[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (2013/12/09)
2013/12/10 - 15:07
Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M9 PRO (aka Max-M9pro) for both WiFI and 3G models. This custom firmware is based on new official update dated 2013/12/09.  This update offers the new Quick Boot feature released on some other PiPO tablets.
(update_M9pro_OTA_20131209.img / M9pro_OTA_software_20131209)
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #398 SMP PREEMPT Mon Dec 9 10:03:39 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20131209.100724:eng/opinions-on-teclast-p90hdst-keys
ro.rksdk.version=RK31_ANDROID4.2.2-SDK-v1.04.00
  • root with latest SuperSU version 1.80 (free version)
  • optional ClockworkMod (CWM) Recovery easy install package
  • NEW! optional Deep Sleep fix for some Rockchip RK3188 based tablets ArcTools package
Notes:
- Certificate Center and original PiPO launchers have been kept in the firmware
- to hide the status bar, press the last button on the right from the status bar
From the hidden status bar to show it again: slide from bottom of the screen to the top.
- we have posted a short video about the Quick Boot feature
Download: kasty-pipo-m9_pro-422-ota_20131209-rooted4.zip
JugeHuge, --k0l0kaust0--, maryontour, tim2121, AJS007, goguenard, Reini, regne v, pipo1924, soenghei, rodeomb, Andi_Berlin, prp, KenMic35
manuelr
2013/12/10 - 15:53
thanks for that quickly work
The following users say thank you to manuelr for this useful post:
Kostian90
darevil102
Forum Posts: 35
2013/12/10 - 15:57
works it fine? I have the previous Custom Rom. Can i update by OTA?
darevil102
Forum Posts: 35
2013/12/10 - 17:06
Muy Pipo m9 pro is working with this new ROM. Thanks. I did it vĂ­a PC because ota don't worked for me.
2013/12/11 - 11:18
I have moved xocolocoxoco posts about his bricked tablet here since they are not related to this new firmware update, please let stay on topic here.
--k0l0kaust0--
hal rockwell
2013/12/11 - 14:42
Can it be installed via CWM?
2013/12/11 - 14:59
Nope, Rockchip Batch Tool version 1.7 only.
Future versions will come in CWM packages.
--k0l0kaust0--
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2013/12/11 - 15:31
You will know when a firmware is installable though CWM when you find the firmware comes in a few zip packages (e.g. Gapps.zip, Firmwareupdate.zip, Single/Multiuser.zip) and the anoouncement through the forum that it comes in CWM installable format, else dont try it unless you get a CWM backup of the latest firmware from someone who already installed on on their device, then you can use the CWM restore.
Else dont waste time in asking this question over and over again.
--k0l0kaust0--
hal rockwell
2013/12/11 - 15:49
Why does every time that I update to a newer version of Kasty rom it erases the CWM and reverts back to the original recovery?
darevil102
Forum Posts: 35
2013/12/11 - 18:10
Kasty rom has the stack recovery, so when you update to a newer version, you install it. You only need to use the arctools app to re-install CMW recovery in 2 clicks.
Jazzie
2013/12/11 - 19:02
Thanks for your express work.
Btw Pipo U8 has already KitKat (from yeasterday), you're thinking that M9 Pro will have too soon?
darevil102
Forum Posts: 35
2013/12/11 - 19:50
Nobody has problems with quick boot? When I shut down, sometimes I have to press the power buttom several times to turn on the tablet
Jazzie
2013/12/12 - 13:42
I have the same problem. I must have been use Reset. Quick Boot is not functional.
mattiesrag
Forum Posts: 39
Thanks Received: 5
2013/12/12 - 16:37
I have the same problem. Perhaps the best option is to switch it off in settings.
ludoke
Forum Posts: 85
2013/12/12 - 17:20
You have to in Quick boot tick the box ,then power,not reboot but shutoff.
When you power on ,tablet boots in 10 secs
77 Guest(s)
Devices in use: Desktop (71), Phone (6)
