[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (OTA_1.0.0 - 2013/10/10)
Mr.BlueSky
Germany
31
2013/10/17 - 13:42
Lottoman said
slackerlx said
Lottoman said
cracktech said
Will try to do it AGAIN! I just installed the factory ROm and rooted it beautifully with RootExploer installed,SuperSU and busy box installed and in the process of restoring the device when I saw this msg. Will tell you how it goes! I backed up using ROM Tool Box Pro it does the job of keeping my apps & data intact.
https://play.google.com/store/apps/details?id=com.jrummy.liberty.toolboxpro
It even backed up the wallpaper and email accounts. seldom used Titanium backup because on my other device with CM10.2 (4.3 Android) e are all facing problems in  restoring. It screws up the installations.
Hi
Can you ntell me how you rooted the factory ROM? I am not able to get in contact with the tablet with debugger on so I will appreciate your help.
Lottoman
Here's a root tool kit.. One click and three reboots  = Rooted
https://www.dropbox.com/s/62k6jv31aujpddx/RK3188%20ROOT%20Tool.7z
Thank you, but this is one I already tried. All these demand the debugger ON, but then it seems I  am not able to install the correct ADB driver so I do not connect. Oh, well there always something... Funny things are it do connect when I use Rockchip Batchtool 1.7, but then the debugger is OFF. So the correct driver should be there ??
Hi slackerlx,
here a fresh driver link:
All OS Version´s -> http://www.rockchip.nl/downloads/
Tell us, it´s working or not !!!
Hope, i can help...
Mr.BlueSky
Kati
Forum Posts: 14
32
2013/10/17 - 14:37
Hey Guys!
Do you Can you answer my questions? :(
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
33
2013/10/17 - 14:50
Here is the Rooting kit that doesnt have to reboot 3 times to get rooted it will install the SuperSU,RootExplorer,and busybox all in one go and after it reboots and you're rooted with all the apps installed.
I'll will provide you with the win7/xp,vista (but not tried on win8) Rk Driver installer by Rockchip, it come in **.exe format for Win installer after that you I advised you to reboot the Pc and switch off all background applications running on Pc like virus caneer,malware scan, disk defragmener, optimisers ect,ect then plug in the device to Pc and wait for the conect sound and it will take awhile for all the drivers to be loaded.
If you areahving problems with the latest KASTY ROm I advised you togo for the factory ROm but youahve to root it first and then uninstall all the blaotware, keep what you need.
0n3j0k3
cracktech
Malaysia
Forum Posts: 432
34
2013/10/17 - 15:07
Mr.BlueSky said
Lottoman said
Slakerlx,
I am on a modified RILEYS v1.8 ROm that doesnt have tis "provison errror" thingy. Will not revert to KASTY unless he sort this things out , I am on 6Gb data partition although I can go as high as 10Gb data partn (what the hell for?) but I extracted the boot.img from factory ROM and modified the build.prop by RILEY. Higher wifi tcp buffer size but it does seem to have wifi cut in and out problems and I communicated to RILEY devloper himself complaining that his system partition has 0Mb of extra space for anybody to add in any other extra app in the system folder unless somethings is taken out in this case the PIPO Lanchers 24Mb,calculator, RkExplorer,APKInjector, and many others , and en-app folders/zh app folder which is zero bytes (that has all sorts of **.nm files in there which is not used) I wonder how he manage to squezee the sytem partition so tightly until 0Mb of free space
futzmaster
Forum Posts: 37
Thanks Received: 4
35
2013/10/17 - 17:59
cracktech...
first of all: relax a bit...
We all know the problem, and we will try to fix it...
 as you may have read, admin doesn't have a m9 pro to test...
so all his firmwares are kind of beta...
please don't ask for fixes, we are on it, but we have to do other things in the Real World too...
be patient, when i have some time left, i am trying stuff with the m9, and admin trys to help...
riley rom has left some stuff (that is needed from the provision.apk) in his rom -> no error...
The following users say thank you to futzmaster for this useful post:
Mr.BlueSky
slackerlx
Forum Posts: 52
Thanks Received: 9
36
2013/10/17 - 21:09
Informative query:
What is this en_apk_install package anyway?
enable it during the setup or disable it?
What do I miss if I disable it?
Thanks Received: 3171
37
2013/10/17 - 21:23
Just wanted to confirm that I am aware of current problems with our custom firmware and I am working on fixing the problems as futzmaster said. It's not quite easy as I don't have a Pipo M9 pro tablet myself to test my modifications, thanks for your patience a new custom firmware will be published soon.
Lottoman, Terryfried, Mr.BlueSky, Johan007, griff2, 0n3j0k3, cracktech
yabalis
38
2013/10/19 - 00:34
thanks for the good work
and i confirm provision apk issues after first start pipo m9 pro wifi.
thanksSmile
paulogilmour
39
2013/10/21 - 19:19
I cant downgrade firmware!
Pipo M9 Pro - Kasty Rom
Samsung Galaxy Win Duos (Grand Quattro) - DocDroid Extreme 1.3
paulogilmour
40
2013/10/21 - 19:34
It did not work. Gave the error "provision".
But now I can not go back to the previous version of firmware! How do I?
The rockchipbath tool does not detect the tablet.
When I restart in recovery mode gets a android with a red exclamation.
What do I do? The tablet linking this normal enters the system and the error provision.
cracktech
Malaysia
Forum Posts: 432
41
2013/10/22 - 08:29
That the problem with you guys who dont read the whole forum thread first. If you have "Android goes belly up" the android with red exclamation mark press reset at the back camera (there is a small hole push pin inside) it. And reboot. it will go back to the page where you get "provision error" If you reach this page "provision error" then your tablet can be detected by the PC and you can downgrade it to the previous version.
If you still cannot get it to recognised first switch off the device a then run the RKbatch tool on your PC, then (dont switch on device yet) attach the usb to PC and device. The press the power button and ESC key together till the PC RkBatch Tool 1st square turn pink color. then press switch. it will turn to green color.
Then reflash with the previous version.
paulogilmour
42
2013/10/22 - 13:13
Hello Cracktech. I made it back to the old ROM. I copied the file update.img to TF card. When you insert the tablet, showing the same error message provision, had the option to do the update. After reboot back to normal. But the wifi did not work. But luckily the tablet came to be recognized by the PC. Goes like I did the restore with RkBath. Now everything is ok.
griff2
Sarlat
Forum Posts: 11
Thanks Received: 4
43
2013/10/22 - 14:32
I have been running rooted latest official version on my WiFi M9Pro (only for 24hrs to try out rooting procedure), and I've just had a successful OTA upgrade. Now shows as #347 Oct 22 2013. (rk30sdk-eng 4.2.2 JDQ39 eng.root.20131022.113923 test-keys)  Haven't seen the update on pipo.cn site anywhere yet.
cracktech
Malaysia
Forum Posts: 432
44
2013/10/22 - 18:15
Admin,
looks like there is gonna be another update! #347 hard to keep up with the factory updates, what the hell are they doing? But tough luck they have confirm that they are not giving us Android 4.3 maybe through CWM we can get the CM10.2 (And 4.3)
cracktech
Malaysia
Forum Posts: 432
45
2013/10/22 - 18:19
Good to hear that you made it safely down to earth. Learning is experiencing it first hand. Update to the latest KASTY ROm now it is stable no more provision error!.
54 Guest(s)
Devices in use: Desktop (51), Phone (3)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
