro-3G-Quad-Core-1_6GHz-10_1-Inch-Android-4_2-Tablet-p-80089.html
2013/10/31 - 19:32
slackerlx,
Thanks for the recommendation. I've done some research and I should actually buy locally, I found a shop that is more expensive than importing from China but they ship faster, accept Paypal and offer better support.
g1247216
2013/10/31 - 19:56
Guys' is the sms integrated in this ROM?
Xikin
2013/10/31 - 20:01
Hey
So far tested wifi, 3g, gps and benchmarked on antutu. Wifi and 3g work great.
The tablet can go into deep sleep now (couldn't in sms version). GPS doesn't find any satelites :/ (not using it anyway :P )
Antutu gave it 17 885 points. But the tablet seems to run a little slower than before.
Skype works, i  made a few calls and it didn't crash :)
segundus
2013/10/31 - 21:00
Does anyone have a Checksum for this download, it would be very usefull.
Thanks.
Lottoman
Forum Posts: 43
Thanks Received: 10
2013/11/01 - 08:24
slackerlx said
Thank you.
@admin
Even better: http://www.focalprice.com/CE0576B/PiPo_M9PRO_3G_Version_10.1_Capacitive_Retina_Display_Android_4.2.2_Quad_Core_RK3188_1.8GHz_Tablet_PC_Phablet_with_Built_in_3G_GPS_Bluetooth__Auto_Focus_Camera_32GB__Black_.html
Very relaiable, good reputation, Pay Pal, pay a little more and you get delivery by EMS/DLH/UPS in a few days.
Cheers!
Lottoman
gerfalcon
2013/11/01 - 09:30
Updated
Nice ROM.
But and now i have problem with included 3G - dont work
I changed operator_table, spn.xml, xml with apn...
Maybe its hardware problem?
Lottoman
Forum Posts: 43
Thanks Received: 10
2013/11/01 - 09:44
gerfalcon said
Updated
Nice ROM.
3G works fine for me. You tried to put Modem Power ON, turn tablet OFF, Put in SIM card and restart? That is what I did anyway..
Lottoman
Lottoman
Forum Posts: 43
Thanks Received: 10
2013/11/01 - 10:57
Lottoman said
slackerlx said
Thank you.
@admin
Cheers!
Lottoman
slackerlx
Forum Posts: 52
Thanks Received: 9
2013/11/01 - 10:59
Great ROM no doubts. I didn't see any drop in performance. Still 19340 by AnTuTu as before.
However, I went to factory ROM because Kasty's still missing necessary elements (for me, of course). I don't believe demands are universal.
I really like oosic video player widget (cannot be found in Kasty's) which fits perfectly into family launcher. There's no time widget nor Logbook (with widget) in Kasty's Rom. I'm a teacher and work a lot with tablet, consequently using Documents widget much. As I have said, these are personal choices which I don't expect everyone to have.
Skype now finally works in both Kasty's and factory roms so finally this annoyance has been removed.
Lottoman
Forum Posts: 43
Thanks Received: 10
2013/11/01 - 11:02
Confirms FYIO:
Wifi works fine
3G works fine, NO SMS
OTA- Have no idea
GPS-Still bad, finds 3 sattelites in 30 min.
Skype-Works fine
Netflix-Have no idea
All together the best rom until now I think
2013/11/01 - 11:14
slackerlx,
It's not easy to satisfy everybody Wink The idea of removing unnecessary apps is to keep the Android system as stock and basic as possible. Asian apps are removed because they aren't of any use for non Asian users, and some other apps were also deleted because they can be installed from Google Play Store. This assumptions aren't probably completely right and I am thinking to review that probably by adding optional packages, depending on users needs. For those using stock firmware from the manufacturer, I'd like to know what which app you would like to be kept in our custom firmware and if that's OK to get them as an additional package, probably thru ArcTools.
On an unrelated subject, we are currently experimenting overclock, please check here if you want to know more.
slackerlx
Forum Posts: 52
Thanks Received: 9
2013/11/01 - 11:14
Lottoman said
Lottoman said
slackerlx said
Thank you.
@admin
Cheers!
Lottoman
Uh-uh... You didn't say the magic word. Bandgood has worldwide free delivery service :)
86 Guest(s)
Devices in use: Desktop (76), Phone (10)
culo1
dfrt
PQNY
chema1971
speedyftp
georgicaa97
