[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (2013/09/06)
tirmey
61
2013/10/10 - 20:52
Thanks, admin!
Your firmare is very clean, and i have noticed an increment in antutu scores (around 18.500 pts now against 16.000 before). Battery life is good (having in mind the 1080p 10.1 " display): about 9 hours of moderate use (wi-fi on,  screen bright at 25-50%, casual gaming or video play).
But i have experienced some problems (i don´t know if caused by firmware or RK3188 hardware):
- Random freezes, even in low demand tasks, like internet browsing, for instance.
- I noticed too a low performance in ezpdf reader (performance levels are very poor, compared with my dual-core cube u30gt. Anyone has that problem too??).
- Some games (Gangstar vegas, for instance) are displayed as "not compatible with device". Can i edit build.prop to allow specific games to be installed?
- Netflix weirdness: ocasional hangups, missing sound, etc, occurs frequently. But i saw the same behaviour in my mini-PC Tronsmart T428 (maybe it´s a problem of RK3188 architeture).
Except for the issues above, i´m very satisfied with my tablet.
Sorry for my bad english and thanks for your efforts developing that custom rom!!
eminemmaick2
62
2013/10/12 - 15:15
This really working? Can anyone make an video with the root process?
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
63
2013/10/12 - 15:34
What rooting process , IT COMES PRE_ROOTED (it comes with a rooted firmware there is SuperSU and busybox already installed in the ROm) after you flash KASTY ROm there is no need to root anymore it is PRE-ROOTED.
tramin
64
2013/10/14 - 08:40
is already official Pipo update on 10/12/13.Will be the new custom ROM? Thanks!
Thanks Received: 3170
65
2013/10/14 - 08:45
It's in the works, custom firmware should be published today.
66
2013/10/14 - 16:32
I have posted 2 custom firmwares updates:
- first one is designed, I believe for the M9 pro 3G model :
http://www.arctablet.com/blog/forum/pipo-max-m9/rom-pipo-m9-pro-3g-model-custom-root-android-4-2-2-firmware-20131011-sms/
- I'm not sure about the compatibility with 3G and non 3G model for the second firmware, please check and let us know in this topic:
http://www.arctablet.com/blog/forum/pipo-max-m9/rom-pipo-m9-pro-custom-root-android-4-2-2-firmware-ota_1-0-0-20131010/
eminemmaick2
67
2013/10/16 - 20:21
But i don't know how to flash :/
tramin
68
2013/10/17 - 13:07
Sorry for off-topic,but is somewhere exact instructions on flash Pipo m9 pro with Android 4.2.2.Before I had a Cube and there it was probably different,thanks.
slackerlx
Forum Posts: 52
Thanks Received: 9
69
2013/10/17 - 14:18
Download Rockchip_Batch_Tool_v1.7 from the first page. Inside you have a doc in Chinese. You can either tanslate it or, as most of us do in this case, follow the pictures
http://www.arctablet.com/blog/featured/flashing-your-rockchip-rk3188-based-tablet-with-rockchip-batch-tool-v1-6/
tramin
70
2013/10/18 - 08:42
I'm sorry, but I thought it otherwise.I need to know if I have a tablet connected to a charger,which button do I press and in what order,etc.Or if it's exactly the same as the Cube U30 GT2.How to deal with Rockchip_Batch_Tool I know.thanks.
slackerlx
Forum Posts: 52
Thanks Received: 9
71
2013/10/18 - 12:50
Hold ESC button and press POWER lightly till you hear a chime on your PC
tramin
72
2013/10/18 - 14:21
OK and what with connection to a charger,USB debugging.Hold ESC and POWER before plugging the USB cord into the PC,or later?Thanks
P.S.I tried it once and it ended with dead tablet with an exclamation point in a Android.Therefore, so asking questions...
cracktech
Malaysia
Forum Posts: 432
73
2013/10/18 - 15:08
For Pipo M9Pro you Do NOT nEED to press any key combinations just plug the usb to connect beween the PC and device (make sure that the drivers are installed properly if not you can download the driver installer from here and the Rkbatch tool
https://docs.google.com/file/d/0BzXIan93EkgkVHBRSXc4X2ZVU2c/edit?usp=sharing
After using the RkDriver installer.exe file reboot PC and then switch off all your unecessary background application (anti virus/autodisk defragmenter, and switch off wifi if possible we dont want any downloads happening during the flashing) Attached the PC and Device and wait for all the drivers to install it might take upto 10minutes. Click on your PC task bar and see the pogress of the update until all the drivers have green ticks and not one is left out. Then youre good to go. No need to press any key combination just check that the RKbatch tool have a pink square then click switch and flash.
tramin
74
2013/10/18 - 17:58
cracktech It is interesting, everyone is doing differently,charger is needed,or is satisfactory fully charged battery?Thanks
slackerlx
Forum Posts: 52
Thanks Received: 9
75
2013/10/18 - 18:28
My upgrade tool (downloaded from here) doesn't see the tab unless the buttons are used
147 Guest(s)
Devices in use: Desktop (135), Phone (12)
jacklewis3
123456asd
valdes1964
pipo2015max
Vickyabc
massoud
