[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (OTA_1.0.0 - 2013/10/10)
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2013/10/16 - 23:14
Will try to do it AGAIN! I just installed the factory ROm and rooted it beautifully with RootExploer installed,SuperSU and busy box installed and in the process of restoring the device when I saw this msg. Will tell you how it goes! I backed up using ROM Tool Box Pro it does the job of keeping my apps & data intact.
https://play.google.com/store/apps/details?id=com.jrummy.liberty.toolboxpro
It even backed up the wallpaper and email accounts. seldom used Titanium backup because on my other device with CM10.2 (4.3 Android) e are all facing problems in  restoring. It screws up the installations.
cracktech
Malaysia
Forum Posts: 432
2013/10/17 - 00:05
Nope it is a waste of time I cant get to pass the page without encountering "provision stopped working" message. Even after I waited a while after installing en.apk , then when I press DONE it goes into this error again.I was just on the factory ROm and went to the same motion whitout any errors such as this except it doesnt do the OTA without registering the device first.
What-the-heck.jpgImage Enlarger
slackerlx
Forum Posts: 52
Thanks Received: 9
2013/10/17 - 00:13
Simple solution??
Install the factory sms rom. Root the damn thing and uninstall whatever you heart desires
tirmey
2013/10/17 - 00:21
Lottoman said
"cracktech, you missunderstand. During the install you get a picture where you shall pick your language and region, under there is the big greeen "V" in en_apk.install. Check this "V" and it goes away and proceed. That is all.Works fine."
Strange! To me, provision.apk have stopped even with en_apk.install unchecked... I have a non-3g model...
slackerlx
Forum Posts: 52
Thanks Received: 9
2013/10/17 - 02:27
I'm on factory Rom 10.10 Build #327
There are slight changes but the most of it I just fell in love with the newest launcher. Unlike his predecessor this one is fully customizable. Lovge it! Love it.. No issues so far. I'll keep testing
Screenshot_2013-10-17-03-16-05.jpgImage EnlargerScreenshot_2013-10-17-03-15-41.jpgImage EnlargerScreenshot_2013-10-17-03-15-19.jpgImage Enlarger
shal
2013/10/17 - 02:36
Lottoman, I do as you speak, but it doesn't help. The error is present. I have a non-3g model…
Kati
Forum Posts: 14
2013/10/17 - 03:03
I'm from Poland. I apologize in advance for spelling errors.
I bought Pipo Max M9 Pro. I'm pleased with it. For your forum I installed the firmware on 06/09/2013. Thank you very much for that!
I do not understand your posts. Please, excuse me. Is this the latest soft is defective?
Colleague above shows screenshots of the official version. Does this firmware have the same opportunities? I'm sorry if I ask stupid.
I would like to ask if it is possible to do folders thanks to this software?
Best regards!
Katherine
cracktech
Malaysia
Forum Posts: 432
2013/10/17 - 07:12
slackerlx said
Simple solution??
Yup thats what I did!! I installed the factory ROM.But the question remains! Mr. ADMIN PLEASE DO SOMETHING!! I am adamant at sticking to KASTY ROMs although I did try the RILEYs latest ROM v1.8 on this same build #334. It doesnt have this problem. That is why I insist on Mr.ADMIN to look into this issue.
Mr.BlueSky
Germany
2013/10/17 - 08:11
Do you have tested the following....!?
…from the freaktab forum member "colinabroad"
Found the com.provision.android and uninstalled
As if by magic the file provision.apk in the system/apps folder dissapeared!
cracktech
Malaysia
Forum Posts: 432
2013/10/17 - 08:33
Mr BlueSky how do you expect me to do that when I cant even get passed the first page? Do an adb pull??
Lottoman
Forum Posts: 43
Thanks Received: 10
2013/10/17 - 10:28
I am on the SMS version and got the same probleme installing this. Unchecking the "V" in en_apk.install fixed it and the rom installed and runs fine. I see no reason why this should be different in the OTA version but it obviously is. Then I am sorry - I can not help.
Lottoman
Mr.BlueSky
Germany
2013/10/17 - 10:29
Oopsss.... -> sorry cracktech,
Okay, colinabroad get this on working m9pro with Root Explorer !
I am still waiting of my new Pipo M9 pro.... !!!!!!!!!!!!!!!!
So i can´t test this yet... but is worth a try with adb pull, but dont forget to delete provison.apk too !!!!
Please tell me, if it works.
kind regards from germany
Mr.BlueSky
PS: Sorry, for my bad english... Embarassed
Lottoman
Forum Posts: 43
Thanks Received: 10
2013/10/17 - 11:24
Hi
Can you ntell me how you rooted the factory ROM? I am not able to get in contact with the tablet with debugger on so I will appreciate your help.
Lottoman
slackerlx
Forum Posts: 52
Thanks Received: 9
2013/10/17 - 12:38
Hi
Lottoman
Here's a root tool kit.. One click and three reboots  = Rooted
https://www.dropbox.com/s/62k6jv31aujpddx/RK3188%20ROOT%20Tool.7z
Lottoman
Forum Posts: 43
Thanks Received: 10
2013/10/17 - 13:10
Hi
Lottoman
Thank you, but this is one I already tried. All these demand the debugger ON, but then it seems I  am not able to install the correct ADB driver so I do not connect. Oh, well there always something... Funny things are it do connect when I use Rockchip Batchtool 1.7, but then the debugger is OFF. So the correct driver should be there ??
55 Guest(s)
Devices in use: Desktop (53), Phone (2)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
