[ ROM ] Pipo M9 pro (3G model) custom root Android 4.2.2 firmware (OTA_1.0.0 - 2013/09/13)
baz069
46
2013/10/15 - 16:04
Just gotta say thanks for this ROM! I updated my M9 Pro (non-3G version) and everything worked first time. WiFi reception seems to be a lot better, and the annoying flickering buttons issue has gone. AnTuTu scores are slightly up too. :)
I'll be keeping my eye out for future updates. Many thanks!
baz069
47
2013/10/15 - 16:28
Just to add, the whole tablet seems much 'snappier' and faster than on the original stock ROM. Well pleased. :)
slackerlx
Forum Posts: 52
Thanks Received: 9
48
2013/10/16 - 08:16
@Admin
I forgot to report this occasion but here it is:
I was performing testing per Antutu Labs request using their newest "Antutu X Benchmark" supposedly the one which prevents cheating. It requires a login. I was, of course testing the factory Rom #314 updated by OTA
They were impressed by Pipo M9Pro performance. Here is our conversation log and my screenshot of it :)
Twitter Log <=Here
Capture-1.JPGImage Enlarger
baz069
49
2013/10/16 - 12:20
@slackerlx That's a good score.. the best i've been able to achieve is 18939, and that is when i force the use of the GPU for 2d drawing in dev options.
baz069
50
2013/10/16 - 12:25
@slackerlx just realised we got our tablets from the same supplier, i knew i recognised your username... :)
robulle
51
2013/10/17 - 08:54
I try this ROM for about two weeks now and I have some trouble with the brightness.
When I start the tablet I can adjust the brightness with the slider available in the settings panel but after about 30 minutes of use, the brightness automatically goes to the maximum. So I try to reduce the brightness in the settings panel but whatever the position of the slider is, the brightness is still very high (at the maximum I think). I precise that I am not in auto mode and I have no apps or widget to set the brightness (Actually I deleted everything that can interfere with the official setting). If I turn off then on the screen it is still the same, I have to reboot the tablet for having the brightness setting working again. It was not the same with the stock ROM.
Someone has the same behaviour or an idea ?
Regards.
PiPO M9-Pro 3G
robulle
52
2013/11/05 - 21:27
Actually it is a hardware issue. I created a topic for that here
http://www.arctablet.com/blog/forum/pipo-max-m9/solved-brightness-issue/#p32444
PiPO M9-Pro 3G
TGPB
53
2013/11/21 - 19:30
Just got a M9Pro for the wife, for Christmas.  Was going to update the firmware from the factory until I ran across this post.
According to the factory site they updated the firmware today Nov 21, 2013.  Should I wait for the latest firmware to be modified, by the local Guru, before updating the wife's tablet?
_________________________________________
                      Pipo M9 Pro
156 Guest(s)
Devices in use: Desktop (147), Phone (8), Tablet (1)
jacklewis3
123456asd
valdes1964
pipo2015max
Vickyabc
massoud
