[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (v1.07 - 2014/04/14)
william-boo
2014/05/23 - 09:47
mgergolet said
all links are broken? download page shows error.
Security error(5)
error logged, system administrator has been notified
Please reload this download page
Old files may have been removed, please check our web site or forum for latest updates.
where can i find a new liknk?
thanks
mariano
Hi everyone.... me too, i have the same problem.. i cannot download .zip from any server..
any ideas?
(Mariano aqui tambien hay un argentino :p) CoolCoolCool
Thanks Received: 3170
2014/05/23 - 10:03
I just checked and had no download issues for the firmware in post #1.
Please make sure you are logged in and try again.
twingo16s
Forum Posts: 48
2014/05/23 - 14:57
ami also goes if (error code 80040154)
mgergolet
argentina
2014/05/24 - 00:50
I don't know why but this morning links worked fine!
Nos i've new firmware installed.  I did not know that all my apps would disappear. :-(
onesky
2014/06/07 - 22:40
i had to downgrade to this version because any 4.4 kitkat out (official, kasty or riley version) make my Pipo M9pro exremely unstable, that means reboots just after some minute of using
this 4.2.2 1.07 is stable and even more responsive
(p.s. gps works)
blabetalo
2014/06/23 - 10:35
After Upgrading Pipo M9PRO with the new version Android 4.2.2 Jelly Bean rooted firmware for the Pipo M9 PRO
I`m realy happy.Flashed with Rockchip Batch Tool version 1.7.
everything is working very well (GPS too ) but I can`t write files (or transfer) on my external SD
((((•changed permissions on external sdcard to allow write access))))
If I use sdcard on PC everything is OK.
If I transfer files from my PC to sdcard I can use them on Pipo.
How can I use CIFS on this firmware withot apps like Mount manager,CIFSmanager or andsmb?
Cheers
sleepums
2014/07/17 - 23:30
I can't get my main desktop to auto-rotate.. It'll rotate when i go off the main desktop to settings or other apps, but, not while on it.. Any ideas, anyone? (And, yes, auto rotate is selected!)
Edit: I just installed NOVA and fixed it.. Apparently it's a known issue.. Now, I know why Cookers always have NOVA installed! HAHA!
The following users say thank you to sleepums for this useful post:
soenghei
BliND123
2014/08/06 - 23:55
How do I downgrade to this from 4.4.2 KitKat?  I'm having a lot of trouble with the wifi on 4.4.2 KitKat not connecting at all randomly.
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2014/08/07 - 02:55
Did you guys do a CWM dalvik-cache  erase, data format, and if your version have system erase -erase sytem before flashing a new ROM, I learned this the hard way also when I upgraded from JB to Kasty KK because it now has a 7Gb data partition our older JB/KK has only 4Gb data partition and I dont face this problems if I am patient enough to go through this preparation it will take half a day just to format , check and counter check before flash upgrade to the newer ROM especially if you dont read the fine prints (this KK has 7Gb data partition versus the previous 4Gb of the older KK or the JB)
It is not a simple matter of connecting the USB cable and getting the "pink" square and "restore" buttons it needs a proper preparation. I learnt this the hard way also I am not Einstein either.The ROM i can declare it as being 98% stable except for the GPS (but this is due to the aluminium back cover), no random reboots, no wifi drop-outs and 3G dongle works on non 3G models(the ones without the SIM card slot), No screen auto rotate issues.(Except I missed the multi window functions on a previous JB ROM).
I can vouch to that but I am now on another device ONDA V975m Amlogic M802 SoC which I cant get a ROM form KASTY and using ROM from another Forum.I am waiting to buy another screamer from ONDA V979 with 55k+ Antutu score in Q3. But all this cannot be enjoyed without the stable ROM. I can understand how you guys feel when your device dont perform well but I can say that the KASTY ROm latest #407(??) is 98% stable as it can get.Just check your preparation BEFORE flashing the ROM.
(this device is an old stuff to me already since owning ONDA V975m and LENOVO OctaCore device, just following up on comments in the Forums, KASTY has done his best already)
kukacka2
2014/08/14 - 08:24
Unfortunately KitKat change failed, the device does not turn on and can not even see the computer. Pipo not respond to anything. How can I fix it?
soenghei
Asia
2014/08/16 - 16:00
Had this problem since the 20131209 and subsequent versions. Now finally resolved with Nova. Thanks sleepums...
Currently Online: mogabi
83 Guest(s)
Devices in use: Desktop (75), Phone (8), Tablet (1)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
