[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2014/05/04)
Piperos
Forum Posts: 13
106
2014/09/17 - 15:52
BliND123 said
Having trouble with the wifi, what do I do?  Everything else seems fine, just wifi doesn't seem stable.
Edit:  Well, found a hardware fix for the wifi on another forum and gave that a shot as I was reading that there is a specific way to downgrade that I couldn't find it.  So did the hardware fix and so far so good, stronger signal than before too.  I'm also now finding out KitKat doesn't have GPS?  I didn't know and hadn't noticed, next update will have it?
I've a lot of WiFi issues too, can you please link me the fix you are using?
Thanks very much!
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
107
2014/09/26 - 07:34
is there an overclocked kernel for this unit?
Pipo M8pro
Pipo M9pro
Pipo P4
BliND123
108
2014/11/17 - 23:02
Thanks very much!
Hope you know how to solder, http://www.freaktab.com/showthread.php?8568-Pipo-M9-Pro-wifi-antenna-modification-instructions and I would use a real guitar pick to open it as it doesn't leave scratches like the cheap "picks" that come with like phone repair kits.  It's still working great months later, still strong signal and not dropping anymore.
c_shekhar
Forum Posts: 12
109
2014/11/19 - 15:39
[Image Can Not Be Found]admin said
Here is latest Android 4.4.2 KitKat rooted firmware for the PiPO M9 PRO (aka Max-M9pro) tablet based on an update from PiPO dated 2014/05/04.
The fake Linux 3.4.0 version display from previous firmwares has apparently been removed as the Kernel is listed again as 3.0.36.
(PiPO M9pro_update_andriod4.4_20140504.img)
Build information:
Linux Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #407 SMP PREEMPT Sun May 4 11:18:12 CST 2014
Android 4.4.2: rockchip/rk3188/rk3188:4.4.2/KOT49H/eng.root.20140504.171845:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU version 1.94 (free version)
  • increased space for applications (/data partition) to 7 GB
  • added Google Experience Launcher (GEL) in addition to PiPO's stock launcher
  • temporary fix for multi-user support, thanks to didierm
 Notes:
- you should get an error saying "E:failed to mount /metadata (Invalid argument)" on first boot, you should have no problem ignoring the message.
- while previous firmwares for the PiPO M9 pro were mosly beta software, it seems this release is one of the first stable KitKat update for the tablet.
Download: kasty-pipo-m9_pro-442-20140504-rooted7_mu.zip
If you like our work, please support us to keep the site alive and contribute to our efforts.
This firmware was successfully flashed on a PiPO M9 Pro but hasn't been extensively tested yet, please report any problem.
If you later want to downgrade and flash an Android 4.2 (or older) firmware, please follow this tutorial.
Thanks sclstore.fr for their support.
Cannot flash this ROM on my M9Pro3G again.
Earlier I had flashed kasty-pipo-m9_pro-442-20140504-rooted7_mu ROM on my tablet. I want to flash it again as I corrupted the system files.
1. I connect the device to USB.
2. Run the RKBatchTool.exe (v1.7)
3. Select the kasty 422 ROM.
4. Bring the device to recovery mode.
5. button turns green saying 3-1-1
6. press Restore button
But getting error <layer 3-1-1> test device fail. see image
Image Enlarger
Image Enlarger
.........Please Help
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
110
2014/11/21 - 21:38
You said you somehow corrupted the Systems file, that is the hint to your problems . You some how have to format the system through using other RK flashing Tool try (tools from Freaktab Forum). Reinstall back ALL your Rockchip drivers. and try to flash the ROM again, you can also redownload the ROM one more time (maybe your have a corrupt "update.img" file since it is a big contiguos 400MB file and anything can happen, you dont use dial up ,must use high speed broarband. I had that problem once before I started shouted for help. I redownload and then everything went fine.
Dont use factory ROM ! their downlod speed will take ages and is prone to terminate halfway. I have uploaded drivers for you to reinstall. Apart from that I dont know what else to say, start by formatting the system partition first by using other Rockchip Tools (from FreaktabForum)
c_shekhar
Forum Posts: 12
111
2014/11/23 - 18:27
Thanks a lot bro. Let me try and I get back here...
c_shekhar
Forum Posts: 12
112
2014/11/25 - 14:06
@cracktech
Thanks a lot. My problem is solved. Actually it was driver problem. I did following:-
1. Using usbdeview-x64 I uninstalled all the devices concerning my Tablet.
2. Using Universal-USB-Installer-1.9.5.3.exe I installed the drivers.
3. Then I Run RKBatchToolv1.7-with-x64 and the ROM was flashed without any problem.
My gratitude......
