[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (2013/09/06)
Titonine
Italy
31
2013/09/20 - 09:05
Hi there,
I have a Pipo Max M9 pro without 3G. I received it one week ago and it has original firmware. My tablet fails to receive gps signal and video calling in Skype crash. Wi-fi works very well with a great signal. Pipo assistance said me to update firmware but they were not so clear. Do you advise me to update to this firmware?
P.s. sorry for my English
tito2k
Forum Posts: 18
Thanks Received: 4
32
2013/09/20 - 11:20
If you don't Update before installing all applications, later it is more laborious.
GPS problem doesn't have solution updating firmware and skype problem I think that the same.
Then, I recommend you to update the firmware if you have already tested the tablet and all functions work well.
The following users say thank you to tito2k for this useful post:
Titonine
Titonine
Italy
33
2013/09/20 - 11:49
I tested the tablet and it works well for the rest. So, I will update to this firmware. Thank you. Wink
slackerlx
Forum Posts: 52
Thanks Received: 9
34
2013/09/21 - 04:33
I have 2 questions:
1.  I own Pipo M9 pro with high resolution and large Nand disc capacity.  For my daughter I bought Pipo M9 (regular) with 1280x800 resolution. I really like widgets on her tab and I know she has different firmware.
My question is: Will firmware from Pipo M9 work on pro model? Well it support the high resolution of pro model?
2. About GPS:
Here's a Video from Pipomall.com on GPS test, uploaded in July:
I wonder whether July 2013 firmware is better for GPS...
_________________________________________________________
Update on Skype=>
I've attempted to run Skype on different firmware (Pipo M9Pro), stock and custom alike and used different versions of Skype (2.8; 3.0, 4.0) and coming from oldest to newest Skype behaved annoyingly capriciously. I managed to make and hold calls with 2.8 and 3.0 but only after reboot. Reboot=>call=>call=fail=>reboot=>call
It's obviously the fault of  M9Pro model
Titonine
Italy
35
2013/09/25 - 15:24
After 3 days with this firmware I decided to install the original version cause WI-FI often disconnected and it doesn't longer works at last, display began to flicker. But I found the same problems with original version, WI-FI mysteriosly disconneceted. I'll go with previous rooted firmware http://www.arctablet.com/blog/forum/pipo-max-m9/pipo-m9-pro-custom-root-android-4-2-2-firmware-20130822/
The original firmware M9 pro_NO3G_20130822.img was installed when I received my tablet and WI-FI works fine.
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
36
2013/09/25 - 16:19
I started off on a build #270 NO-3G out of the box and I am now on build #314 without any problems what soever but the first time updating from #311 to #314(with OTA)  I even called the admin to stop anybody else form installing the firmware on their NO-3G pad because my pad became erratic and its so screwy that I thought I lost it.
But then I redownload the firmware again from this site and REFLASH for a second time and all is well and we announced that the firmware is good to go. Why dont you reflash it after redownloading it the second time and see. I have a great time with wifi it is pulling in signals from around the neighbourhood upto 200feet away I can see their signals. and there are no more screwy antics like keypad not responding the, screen is not responsive.
The firmware is "Good to GO". Sometimes it doesnt erase all the nand memory clean like my installation it has stragglers apps that seeems to have been left behind from the previous install, there were already installed when i first booted up but they are working fine but just in case i decided to uninstall and reinstall them.
Except for the OTA nagging screen (which you should answer NO to update and then go into the build.prop and dissable that statement later)   DO NOT DO an OTA update at this point in time.
Give it a try like somebody advised me on another thread. Do it step by step and have patience with the process.
Titonine
Italy
37
2013/09/25 - 16:38
I'm really frustrated. I installed the older rooted version and I have the same problems with Wi-FI... Is there a procedure to be sure all data is erased?
cracktech
Malaysia
Forum Posts: 432
38
2013/09/25 - 17:01
Try to do a factory reset (in settings) then if all else fails i think you have a hardware problem return it to supplier before your warranty is up. Thats all that I can do from half way around the world from you. I seldom hear it happening with other pads using KASTY ROMs it is not his software then it must be hardware. There are flickering issues reported on other ROMs (with TWRP/CWM) but not here.
cracktech
Malaysia
Forum Posts: 432
39
2013/09/25 - 17:09
Titonine ,
Give me a few minutes max 30 mins then I will provide you you with another custome ROm with its own flashing tool (dont use the standard RKBatch Tool) for you to try it out but if this time it still fails then you would have a hardware problem for sure. just make sure you have the the M9Pro models not the M9.
