[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (2013/12/09)
TheGeobi
61
2013/12/19 - 16:48
ludoke said
Do you flash in the wright way?
Factory/data reset?
i followed the steps from the official site for the official roms and the unofficial ones. i had that problem from the first day and that's the reason i tried to flash a new rom....is there any other way to flash?? i might miss something. what are the right steps??
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
62
2013/12/19 - 16:59
TheGeobi said
Factory/data reset?
Here is the correct upgrade guide as of version 1.7, my own compilation for newbies. Dont use the original PiPo upgrade guide that came in the original  Rkbatch Tool v1.7 foder which is in MicrosoftWord format
TheGeobi
63
2013/12/19 - 17:12
cracktech said
I was just reading through the threads, yes thats about right. Go into the internal sdcard (sdcard0) and delete the whole thing inside there and then after a wipe through CWM you reflash the ROM through normal method.
I once lost wifi for 4 months and spent a whole lot of money to connect to internet on another device. But after I did the following steps and reflash a newer ROM, I got the wifi back and now the minute I boot up it is already ON. the most important is the dalvik cache inside the system folder (that needs to be erased).
Do all this just before you go out to reflash the newer ROM (try not to switch off , just in case)attach the USB cable --- run RKBatchTool---then flash it again.
thats how i flashed the rom, i also followed the steps in the quote and reflashed. i have still the same problems with the freezes and the restarts.....
mnemonic.jr
64
2013/12/20 - 15:53
G B
Forum Posts: 21
Thanks Received: 5
65
2013/12/21 - 19:01
Hi
For Everyone facing issues of hang/freeze, device operating slower than usual, Wifi, or 3G not working properly or Hide taskbar button Not working or issues of Browser, Wifi Display...
Wipe DALVIK CACHE!!!
Wipe dalkvik cache after you flash your firmware, let it boot completely reach the home screen...
Options 1
Install CWM or a recovery of your choice.... Wipe dalvik cache
Option 2
Install "System Cleaner" app from the playstore. In the menu you'll find option to "Reboot with Dalkvik cache wipe".
I followed the second option!!! You'll need ROOT PERMISSIONS in both ways
-G B
The following users say thank you to G B for this useful post:
AJS007
mattiesrag
Forum Posts: 39
Thanks Received: 5
66
2013/12/22 - 13:42
G B said
Hi
Options 1
Option 2
-G B
There are many system cleaner apps on playstore. Please send a link so I can download the app you are referring to.
Thanks. PM
cracktech
Malaysia
Forum Posts: 432
67
2013/12/22 - 13:57
Dear Mr Mattiesrag,
I recommend this if you insist on downloading an app:https://play.google.com/store/apps/details?id=com.lukemovement.roottoolbox.free    You can otherwise install the CWM recovery and reboot into CWM recovery and from there you can do a cache and dalvik cache wipe. or If you are more in the "mood", just go into your /system/data/dalvik-cache folder and erase ALL the files inside there and then reboot. the device (it will take slightly longer the first time)
G B
Forum Posts: 21
Thanks Received: 5
68
2013/12/22 - 21:27
mattiesrag said
G B said
Hi
Options 1
Option 2
-G B
Thanks. PM
Try the 'System app cleaner' by Flaki. It requires root permissions
gogojoe
69
2013/12/24 - 18:22
Hi.  I understand “From the hidden status bar to show it again: slide from bottom of the screen to the top..”.  I am having some trouble doing this.The hidden status bar on the bottom of the screen is Restored (as expected) – if my Pipo screen is in Landscape orientation.  But NOT when I am in Portrait Orientation.
Anybody else having this Problem?
gogojoe
70
2013/12/24 - 18:28
mrleezh said
just updated to this new rom. seems to be the smoothest for me thus far. however, got an issue. not sure its just me or others facing this as well. my screen doesnt seem to have the auto rotate. not to sure why also. any ideas?
You might wish to go to "Settings"  -- then to "Accessbility", and checked the "Auto-rotate screen" setting.
My pardon if you have already done the above.
laloman18
71
2013/12/24 - 22:01
Hi.  I understand “From the hidden status bar to show it again: slide from bottom of the screen to the top..”.  I am having some trouble doing this.The hidden status bar on the bottom of the screen is Restored (as expected) – if my Pipo screen is in Landscape orientation.  But NOT when I am in Portrait Orientation. Anybody else having this Problem?
---  In portrait mode
While in portrait mode, the screen hides the status bar hides automatically.  In order to make it reappear there is a trick and I found this by accedent.
About an inch going left from the bottom right corner of the active screen u need to "slide" your finger starting from the frame part of the tablet and slide it up,  this will pop the bar back up.  Do the opposite to rehide it back down.  That's all it is to it!
The following users say thank you to laloman18 for this useful post:
gogojoe
laloman18
72
2013/12/24 - 22:05
—  In portrait mode
73
2013/12/27 - 11:49
AJS007
New Zealand
Forum Posts: 15
74
2013/12/30 - 08:25
Hi, For Everyone facing issues of hang/freeze, follow G.B s instructions my pipo has never run so fast or smoothly ! . What a transformation. Thanks for the great work. Im not touching kitkat now till the teething problems have been solved , not Brocken don't fix!.Smile
PS: crackteck I have made contact with Ronald , fingers xed I can help him !
grzegorz82
75
2013/12/30 - 10:11
Can I upgrade firmware with CWM Recovery?(I have installed CWM) If I can, what the settings? Choose only wipe dalvik cache? I can't find a tutorial.
Sorry for my english.
60 Guest(s)
Devices in use: Desktop (57), Phone (3)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
