[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (OTA_1.0.0 - 2013/10/23)
futzmaster
Forum Posts: 37
Thanks Received: 4
61
2013/10/29 - 17:50
Just curios...
Why is everyone trying to have gps Signal indoor?
Lottoman
Forum Posts: 43
Thanks Received: 10
62
2013/10/29 - 18:08
So they know they are home? Cool
hedom
63
2013/10/29 - 19:53
I am a relative Android newbie, and I am extremely disappointed with the speed of the m9pro.
The tablet takes 90 seconds to start and search an icon in the Stock UI Icon Theme takes about 30 seconds.
I got the last Kasty ROM installed and everything else runs relatively well, except just the speed and that after turning off the tablet or the charging often does not boot.
And well another thing: the lower screen bar flickers extreme, when the screen reloads, as for example for searches on Google or Dolphin.
Are these phenomenas known and has someone any solutions?
Thanks in advance.
hitvthanh
64
2013/10/30 - 05:39
i have my pipo m9pro 3g stock firmware rooted using TPSparkyRoot. i would like to
  • increase space for applications (/data partition) to 4 GB or 6GB or even 8GB
please show me how to do this without install custom rom
thanks in advanceSmileLaughLaugh
65
2013/10/30 - 09:20
I'm afraid this is not possible as you need to use a Flashing tool such as Rockchip Batch Tool to low-level reformat the tablet, reflash the firmware and get an increased space for apps.
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
66
2013/10/30 - 12:19
futzmaster said
Just curios...
My dear,
It is for testing purposes, to see the signal strength when you travel to a places that is concrete shielded, this is the best measure without you running around like a headless chicken around the neighbourhood and running into your neighborhood mall and wasting money drinking StarbXXX coffee just to test the gps out.
I like to go to the mall with my grandaughter and do all the necessary things that you can do while on gps at home. I dont travel a lot due to my medical condition but it pays when my children drive me around and i know that my gps is pulling in the signal.
cracktech
Malaysia
Forum Posts: 432
67
2013/10/30 - 12:32
Thanks in advance.
This what you should do next time before flashing any new ROM, just before going back to home screen to standby for the new flashing go into the internal sdcard and delete everything on the sdcard then attached the usb cable to device/PC and start flashing process (backup the data first onto external sdcard!!) OR you can go to setting and do factory reset or go to settings/storage/sdcard and format the sdcard. This prevents junk data that sometimes is retained on the sdcard that will interfere with the "fresh install" of new ROM , (I had this problem with installation of CM 10.2 on my other device and had  cause hours of headache) You shouldnt be having flicker problems at the bottom of the screen just because of the ROM (it could be loose cable inside). and the slow "ui" loading is due to I strongly belief "junks left over" from previous ROMs (but now is totally shielded from scrutiny by debugging tools  cause it is incorporated into the new ROM)
hedom
offsides
68
2013/10/30 - 17:40
Do your rooted ROMs support updating via the update.img method?  I'd rather not have to re-image and restore/reinstall my tablet every time I install a firmware update.  I'm currently using a rooted stock firmware, but I had to re-root after the latest firmware update, and I don't know if the previously created secondary user will still exist after I re-enable multiuser, so I'm looking for a more straightforward upgrade process for the future (not to mention the debloating/fixes your ROM provides)...
Thanks!
hedom
69
2013/10/30 - 19:01
Thanks in advance.
  hmm ...
I made a factory reset, then I flashed the factory ROM, then the custom ROM ... perhaps a reset too little ;(
the flicker problems at the bottom of the screen I had with the m6pro too ... then I updated to a new firmware version and the problems were gone ... but who knows?
anyway, thanks for the forecasts
fireblade9
70
2013/10/30 - 20:07
Hello guys
I have stock firmware 06/09/2013 and the skype when someone call me with video call restarted. Do you know if this firmware(Pipo M9 pro custom root Android 4.2.2 firmware (OTA_1.0.0 - 2013/10/23) solve this problem???
Best regards
gerfalcon
71
2013/10/30 - 20:32
Hello friends
I have a problem with internal 3g module. 2 weeks ago once a day i turn it on and tablet cant found network.
This just doesn't work and everytime I try to search for a operator I get a "error while searching for networks" error and I can not manually select the network. I tried many sim cards and firmware - riley 1.7b 1.8 kasty 10.10 and stock.
Can you help me pls!
Lottoman
Forum Posts: 43
Thanks Received: 10
72
2013/10/30 - 20:37
fireblade9 said
Hello guys
Best regards
I have the new OTA and no the problem is there. Skype do not work properly. I think it is a Android problem, not a Pipo problem.
The following users say thank you to Lottoman for this useful post:
fireblade9
slackerlx
Forum Posts: 52
Thanks Received: 9
73
2013/10/30 - 22:00
Lottoman said
fireblade9 said
Hello guys
Best regards
No. Not Android.
It works fine on my Ainol Novo7 Venus 7"And on my wife's Ainol Novo9 Spark, but it never runs properly on Pipo. On my Pipo I have replaced Skype with Viber!
Lottoman
Forum Posts: 43
Thanks Received: 10
74
2013/10/30 - 23:04
slackerlx said
Lottoman said
fireblade9 said
Hello guys
Best regards
No. Not Android.
Just to be sure: Are your Ainol Novo7 Venus using Android 4.2.2?
futzmaster
Forum Posts: 37
Thanks Received: 4
75
2013/10/30 - 23:12
Have you tried this: http://www.arctablet.com/blog/forum/pipo-max-m9/skype-not-working-on-pipo-m9pro/ ?
(maybe it helps...)
And no, its Pipo related...
69 Guest(s)
Devices in use: Desktop (62), Phone (7)
