[ ROM ] Pipo M9 pro (3G model) custom root Android 4.2.2 firmware (OTA_1.0.0 - 2013/09/13)
futzmaster
Forum Posts: 37
Thanks Received: 4
31
2013/10/10 - 15:26
You only need to delete the provision.apk
The following users say thank you to futzmaster for this useful post:
7Max2
robulle
32
2013/10/10 - 21:26
Hi, I deleted provision.apk thanks to terminal emulator but i still got a black screen for user 2.
Do y ou have another idea ?
Thank you
PiPO M9-Pro 3G
futzmaster
Forum Posts: 37
Thanks Received: 4
33
2013/10/10 - 23:03
Sure it was deleted?
Restarted the Tablet?
Try deleting the 2nd User, restart and create it again.
You say black screen.
Complete black screen or with "com.android.provision"
You can try pressing the esc button (maybe few times) it should apear something like provision is not respnsing, wait or close -> if close, it shows up again... -> and provision.apk is still there ;)
robulle
Rsly
34
2013/10/11 - 10:55
I upgrade the tablet, it works good now :)
mattiesrag
Forum Posts: 39
Thanks Received: 5
35
2013/10/12 - 11:59
Hi Kasty,
M9 Pro SMS 3G 20131011 (Don't know what the sms means????)
It appears PIPO have released new software. Yesterdays date. It would be interesting to know what changes have been effected. How about a new rom based on this.
I have tried Rileyrom 1.7b and yours is far superior - snappier - better wi-fi and 3g.
Thanks for all the excellent work thus far!!    Kind regards
Terryfried
36
2013/10/12 - 12:24
They have also added
M9pro_OTA_software_20131010
so looks like ota update possibly for wifi version only and SMS version(whatever that is) for 3G.
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
37
2013/10/12 - 15:04
No!No! Dont download from the Chinese site it is for Chinese version.
I got another link from factory side for International version(English)
heres the link: https://www.wetransfer.com/downloads/2b291e374521a8e1d92f8a20520a9f1d20131012053217/5e198a7aaa440520652ba5a1af0c2d2920131012053217/2bcca7#
I got this after I've complained to them regarding their OTA is NOT working. Need to capture the OTA update files.
cracktech
Malaysia
Forum Posts: 432
38
2013/10/12 - 15:13
I had checked the Riley ROM parameter files here is what is wriitten in there see the first line it is set to Android version 4.1.1 wheras we are on 4.2.2. KASTYs ROM is as close as we can get to the factory ROM and the factory recognises it so. When i complained to factory that we cant do OTA update they refered me back to this Forum.
Parameter file for 4 Gb RILEY ROm is attached (from RILEY 1.7B version)
txaguin
Spain
39
2013/10/12 - 17:37
Hola a todos.
Acabo de instalar este firmware en mi Pipo m9 pro 3G y va de maravilla. La tablet ahora va perfecta. Ha ganado en rapidez y ya no se producen los molestos parpadeos de pantalla que hacían que se pusiera en visión doble. Agradezco enormemente este trabajo. Enhorabuena y muchas gracias.
LaughLaughLaughLaugh
amgat
Norway
40
2013/10/12 - 17:43
Write English please, so the rest of the world understand what you say
txaguin
Spain
41
2013/10/12 - 17:50
Ok. Sorry.
Hello everyone.
I just installed this firmware on my m9 pro Pipo 3G and going great. The tablet is now perfect. It has gained in speed and no longer cause the annoying screen flicker that made double vision was put on. I greatly appreciate this work. Congratulations and thank you very much
Dereck
Forum Posts: 15
42
2013/10/12 - 17:58
Hi all.
I`m having problem with wifi - it stucks... I need to go to the settings and turn off/on it, but simetimes even this did not help.
Does anyone know how to fix this?
slackerlx
Forum Posts: 52
Thanks Received: 9
43
2013/10/12 - 19:35
Dereck said
Hi all.
You cannot it's a hardware fault. I had the same thing with M9. So I sent it back to retailer and they replaced it to me for M9Pro which I currently own. Just replace the damn thing
vbpian
44
2013/10/14 - 05:24
Hi
I've installed this ota firmware version, but I found a problem that my sim card is not detected. I've tried to pull out and put back my sim card but still doesnt work. Reboot is wasting time i ever try, After some try my  sim card can be detected and the data connection can be made.
The problem will re-appear if the modem power is turned off or reboot process... i`m going crazy to this
Please help, what is the root cause to this problem and how to solve it
Thank you, and i appreciate you great work
robulle
45
2013/10/14 - 09:13
It works great !
Actually the file Provision.apk has to be deleted before creating the second user.
I deleted the second user restarted the tablet then created the second user again and it works !
Thank you !
PiPO M9-Pro 3G
78 Guest(s)
Devices in use: Desktop (69), Phone (9)
heydude
Varnanfilms
jacklewis3
123456asd
valdes1964
pipo2015max