The following users say thank you to c_shekhar for this useful post:
Welcome
cracktech
Malaysia
Forum Posts: 432
113
2014/11/26 - 20:29
Click thanks for me.
c_shekhar
dalton72
114
2014/12/17 - 22:10
Hello @cracktech,
Is it possible to instal DRM WIDEVINE in this tablet?
I can not see the application of TV "Yomvi" of Spain.
Is there any approximate date to have a new ROM?
Thanks.
cracktech
Malaysia
Forum Posts: 432
115
2014/12/19 - 20:15
I can install the YOMVI app even in Malaysia (where I am right now) and can assure you that DRM drivers are present in our M9Pro ROM. The only thing I cant test out is the video playing ok or not because I dont have an account with YOMVI. Maybe you have to enable the DRM line in the build.prop (it is enabled in ALL my build.prop version from phones to tablets). If you want my build.prop file I can give you with DRM enabled better net buffer sizes for Wifi/GPRS/ as I dont use the normal build.prop files given by any factory ROMs/Customs ROM.
Changelog :
Added in build.prop increase net.buffer sizes/power saving/Google signatures for market accessibility/drm enabled/data&mobile enabled/mild performance tweak/network location enabled
Added more permissions and additional tablet core permissions includes gsm enable/wifi enable. Sound effect
Corrected/Updated to SuperSU2.40 with correct daemon/init.d/ ota survival script (can only be seen when using SuperSU Pro)
This file DO NOT unzip it, just INSTALL the zip through CWM/TWRP. For anybody who wants to use ths zip after INSTALLing zip do a dalvik-cache/cache wipe before REBOOT to SYSTEM.
dalton72
116
2014/12/20 - 10:16
Thanks, I 'll try and I 'll tell you if it has worked .
dalton72
117
2014/12/20 - 11:18
I installed the zip but I have not gotten results .
With DRM Info app I get the following:
"Available engines:
OMA V1 Forward Lock"
On my mobile Lenovo A806 if I can see Yomvi TV, and with the app DRM Info I get the following:
"Available engines:
Widevine DRM plug-in
OMA V1 dcf"
From what I can ascertain the problem is the absence of Widevine DRM plug-in in this tablet.
Is there a solution? Thanks.
cracktech
Malaysia
Forum Posts: 432
118
2014/12/20 - 19:21
Give me time time to check on my other LENOVO ROMs and compare that to whats is available on the PIPo ROM , I have got 20-30 Lenovo ROMs modded but too bad this part of the world we dont have subscription Mobile Subscription TV only free Internet Tv which is free we can get National Geographic based channels/ Fashion TV/our own country made for internet based channels on LENOVO/PiPO/ASUS/ZENITHINK /and almost all brands without the DRM issues cropping up. So like I said previous I dont know if it works or not since I am not a subscriber of YOMVi so now, we know! I will have to check with my LENOVO S939 /A880/A889 which is in my hand right now. and compare that DRM drivers issues amongst the 20-30 other LENOVO ROMs against PiPo firmware but it is not my priority. Just doing a favor.
dalton72, grayling
Welcome
119
2015/03/03 - 16:53
Yesterday I successfully installed this firmware and it works great. Thanks!
I found two tips that helped me greatly, and I hope that these might help others:
(1) I had to trim the plastic on the end of the USB connector to expose about 7.5mm of the connector in order to achieve a positive and consistent connection to the Pipo M9 Pro tablet.
(2) I had to follow this procedure to use the Rockchip Batch Tool v1.7:
a. Start with PC running the Rockchip Batch Tool v1.7, and the Pipo M9 Pro tablet OFF with USB not connected.
b. Connect the USB cable between the PC and the tablet.
c. While pressing and holding the ESC key, press the power button for about 4 seconds. My PC made the sound for the USB connection and the Pipo tablet started. I released both keys. The PC searched for and installed the driver.
d. The Rockchip Batch Tool v1.7 gave the GREEN indicator, and I was able to easily use RESTORE to install the new firmware.
Your mileage may vary. :)
cracktech
Malaysia
Forum Posts: 432
120
2015/03/04 - 15:02
Like they all say! Back to basic! It is the most basic thing in flashing this PiPo, the micro USB connectors like (all old timers here knows) that is a known issue.
208 Guest(s)
Devices in use: Desktop (194), Phone (14)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
