[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (2013/12/09)
mrleezh
31
2013/12/13 - 17:09
alright new updates. even with stock rom. it seems like my g sensor is somehow stuck? i cant seem to get it to rotate.
darevil102
Forum Posts: 35
32
2013/12/13 - 17:18
Download "G Sensor" app from google store and check your sensor
ludoke
Forum Posts: 85
33
2013/12/13 - 17:24
Reflash the rom ,before  flash  data/factory reset again ,wipe dalvic cache
mrleezh
34
2013/12/14 - 05:00
Just to confirm the steps. I reflash a new rom. Install the cwm recovery that this forum provides. Then reboot to recovery and then do the dalvick wipe with all the other wipes. by then it will be clean of any roms etc so I need to re flash again right?
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
35
2013/12/14 - 08:46
I was just reading through the threads, yes thats about right. Go into the internal sdcard (sdcard0) and delete the whole thing inside there and then after a wipe through CWM you reflash the ROM through normal method.
I once lost wifi for 4 months and spent a whole lot of money to connect to internet on another device. But after I did the following steps and reflash a newer ROM, I got the wifi back and now the minute I boot up it is already ON. the most important is the dalvik cache inside the system folder (that needs to be erased).
Do all this just before you go out to reflash the newer ROM (try not to switch off , just in case)attach the USB cable --- run RKBatchTool---then flash it again.
mrleezh
36
2013/12/14 - 09:07
alright. tried your methods guys. still a no go. screen doesnt rotate. i got to rely on widgets/apps now to turn the screen.
cracktech
Malaysia
Forum Posts: 432
37
2013/12/14 - 09:48
Too bad! But one of these days after flashing another update you will find that the rotate will come back if its a software issue and not hardware issue. We all go our bad days even the device. The last update(just before this) I cant get my "hide status bar" to work after this update (current) it works!
And I notice that even sounds of you going through the file list is there (anybody notice this?) They put in newer and better sound effects to everything you do on your device.
mrleezh
38
2013/12/14 - 10:57
haha. thanks for the encouragement! im gonna get the tablet open one of these days. so hopefully that can somehow spring it back to life(g sensor)! actually its not a massive game turner for me. most games/apps i use will be in landscape so its alright. but on the occassional books and facebook, it would be good to see it in its awesome portrait goodness.
BOZ77
Forum Posts: 15
39
2013/12/14 - 11:45
hello
Then to reply to plusieure problem.
1 - Problem Fast Show Start = press really hard on the button on
2 - HDMI cable and USB problem = cut the plastic around the connection of 2 to 3 mm.
pipo the tablet is poorly designed because the connections are too short and also for Boutton it and returns
3 - problem SD = sorry but I can not find the solution
Now I give you some added line in your build.prop to improve the autonomy of the battery, a faster startup , better performence of ecrant and some small improvement :
Disable bootanimation For Quicker Boot:
 debug.sf.nobootanimation = 1
Solve problems Application:
 ro.kernel.android.checkjni = 0
 Save battery :
 pm.sleep_mode = 1 = 0
 ro.ril.disable.power.collapse
With GPU Rendering User Interface :
 debug.sf.hw = 1
Changing build.prop to optimize video streaming
media.stagefright.enable - player = true
media.stagefright.enable -meta = true
media.stagefright.enable -scan = true
media.stagefright.enable -http = true
media.stagefright.enable - record = false
Accelerated Video On
video.accelerate.hw = 1
Disable sending usage data
ro.config.nocheckin = 1
Scroll faster
ro.max.flingvelocity = 12000
ro.min.fling_velocity = 8000
Frees RAM to allow applications to load faster ( change the existing line )
dalvik.vm.dexopt -flags = m = v , o = y
I also change the board dencity 240 230 that improves the fluidity of the picture
DO NOT ADD THIS LINE = 500 windowsmgr.maxevents_per_sec this bloquerra your device.
for all change build.prop editor download google play .
The following users say thank you to BOZ77 for this useful post:
griff2
joemilan
40
2013/12/15 - 10:17
Hi all, why i can't download this rom? I have INTERNAL SERVER ERROR...
There's another link fro download?
ludoke
Forum Posts: 85
41
2013/12/15 - 12:41
Llink IS working !!!
rover75
42
2013/12/15 - 22:36
This new firmware is exclusive to Pro M9 or also works on M9 Max ?
43
2013/12/15 - 22:53
This is for PiPO M9 Pro only, don't flash it on a regular M9 max (non Pro).
All M9 firmwares (Pro and regular models) are listed here: http://www.arctablet.com/blog/forum/pipo-max-m9/
rover75
44
2013/12/15 - 23:36
OK
galmiche
45
2013/12/16 - 14:02
Hi all,
I just bought my tablet and got it a few days ago.
After installing this ROM (renamed it to upgrade.img placed on SDCard the rebooted),my WIFI speed is very very poor.
With several 802.11n routers my Wifi connects only up to 13Mpbs max.
Do you know how to solve the problem?
Thx
Hervé
PiPO M9 PRO 3G
57 Guest(s)
Devices in use: Desktop (51), Phone (5), Tablet (1)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
