[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2014/05/04)
Pipo_Bibi
121
2015/03/18 - 20:58
I'm glad to announce you that I flashed it and everything is ok. I just had a problem about updating Super SU, I pushed on "normal" because I don't have TRPW (I think I don't have) and it was solved.
Before I had rom rk30sdk-eng 4.2.2 jdq39 eng.root.20131209.100724 test-keys with wifi problems to download applications from Play store.
Pipo m9 pro
rom rk3188:4.4.2/KOT49H/eng.root.20140504.171845:eng/opinions-on-teclast-p90hdst-keys
netpower8
122
2015/04/21 - 02:52
Is there another link? Im having problems downloading this rom. I always get a broken file cant complete the download. When i retry again it will start from the beginning again. Is there another link? Where there is support for resume download function? Or links in dropbox? Box? 4shared? Megadownload?
danielp
123
2015/09/08 - 13:05
I too am having issues trying to download this link.. it seems that after about 1MB it fails to download..
can someone please provide an alternative download for this?
Thanks Received: 3171
124
2015/09/08 - 15:36
We are aware of the problems downloading files, our web server configuration is being modified so the early download stop does not happen anymore. We'll post and it's working reliably again.
125
2015/09/10 - 00:59
Hello danielp, netpower8,
It took us a while to find and fix the problem. I have posted some details about the downloads issue here.
It should be fixed now, you may retry your download.
danielp
126
2015/09/10 - 02:45
Thanks for the update, has this this ROM fixed the WIFI issues that seem to plague this device.
While I was waiting, I installed the RileyRom, didn't seem to fix the WIFI... connects for a while then after a while data stops coming through, however it seems that it's still connected to the WIFI... just no data getting through.. This really sucks...
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
127
2015/09/12 - 23:46
Danielp,
I used the M9Pro since JellyBean version (thats about 23 months ago, I think) with all the original bugs and I have flashed Rileys ROM when he first started I dont like it but now I am using Archtablets ROM the final version (there are no more updates after this and dont expect Admin to port a Lollipop ROM, because it will be buggy as with any ported ROM). So far users have only complaints both on Rileys and Archtablets ROM are the GPS signals only never come across anybody complaining about WiFi.My M9Pro WiFi is very reliable with steady signal and also my GPS, they are related. You should flash this Archtablets ROM(and please use the correct length micro USB connector). If you still faced the WiFi problems reboot/shutdown a few times for afew days (sometimes it needs to stabilised for a few days) but if you still faced the same WiFi issues then check hardware at any good repair shop.
I have an ONDA V975m which has a WiFi problem but I propped it up using apps from Playstore (4 apps on WiFi improvements on the same ONDA!) "KeepWifi On", "Auto Start Wifi", ect, ect. This ONDA doesnt loose WiFi signal but "internet connection" is lost in the middle of doing somethings.
drjos
128
2015/12/06 - 19:29
Is there a how-to install instruction for rom  kasty pipo m9 pro 442-20140504-rooted7_mu.zip ?
Now I have a Rileyrom   rk30sdk-eng.root.20131120.141257   with kernel 3.0.36+    but its very slow and old.
WoW06
129
2016/01/22 - 20:24
I just want to say you thanks, because i use this rom for my pipo tablet and all works like a charm. 🙂
maschi
Rastatt / Germany
130
2016/04/17 - 16:37
I also say thanks a lot - the tablet is really fast now (starting Dolphin-Browser before takes 30 sec, 1 sec now 🙂 )
But when i start the tablet now it always comes up with "modem power" on (3G), no matter if 3G was on or off at shutdown.
(I'd like to save battery.)
uli-hh
Forum Posts: 31
Thanks Received: 8
131
2016/04/17 - 16:51
I always switch "Modem Power" off and activate "Airplane Mode" to save battery.
WIFI can be reactivated after that separately.
maschi
Rastatt / Germany
132
2016/04/18 - 17:57
Ok thanks, I didn't know that. But the "modem power"-checkbox still turns on, although in flight-mode.
(I use the direct-link-to-the-mobile-settings-widget: https://play.google.com/store/apps/details?id=com.curvefish.widgets.network2g3gonoff )
Another thing that doesn't work any more is the percentage of consumed battery in "GSam Battery Monitor":
https://play.google.com/store/apps/details?id=com.gsamlabs.bbm - the bars are ok but the percentage ist displayed as 0% for all apps.
uli-hh
Forum Posts: 31
Thanks Received: 8
133
2016/04/18 - 18:22
Unfortunately you have to repeat the procedure after each rebootConfused
maschi
Rastatt / Germany
134
2016/04/18 - 21:43
Is it a "feature" of Android 4.4.2 - or a bug in the ROM? I also tried to replace the  libril-rk29-dataonly.so with a stock-version, but: No effect (they are binary identical 😉 ) (http://freaktab.com/forum/tablet-support-android/pipo-tablets/archived-pipo-roms/11804-pipo-m9-pro-rileyrom-2-6-kitkat?p=247814#post247814).
cracktech
Malaysia
Forum Posts: 432
135
2016/04/19 - 16:01
There are no bugs in 4.4.2 Kasty ROM as far as WiFi is concern. Like I said I used this tab for over 2 years (nearly 3 years since JellyBean version) as far as WiFi is concern it has no problems at all. But I did faced a Jammed WiFi once when I reflash after a serious corruption of my M9Pro (way back 2 years ago) , I did another  reflash and the problems is gone after a second reflash. It can get get slight corruptions (BlueTooth, Ethernet, WiFi, Touchscreen) sometimes during a flashing process.
But now this tablet has gone into my collection and used it only occasionally as I am more into Lenovo phone/phablets/tablets now.You can try reflashing the tablet again (these are just ordinary electonic gizmos nothing to be afraid off, it will not bite you if you reflash again. Only some spare time)
I even change my Recovery from CWM to TWRP  without any problems and add my own mods to Kasty ROM.
55 Guest(s)
Devices in use: Desktop (52), Phone (3)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