Titonine
Italy
40
2013/09/25 - 17:12
Ok, thank you very much. I have Pipo Max M9 Pro 32Gb.
cracktech
Malaysia
Forum Posts: 432
41
2013/09/25 - 17:39
Here you can try this ROM nad it is closely related to KASTY ROM (they work with the same team).
All the firmware and Tools are included in this zip file (dont use any other tools from another ROM with this ROM) Please read the instructions file carefully for you to understand the process (it is slightly different from the standard flashing procedure.
If this doesnt help your wifi problem send the pad back (with the factory ROM installed) and get a replacement pad it is a hardware problem although it can be solved (hardware) but it is till under warranty isnt it?
the link :to the rom and included tools (RILEY ROM)wifi only :  https://docs.google.com/file/d/0BzXIan93EkgkbEphUlVyaTJoWG8/edit?usp=sharing
Titonine
Italy
42
2013/09/25 - 19:08
Thanks for your time! Yes, I bought Pipo two weeks ago and it's under warranty.
Please note that WI-FI worked fine with original firmware. As written a few posts ago I updated firmware to solve GPS problem. After few updates, GPS does not work in any way and now I have WI-FI problem too.
If your ROM will not solve WI-FI problem, how can I reinstall original ROM? Can I flash firmware in standard mode with last Pipo update?
P.s. sorry for my English!
cracktech
Malaysia
Forum Posts: 432
43
2013/09/25 - 19:35
Go to PiPo.com, and download the latest firmware and tell the shop that after the update things got screwy with your pad and ask them to check the thing the most important thing is that it must NOT have the SuperSU apps on ypur pad they'll know that you have rooted the pad so even though the versions are the same but on the company's download sites it is all stock firmware NO removed this and that and no SuperSU installed. then take it back to the shop and say that it has gone screwy after the update.
It is OK to update the ROM firmware. It is sanctioned by the factory for us customers to do that (only their factory firmware)
For KASTY ROm it is teh standard RK Batch Tool v1.7 for any other Custom ROM you will have to use the included tools. Your question is that if you use the custom ROm and its non standard tools  will you be able to flash back using the the standard RKBatch Tool using standard /near standard firmware like KASTY ROm?? Yes you can as long as the pad/deviice is recognisable on your PC (which it should be).
Then using the standard/factory KASTY Rom with the standard RkBatch tool is a must!
For other ROMs they will put in their own Tools and you have to use them with THAT ROM only.
AS long as your pad is not bricked whether you want to use factory/KASTY ROM or any other custom ROM it your choice  to move back and forth between the ROM and their flashing methods.
You make up your mind and do the be patient with the update process like my updates that I thought had gone horribly wrong in the end it was a corrupted zip file download that causes my problem or else how would I be on the #314 build ROM right now. Please check and shutdown your antivirus software, anti malware and shutdown your PC/s wifi during the installation and stop any other background applications that you dont need except Windows services when during this flashing process. They might interfere.
cracktech
Malaysia
Forum Posts: 432
44
2013/09/25 - 21:37
The actual download site is this link , if you go to PiPo.com it will only show you their commercial pages.
A last note to remember BEFORE FLASHING under the DEVELOPER OPTIONs switck OFF,OFF,OFF the USB Debugging.
the download lsite links : http://www.pipo.cn/En/index.php?m=About&a=gujian
slackerlx
Forum Posts: 52
Thanks Received: 9
45
2013/09/27 - 02:26
I've upgraded to build #314 (factory Rom) and updated with OTA patch (From System Updates) and noticed a significant performance jump.
System is verrrrry smooth and fast.
Although..
GPS issue has not been addressed. The signal is still very weak and the satellites are lost easily.
Skype still horribly capricious and flaky.
http://www.evernote.com/shard/s318/sh/52bb2862-3543-4275-80c7-9de6d59ea690/0cac40b341fef0cfb086ede0b9fb6e69
139 Guest(s)
Devices in use: Desktop (129), Phone (10)
jacklewis3
123456asd
valdes1964
pipo2015max
Vickyabc
massoud
