[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (2013/12/09)
mrleezh
2013/12/12 - 17:31
just updated to this new rom. seems to be the smoothest for me thus far. however, got an issue. not sure its just me or others facing this as well. my screen doesnt seem to have the auto rotate. not to sure why also. any ideas?
ludoke
Forum Posts: 85
2013/12/12 - 17:51
Did you factory/data reset before or after flashing ?
patoche87
2013/12/12 - 18:39
darevil102 said Nobody has problems with quick boot? When I shut down, sometimes I have to press the power buttom several times to turn on the tablet
I have the same problem. Perhaps the best option is to switch it off in settings.
I have the same problem, too.
darevil102
Forum Posts: 35
2013/12/12 - 19:42
Yes, I have this mode switch off in settings and all works ok. So it seems a ROM issue.
ludoke
Forum Posts: 85
2013/12/12 - 19:53
For Quickboot see post 15,it's not a rom issue,you must choose shuttoff and not reboot.
After that,when you power up it,' starting up in 10 secs on lock screen.
ludoke
Forum Posts: 85
2013/12/12 - 20:18
Sorry guys, the first it works for me but after all the negative posts abou quickboot i tested again and indeed something is wrong,tablet boots up and freezes completely. Only resetbutton helps.
darevil102
Forum Posts: 35
2013/12/12 - 21:13
I have tried ten times and it worked ok. I think that this mode is a russian roulette ;)
AJS007
New Zealand
Forum Posts: 15
2013/12/13 - 02:45
I don't like the sound of Russian roulette , think I will stick with previous version.
It has the best running WiFi and touchwood , never crashed . I have found that one brouser caused a lot of trouble ( HD at end).
Thanks admin for all the hardwork , pls don't loose it with newbees if it don't sink in first time :-)
Alan
lukeeeeeee
2013/12/13 - 11:27
ho to all ... :) i've on mi pipo m9pro previous Kasty rom installed...now when i put on this new rom i've to backup all app and then reinstall them or not necessary ? thank all
darevil102
Forum Posts: 35
2013/12/13 - 11:31
Yes, you need to back up apps ad then reinstall
mrleezh
2013/12/13 - 16:03
does anyone else face the portrait landscape issue? my tablet will be stuck in the particular orientation until a reboot which will change it and then remain that way. another way for it to change is when another app forces it to change orientation and it gets stuck again. i did not face this problem until i flashed this rom. however, after several attempts at flashing other roms to make sure that its this rom that has a bug apparently, all the roms have this issue =(
therefore i can assume that there is smth wrong with my tablet?
ludoke
Forum Posts: 85
2013/12/13 - 16:15
see in the above right corner(drop down menu) is automatic rotation is checked or unchecked.
That should solve the problem.
mrleezh
2013/12/13 - 16:39
i have done that. i have also manually tried it from the settings page. my rotation is like locked. as if my g sensor has gone haywire. tried some random app which requires me to catch a soccer ball. i keep missing unless its in the centre. i cant seem to get it to work. i am re flashing this rom again to see if it can work once again. wish me luck.
i will try it again with temple run again later.
proven doesnt work. i shall try your ideas and come back with findings.
darevil102
Forum Posts: 35
2013/12/13 - 16:46
Good luck, dude. Try with a stock Rom.
ludoke
Forum Posts: 85
2013/12/13 - 16:48
Did you data/factory reset?
48 Guest(s)
Devices in use: Desktop (44), Phone (4)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
