[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (2013/09/06)
Merzthik
2013/09/12 - 17:48
Hi .
i tested this rom and Skype calls doesn't work, when i call a friend the aplication crash and doesn't work anymore.
Anyone had the same problem??
Thanks..
Merzthik
slimbox
2013/09/13 - 14:49
Hi Im new here nice ppl online i like how ppl share there knowlege !
Anyways Great work Admin!!!, looking forward on installing this fw on my newly orderd device on monday.
And will try to contribute from my end if i can to the guys on - the - line :)
I still have 2 questions.
Anyways of installing CWM http://www.clockworkmod.com/rommanager as recovery loader ? Did anyone did this and how ?
Also is there a way to backup the stock recoveryloader or has anyone got the stock one sothat when it comes to warranty i can flash it back ( i hope i never get there but you never know, had this issue with Samsung S4 and lucky was able to flash it all back to stock. even flash counter reset.)
Cheers
Thanks Received: 3170
2013/09/13 - 14:59
You can always reflash the stock firmware from the manufacturer (see pipo.cn) if you want to restore your tablet to original state for warranty, there is no flash counter on Rockchip based devices.
I am working on a procedure to make an easy CWM Recovery installation, I will post about it when it's working well enough or I need testers.
slimbox, kumnamutata, griff2
kumnamutata
2013/09/13 - 20:20
It will be fantastic if CWM flashing is available.
Looking forward to hearing of your post.
slackerlx
Forum Posts: 52
Thanks Received: 9
2013/09/14 - 14:08
Hi .   i tested this rom and Skype calls doesn't work, when i call a friend the aplication crash and doesn't work anymore.   Anyone had the same problem??    Thanks..   Merzthik
Yes, I concur.
I removed this firmware and restored the stock (not rooted) from Pipo website (M9pro_EN_NO3G_update_20130906.img). Don't care whether it's rooted or not as long as it doesn't glitch.
Now the Skype works fine BUT still flaky.. However unlikely, I suppose, it might also be the Skype's bug.
I've also noticed that having different camera programmes affects Skype performance on Pipo M9pro. Don't know how it's connected but it just does. You could also disable HD video for Skype and see how it goes.
Arrived84
2013/09/14 - 14:41
I also use this rom but after I run the AnTuTu test it says that a Samsung Exynos 4412 has set as CPU in stead of RK3188.
Is this normal?
Zeggi
2013/09/16 - 21:29
Is this normal?
I just got my tablet and it was stock with previous version and it also said Samsung Exynos 4412, so you shouldnt be worried.
slimbox
2013/09/17 - 10:23
Hi guys quick one, i successfully flashed my pipo m9 pro but crap i lost 1 hour with windows 8 had issues with the drivers but then i said ( F*ck off ) installed it via windows 7 and flashed it their in like less then 5 min or so
anyways everything is working fine ( skype also ) but my WIFI drops out from time to time even if i had my router configed without wep or wpa ... ( open wifi )
Anyone has the same issue ? any ideas what i can do to solve ?
Cheers
Antutu : 18554 :) GOOD ROM !
tito2k
Forum Posts: 18
Thanks Received: 4
2013/09/17 - 11:00
I have the same problem. Pipo Wifi crashes the wifi-router sometimes. When It happens, I can't connect to internet with the mobile phone neither.
If I wait or I turn off the wifi on the tablet and I turn on again it works other time.
I use a THOMSON TCW710 router. I think that this has problems with others devices and has wifi conflicts sometimes.
But the most important problem on this tablet is that GPS is DIED.
slackerlx
Forum Posts: 52
Thanks Received: 9
2013/09/18 - 03:10
With GPS testing I normally see that GPS device is turned on but it fails to find any satellites.
No troubles with Wi-Fi on D-Link router
And yes, I agree 20130906 Rom seems to be the fastest and the least bugged
Antutu score also seems to beat the odds B-)
https://www.evernote.com/shard/s318/sh/886b6f7a-0213-4df9-bfc4-3b759fc817c6/bbaf07288e84c98a3405b15d8e679688
beppedomani
Forum Posts: 20
2013/09/18 - 11:10
Is this normal?
Pipo say not use antutu but much better http://pan.baidu.com/share/link?shareid=3316304164&uk=1528899468
Someone used it?
Zeggi
2013/09/18 - 11:20
https://play.google.com/store/apps/details?id=com.cpuid.cpu_zbeppedomani said
Is this normal?
Someone used it?
its cpu-z nothing dangerous. I use it for my computer.
slackerlx
Forum Posts: 52
Thanks Received: 9
2013/09/18 - 11:22
beppedomani said
Is this normal?
Someone used it?
It's not the same. CPU_Z is a  CPU identification tool while Antutu is a system performance benchmark.
I don't use Antutu for CPU/Device ID purposes but this one:
https://play.google.com/store/apps/details?id=com.Bfield.CpuIdentifier
The following users say thank you to slackerlx for this useful post:
beppedomani
2013/09/18 - 16:08
wacommike
2013/09/18 - 22:30
Hello kasty!
I've successfully installed/restored my fresh Pipo M9 Pro tablet to this version (09/06). Thanks! (Install was a little messy because the first tutorial I found says: Turn off the tablet, and press ESC and reset... there's no need to turn off.)
So far just 2 weird problem. After  1st boot, first login to Google Play there was a freeze, so I need to reset.
2nd boot I entered to Google Play again, but this time without problem, so I installed a lot (30+) applications. When I tried to swipe down the notification panel it ended in a fast soft reboot.
eM
156 Guest(s)
Devices in use: Desktop (147), Phone (8), Tablet (1)
jacklewis3
123456asd
valdes1964
pipo2015max
Vickyabc
massoud
