[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (2013/09/06)
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
76
2013/10/18 - 20:00
tramin said
cracktech It is interesting, everyone is doing differently,charger is needed,or is satisfactory fully charged battery?Thanks
It is enough if the battey is fully charged. Differntly? Maybe you are using another custom ROm? The rkBatch tool v1.7 is enough if you get your device identified by the PC and the pink square turns on.
Didnt you read the instructions? The factory says to use upgrade button we are using the restore button (I am on another forum and a user got his device nearly bricked by using the upgrade button).
Just do as per this forums instructions use the restore button, and dont need the key combination, it will make your Pc and device goes screwy (I dont recognise you, what do you want me to do to you,who are you, amnesia??? by both the device and PC) I tried it once when I nearly bricked my device (use key combination and they just ignore each other and dont want to do the flashing.)
I mange to get them to recognise each other and the pink square comes on and press "switch" it turns to green (that means it is put into the upgrade/flash mode from the PC RKBatch application) not the key combination.
cracktech
Malaysia
Forum Posts: 432
77
2013/10/18 - 21:04
That is RK Batch tool not the Version 1.7, you must use version 1.7 by the way you didnt attached the link address. This M9Pro flashing must use version 1.7 Batch tool.
alain0091
78
2013/10/20 - 10:26
Thanks for your ROM
Is it possible to know in details how you create a custom rom for the M9pro step by step
Also I would like to add modules like dvb-usb-....ko ( I have TV dongle af9015, IT9135 and cinergy tstick RC) to get Digital TV working
Thanks a lot for your support
paulogilmour
79
2013/11/04 - 12:13
Xposed Framework
IMG_2013110432970.jpgImage EnlargerIMG_2013110447954.jpgImage EnlargerIMG_2013110421307.jpgImage EnlargerIMG_2013110431352.jpgImage EnlargerIMG_201311045579.jpgImage Enlarger
Pipo M9 Pro - Kasty Rom
Samsung Galaxy Win Duos (Grand Quattro) - DocDroid Extreme 1.3
armspecial
80
2014/03/13 - 16:59
i have question i have  max M9 pro  my GPS doesnt work, if i update official 4.2 to this rom, will it work ?
cracktech
Malaysia
Forum Posts: 432
81
2014/03/13 - 21:15
first you install the CWM recovery through the ArchTablet Tools.
the go into recovery and  delete the dalvik cache and data basically cleansed the device except DONT use any format command.
Then flash using KASTY latest ROM Mar 2014 version. The GPS should be working except that it is a little bit weak in the signal due to the metal backing (but i have heard that there are models coming out of the factory already with plastic back cover). I confirmed that with another user (I asked him is it the original device or a copred device, he confirmed that it is the original and he can flash KASTY ROM successfully).
The GPS in order to get a slightly better signal you have to put in the "gps.conf" file basically it is to tell the device of your locality and geographical location. Find inside forum threads for how to improve the GPS signal.
But I am so dissapointed with the GPS performance also as I am uisng a 6inch LENOVO Quadcore Mt6582 Phablet it always have full house as far as satellite signals are concern in less than 3 secs!.The M9pro although also a quad core device is laggy compared to Phablet.
All i can say is that the firmware doesnt have a problem with GPS per se (it works but....).If you still have problem with adead GPS maybe you have to look at hardware, wires and antennae placement, shortings etc. etc.
armspecial
82
2014/03/13 - 22:19
ok ill try thanks ) . but i thing it will not help 🙁
fifa_05
83
2014/09/12 - 23:07
I think I have bricked my Pipo M9 pro.
I used restore button. It was flashi good but at the end I had "TEST DEVICE FAIL"
I restarted the flashing and at the start,(before the flashing I'm having "TEST DEVICE FAIL")
Pls help :( Adsız.pngImage Enlarger
fifa_05
84
2014/09/13 - 06:40
pls help
135 Guest(s)
Devices in use: Desktop (127), Phone (7), Tablet (1)
jacklewis3
123456asd
valdes1964
pipo2015max
Vickyabc
massoud
