[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (OTA_1.0.0 - 2013/10/10)
2013/10/14 - 16:29
Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M9 PRO (aka Max-M9pro) based on new update 2013/10/10 published by Pipo offering OTA (Over the Air) support.
(update_M9pro_OTA_1.0.0_20131010.img)
Notes:
- it's still not clear if this firmware is designed for the Pipo M9 pro model with or without 3G and I don't have these tablets to test with. If you have are not sure it will work on your model, please let the experienced members from the forum check the firmware and report about the compatibility. According to Lottoman (see post below), this firmware should work on both M9 pro 3G and non 3G models.
- please uncheck "en_apk.install" for this firmware to work, thanks udio80
- any update received thru OTA may interfere with our custom firmware, please let us know how it goes if you try such updates.
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #337 SMP PREEMPT Thu Oct 10 18:25:09 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20131010.182731:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU version 1.65 (free version)
  • removed most Chinese and unnecessary applications, removed Certificate Center asking for product key
Download: kasty-pipo-m9_pro-422-ota_100_20131010-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a PIPO M9 pro tablet to test the custom firmware.
Terryfried, Mr.BlueSky
Lottoman
Forum Posts: 43
Thanks Received: 10
2013/10/14 - 18:56
Sorry, don`t work. Provision stopped, did not open. Same as for the SMS version. Hope it can be fixed.
EDIT: From the SMS thread: I understand what the problem is you have to uncheck en_apk.install
I tried it on the SMS version and it works. It will probably do that on the OTA version too.
And for your info: Both version OTA AND SMS works with 3G and WIFI, I tested the originals and they are OK. But with the SMS version you can send and receive SMS if you have 3G activated.
Confused
The following users say thank you to Lottoman for this useful post:
admin, GeorgeKn
2013/10/14 - 19:48
Thanks for your tests and report Lottoman Wink
I'll add the tip to post #1.
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2013/10/14 - 19:50
Yup, this is dissapointing the "provision" stopped and I am stuck whether to wait for a corrected version or to go back to the previous version. Hopefully soon.
tirmey
futzmaster
Forum Posts: 37
Thanks Received: 4
2013/10/14 - 21:36
As far as i have read 3 Options:
1. the fix in the other thread...?
2. Admin leaves the pipo family launcher (and maybe it needs the other pipo apps too)
   I have read that the provision.apk wants to do the settings for these apps (at least the family launcher) -> should be testet...
3. delete the provision.apk by default...
  or with a skript at start up...?
The Pipo family launcher got an update in the new release, maybe someone can upload it again?
THX Admin for the good work and your quick Rom upload
2013/10/14 - 22:30
Thanks for the tips, I'm currently considering to remove provision.apk, but I need to make sure it doesn't have any serious side effects. In the meantime, it seems the tip from post #2, that I edited in post #1 as well does the job.
futzmaster, I'll try to extract and upload the Family launcher for you when I have a few minutes.
cracktech
Malaysia
Forum Posts: 432
2013/10/14 - 23:57
No need the OTA this build #337 is "ro.product.version=1.0.2" versus the the last version it was "ro.product.version=1.0.0" build #314. It was already the targeted version update that is supposed to be done thro' OTA which was intended to be "ro.product.version=1.0.1".
futzmaster
Forum Posts: 37
Thanks Received: 4
2013/10/15 - 19:25
Thx Admin.
No need to rush...
If we would test something, better to do it as a Beta release (Just to some users)....
Otherwise if anything fails, the crowd goes mad if everyone flashes it :)
@cracktech
don't really understand what you mean.
but the OTA in the firmware (i guess) means that this firmware is able to get OTA Updates....
not that it is an OTA Update (those are normaly just small updates....)
but maybe i miss understood you
cracktech
Malaysia
Forum Posts: 432
2013/10/16 - 05:40
What I meant was we are all so hyped up about getting an OTA updates. Now it doesnt matter because the version released was a build version "1.0.2" while we were on version #414 (the previous version) it was on version "1.0.0" and we were waiting for OTA update to version "1.0.1" (that was it said when it id the update)
and most of us gone "belly up".
It doesnt matter now, and only now I understand the reason after I complained to the factory we cant do OTA update they gave me the link to download this version. It is an already the updated version.
slackerlx
Forum Posts: 52
Thanks Received: 9
2013/10/16 - 07:35
Let me understand it clearly...
There's no need to update to a newer 10.10 version if you have successfully updated OTA Build #314. Is that right? Because I had no troubles or "belly up", as you put it, in updating my tab using OTA. And it never went "belly up"after update. Probably because I installed factory rom, not the custom one
cracktech
Malaysia
Forum Posts: 432
2013/10/16 - 11:32
Yup so far so good with the 1.02 version. No need to update to version 10.10 as you put it since youre on stock ROM and we are all on custom 4Gb or 6,8,10 ,16 Gb data partition. None of the customs ROM are able to do OTA update (obviously since it was modified) as far as I know of. You have to root it yourself and debloat it yourself and when I originally did that with the first out of the box firmware it went screwy until I discovered KASTY and RILEYS ROM.
What is the point of updating it to 10.10 version unless it is an Android 4.3 update which the factory flatly told me they dont have that planned anytime soon. Unless somebody can port it from CM10.2 like one of my pad which we all thought that the highest it can go from the factory 4.1.2 is that, now itis happily running 4.3 , thanks to customs ROMs
cracktech
Malaysia
Forum Posts: 432
2013/10/16 - 11:39
Please dont try this dangerous stunt by removing Provision.apk like the RILEY ROm it achieevd this without having to remove the provision.apk. It just circimvent the question of installing en.apk and just went straight into choosing the English language version US/British??
cracktech
Malaysia
Forum Posts: 432
2013/10/16 - 16:34
Thanks for your tests and report Lottoman Wink I'll add the tip to post #1. Cheers.
I didnt touch the install en.apk but it still "provision failed", this  is not the option for everybody, it is not an option for all. I'm going back to stock factory ROM and Root manually but will lose on the 4gb data partition, better than nothing until this is resolved.
Mr.BlueSky
Germany
2013/10/16 - 16:44
Thanks for your tests and report Lottoman Wink I'll add the tip to post #1. Cheers. I didnt touch the install en.apk but it still "provision failed", this  is not the option for everybody, it is not an option for all. I'm going back to stock factory ROM and Root manually but will lose on the 4gb data partition, better than nothing until this is resolved.
...from the freaktab forum member "colinabroad"
Found the com.provision.android and uninstalled.
As if by magic the file provision.apk in the system/apps folder dissapeared!
Now adding user #2 is easy.
Lottoman
Forum Posts: 43
Thanks Received: 10
2013/10/16 - 17:08
cracktech, you missunderstand. During the install you get a picture where you shall pick your language and region, under there is the big greeen "V" in en_apk.install. Check this "V" and it goes away and proceed. That is all.Works fine.
Now, if you already passed this, flash again and start over, it will work.
Lottoman
59 Guest(s)
Devices in use: Desktop (49), Phone (10)
cutierogue
