[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (2013/09/06)
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
46
2013/09/27 - 06:48
You meant you have resolved the WiFi issue? Good for you!!Laugh
Admin has told us our Custom version cannot do the OTA update do you have the downloaded files/directory somewhere stashed on your pad? If you have please distribute it around here.
I have just finishing updating my ZENITHINK C93 from And .4.1.2 to 4.3 via CM10.2 it is stable and god because the ROM cooker is onsite residing on the  Slatedroid forum (where I came from before) so any an all questions regarding CM10.2 he will be able to resolve it , pronto (it also signed by him). The GPS issue you can  resolved it by copying this file that I have with me all the time while since using another ZENITHINK Z102 4.0.4 an it is modified config. file that you put in the system/etc/ folder.. but you will have to modify it to North America settings.
So good to hear of your success! patience and perserverence because the device is ours and we are ultimately responsible for its upkeep and repairs.
slackerlx
slackerlx
Forum Posts: 52
Thanks Received: 9
47
2013/09/28 - 00:37
Thanks for the file, although I don't know how to change GPS settings.
But I rooted my factory firmware flashed tablet with RK31 rooting tools so I'll have no trouble accessing root folders
beppedomani
Forum Posts: 20
48
2013/09/28 - 16:25
please tell me how do root at FW stock without any other custom change
cracktech
Malaysia
Forum Posts: 432
49
2013/09/28 - 17:15
You can root it by using this script (DANs Root Script) : I successfully rooted my first out of the box Firmware with this.
Ensure that the RKdrivers are properly installed on your PC and if it is not, then use in there the PDANet software but I dont encourage you to do that. Enable the setting/administrator page adb debugging is ON and Do NOT (do not enable usb storage) attached your device in usb storage mode although it is a good sign that the PC and the device recognises each other.
Then run the script :that you can download here : run DAN.bat
link to download : https://docs.google.com/file/d/0BzXIan93EkgkYVlld3N3MXZiZ0k/edit?usp=sharing
beppedomani
slackerlx
Forum Posts: 52
Thanks Received: 9
50
2013/09/28 - 21:12
I use RK3188 Rooting tool. Very easy to use. Basically just one click and 3 reboots
Here is the link to it I uploaded to Mega: https://mega.co.nz/#!YIZGAIoa!F6rjrnnrdkxhZB6CmdnuXQL8JCtf9X9mChq3A46z8kU
slackerlx
Forum Posts: 52
Thanks Received: 9
51
2013/09/28 - 21:54
@cracktech
When I used unofficial firmware there wasn't Pipo family launcher and, of course, neither it was IncSpirit Logbook which happen to be VERY good journal programme.
I've attempted to find a decent replacement but nothing seems to be as good. Flava doesn't has chronological layout, Evernote and Springpad are not good for journal functions.
I, actually, had the Logbook backed up on SD Card, but when installed on Kasty's Rom Logbook, it demands a license.
Is there anywhere I can find this license within the official Rom #314 which I currently use?
Because I tried to contact oositech and my request has remained unanswered
Edit:
365Notes
The programme is an actual upgrade of my favorite IncSpirit Logbook. With huge BUUUUUUT.
It doesn't support resolutions higher than 800x480 which is stupidity nowadays.
Pity!
https://play.google.com/store/apps/details?id=com.oozic.note365.manage_en
Capture.JPGImage Enlarger
cracktech
Malaysia
Forum Posts: 432
52
2013/09/29 - 05:18
Here is the the ful PiPo expunged apps including launchsers and what else that make the launchers work including your LogBook apps there is instruction on how to install the apk and its "shadow" app (***.nm files)
downlaod links : https://docs.google.com/file/d/0BzXIan93EkgkQzUwQndrTnNxZVk/edit?usp=sharing
slackerlx, beppedomani, --k0l0kaust0--
beppedomani
Forum Posts: 20
53
2013/09/29 - 19:29
I downloaded the file but when i de-zip it there a problems... all file have 0kb dimension!
slackerlx
Forum Posts: 52
Thanks Received: 9
54
2013/09/29 - 19:47
beppedomani said
You need to redownload it.
I have downloaded the file and tested it. Works fine. Mist likely it's your browser's cache has gone awry. Clean the cash :)
Otherwise, I have also uploaded it into Dropbox: https://www.dropbox.com/s/p1rmms1ptixlfov/RK3188%20ROOT%20Tool.7z
and attached it here as well
The following users say thank you to slackerlx for this useful post:
beppedomani, Mr.BlueSky, --k0l0kaust0--
tirmey
55
2013/10/09 - 01:37
Hi everyone,
I bought recently my pipo m9 pro and notice a huge RAM usage (Around  1gb),  even with a few apps running or cached,  as you can see in attached pictures. The sum of  ram  used by individual apps are much smaller than 1gb! Have I overlooked something?  I don't know if that's normal or influenced by firmware ( that custom firmware installed).  My rk3066 Cube u30gt uses around 350 MB just after boot. Someone can explain what's going on?
Thanks in advance! Screenshot_2013-10-08-20-05-54.pngImage EnlargerScreenshot_2013-10-08-20-06-10.pngImage EnlargerScreenshot_2013-10-08-20-06-17.pngImage Enlarger
slackerlx
Forum Posts: 52
Thanks Received: 9
56
2013/10/09 - 10:03
Linux memory manager doesn't work like Windows. It works on virtual memory partitions as known as SWAP. SWAP, according to rules usually takes approximate 50 percent of given space and spreads things equally.
Pipo M9Pro has 2GB of ram therefore expect your ram to be swapped from 800 to 1000MB
tirmey
slackerlx
Forum Posts: 52
Thanks Received: 9
57
2013/10/09 - 19:02
@cracktech
Just wanted to notify that it doesn't work.
I risked trying and uninstalled family launcher. Used my backup and yours .nm file with negative results. Also tried installing all of your lancher files for no avail. Launcher manager doesn't give any choices when launcher button is pressed. Just goes straight to standard launcher. Therefore I had to reset to factory condition, effectively removing all my stuff.
futzmaster
Forum Posts: 37
Thanks Received: 4
58
2013/10/09 - 20:32
Just did the same yesterday and it worked: (just the launcher, don't need the other stuff)
copy nm files to destination
then i installed the apps: standartlauncher pipo family and manager
pressing home button and the choice to set the standart launcher is there
i also got the tip to use the app: Launcher Switcher -> works perfekt
Zeggi
59
2013/10/10 - 10:54
Is it only me or is the tablet never going to deep sleep?
Im checking wakelock detector and its awake 100% no matter what rom i tried its the same.
Meaning if you charge it to 100% and use it a few hours or minutes and the next day its dead 0%
Only way to save battery is to shutdown the tablet once your done.. annoying.
tirmey
60
2013/10/10 - 20:28
Thank you very much! I´m a Windows user and don´t knew how linux manage RAM memory.
Regards!
142 Guest(s)
Devices in use: Desktop (134), Phone (7), Tablet (1)
jacklewis3
123456asd
valdes1964
pipo2015max
Vickyabc
massoud
