[ ROM ] Pipo M9 pro (3G model) custom root Android 4.2.2 firmware (OTA_1.0.0 - 2013/09/13)
2013/09/18 - 16:06
Update info: According to our forum member cracktech, see his post here, this firmware is built only for the 3G model and should NOT be used on a M9 PRO tablet without 3G.
Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M9 PRO (aka Max-M9pro) new tablet hardware that is equipped with a GPS and 3G module. This firmware is based on new update 2013/09/13 published by Pipo offering OTA (Over the Air) support.
(M9pro_OTA_1.0.0_update_20130913.img)
Notes:
- Pipo firmware doesn't mention if it's built for M9pro model with or without 3G, it may also be a unified version supporting both models.(see update above)
- any update received thru OTA may interfere with our custom firmware, please let us know how it goes if you try such updates.
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #314 SMP PREEMPT Mon Sep 9 17:40:27 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20130913.172925:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU version 1.60 (free version)
  • removed most Chinese and unnecessary applications, removed Certificate Center asking for product key
Download: kasty-pipo-m9_pro-422-ota_100_20130913-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a PIPO M9 pro tablet to test the custom firmware.
amgat, diego.m, tsam2, Hawk, frank10, txaguin, tikitin, baz069
futzmaster
Forum Posts: 37
Thanks Received: 4
2013/09/18 - 22:29
Thx for this updated Version.
The new OTA Update to 1.0.1 failed
Does your rom use CWM as recovery?
booting to recovery:
Can anyone confirm that it works to boot into it?
(boot with adb or select recovery in the app arctools)
when i try it, i only see the android lying on the side, "belly" door opend with exclemation mark :)
The following users say thank you to futzmaster for this useful post:
cracktech
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2013/09/19 - 16:49
DO NOT USE THIS ON A NON 3G MODEL IT WILL SCREW YOUR PAD UP. THIS IS FOR THE 3G VERSION AS I 'VE NOTED ON THE VERY FIRST PAGE OF THE PROVISION SETUP THERE IS A BUTTON FOR "EMERGENCY CALL"
2013/09/19 - 17:10
Post #1 and topic title title updated, thanks for your report cracktech.
futzmaster
Forum Posts: 37
Thanks Received: 4
2013/09/19 - 19:36
I had it installed on the Wifi Version and it worked well (for the few minutes i tested it yesterday)
Because of your alert i went back to the older version (had to reflash anyway, because i tested the Riley Rom and just thought WTF to the bootanimation *g*)
You can ignore the other post, regarding the recovery Problem...
CWM is working (with riley rom, but think it will work to on yours...)
cracktech
Malaysia
Forum Posts: 432
2013/09/19 - 22:00
Oooh! it did work on your non 3G model?, I cant get it to even point to where I wanted it to be the softkeyboard was all screwy I cant even manage to type in my password of wifi properly, only then I realised the first page had an "emergency call" button (that should be a hint). But I kind of like the setup page dont you agree a step by step page to page setup? If only we could extract it through adb and see whats inside. the provision applications should be my target to extract since it is cooool!
regarding the bootanimation I have the original PiPo one that I have attache dfor you, I like the PiPo bootanimation versus the after market ones and customs ROM bootanimation these are techies not artist, they amde horrible animations.
the attachement is below
futzmaster
Forum Posts: 37
Thanks Received: 4
2013/09/19 - 22:17
Thx for the boot animation, but i am very happy with this rom, so no need to change it :)
Wifi and typing worked without any problems.
Got an OTA Update message on internet connection but installation failed (maybe just for me, because i tried some stuff with the recovery)
Didn't do any further tests...
Edit:
Forgot:
The new Wizard is very nice...
Maybe you had these problems because the Tablet was still loading something in the background?
cracktech
Malaysia
Forum Posts: 432
2013/09/20 - 06:40
I couldnt even get pass the wifi setup page! with the screwy touch screen I decided to abandon the attemp before I break something else. What ROM are you on now? The OMA RK31 ROMs with its TWRP/CWM recoveries?
amgat
Norway
2013/09/20 - 06:44
Flashed ROM yesterday on my WIFI model. Functions are working just fine, and the tablet seems a lot snappier compared to the stock ROM. Also the WIFI is working great (was fixed in an earlier release i believe).
I ran into the same problem as futzmaster. An OTA update is detected and if i do choose to upgrade, my jellybean goes belly up.
cracktech
Malaysia
Forum Posts: 432
2013/09/20 - 11:47
Hmmm, Hmmm why was mine so screwy when I update it??
futzmaster
Forum Posts: 37
Thanks Received: 4
2013/09/20 - 18:01
I use the older Kasty Rom from 6.9 (because of your alert *g*)
(i am out for one week and need the tablet, so it should work^^)
I have flashed the Recovery seperatly after flashing the Kasty Rom.
Took the Flash Tool and CWM Recovery from the Riley Download.
Maybe give yourself a new try with the latest Version, and just give it enough time to finish loading (give it an extra restart..?)
cracktech
Malaysia
Forum Posts: 432
2013/09/20 - 18:33
                                      REDACTION, CORRECTION ON THE LATEST #314 Firmware
The firmware is compatible with WiFI version if it fails redownload the file again and reflash again, it is working fine after I redownload it again (I remember it happened around the time your servers were down , I cant post replies or comments then)
It is working fine now on my pad and it even downloaded all the softwares installed from Google Playstore by itself (restore for the first time directly from google) after the reflash, just remember to backup the launcher settings and desktop settings and keep it somewhere outside the internal memory). The new software is better I have no more problems with touch screen and wifi is great.
If you have problems the first time you reflash try the 2nd and even a 3rd time to cleanse the nand,ROM from previous installation I found out that after teh reflash I even have stragglers apps already installed from my previous installations.
So please if you want to take the risk of flashing a new ROM every other week from PiPo please do so at your own risk (of breaking the pad) only 3 weeks ago my stock ROM out of the box was build #270 now it is already build #314.
mcbyte
2013/09/21 - 17:29
I have installed this ROM on my new M9pro Wifi (without 3G).
It's runnig good, but the first OTA update 1.0.1 failed after reboot.
Only reset button can reanimate the device and I have disabled the OTA function now....
- Pipo M9 Pro  4.2.2
- Hero H7500+  4.2.1
cracktech
Malaysia
Forum Posts: 432
2013/09/22 - 04:55
For those that has successfully updated their pad to the new firmware from the posted linkby adminon this page, When  the notice comes up to update OTA. Please DO NOT DO SO, (when it ask do you want to update just click NO) as mentioned by various members here your android will go "bellyup" and god knows what else it has modified to the firmware.
Then go into the build.prop and add "##" at the very beginning of the line the second last line in the build.prop "ro.product.ota.host=*************"into "##ro.product.ota.host=*******" or use and a build.prop editor to edit  the name  after the "=******" into  blank "=       " but keep the name  recorded somewhere so that if on the same firmware it needs an update you can fill the name back in after PiPo resolved the matter (if ever they can resolved it). This is to avoid the trouble of our android going belly up after  the update.
tsam2
2013/09/23 - 20:26
Hi, i have a noobish question.The flashing of the custom rom is being done same as the procedure of flashing the stock rom?Do i have to root first my pipo m9 pro or i flash the custom rom directly?Also are there any restrictions for flashing a custom rom, like after the latest update to flash a previous custom rom edition.Thanks in advance.
75 Guest(s)
Devices in use: Desktop (70), Phone (5)
revoltown
tdomnic024
otismaibe
Tsuna77
docentik2006
