[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2014/05/04)
Viklander
91
2014/07/22 - 23:32
Hi
I cannot succeed getting the tablet recognized
the driver was loaded all right, I can launch RBT, I can read the firmware file, but when I come to <restore> I have the 'no device' pop up.
I have tried to select the USB debug mode, and the peripheral mode as well but no luck
What do I do wrong ???
TIA
Christophe
EDHUNTER
Forum Posts: 22
92
2014/07/22 - 23:46
Viklander said
Hi
TIA
Christophe
If your device has not been recognized on the pc, installed all drivers of your device, open rkb toll and see if the icon is green, if green, follow the steps ... open toll rkb --- swich ---- select ----- restore the firmware
if you have no luck try holding the power button on the device for a few seconds with aperelho connected to pc and open rkb toll, if it is green repeat the above process,
Viklander
93
2014/07/22 - 23:54
Hi Ed
no, the problem is not (yet ?) the rom, but the fact that the tablet is not recognized by Rockchip.
As I said, the firmware file is loaded by Rockchip, but no device button goes green when I connect the M9
And when I click restore, Rockchip logically complaind about the fact that no device is connected.
Could it be a magic sequence of keys to use on the tablet, or ... ???
EDHUNTER
Forum Posts: 22
94
2014/07/23 - 00:13
Viklander said
Hi Ed
sorry my bad english, google translator'''' hahaha, did your problem, try to install all the drivers for your machine before and repeat the above process
Viklander
95
2014/07/23 - 00:16
I installed the drivers, and I can see they are there in the device manager.
However, the tablet is recognized by the PC (I can read/write files from the PC when I select the appropriate mode)
EDHUNTER
Forum Posts: 22
96
2014/07/23 - 00:22
what version of windows you are using? try updating the drivers of your device with the tutorial post below http://www.arctablet.com/blog/forum/firmware-development/rockchip-released-an-easy-driver-installer/
Viklander
97
2014/07/23 - 00:55
I'm using Win Seven x64, and installed drivers with the tool you mention.
One thing : if I power up the tablet while depressing both pwr and esc, I have a different device that appears in the windows devices manager : is this relevant ?
EDHUNTER
Forum Posts: 22
98
2014/07/23 - 01:08
driver usb debugging is installed automatically when the device connects to the PC with enabled debug mode, it is nescessário toll rkb to recognize your device so you can flash a rom
barsy
99
2014/07/24 - 13:31
     Hello everyone. Install Android 4.4.2 pro Pipo M9 root KitKat custom firmware (2014/05/04) on my tablet,        will comment the erroes, not if it happens to others but here we go
   1 - using the balance ball game 3d sensor malfunctions, the original home firmwarez goes well, I try to see     what I mean
  2 - I restarted the tablet quite often
  3 - I turned off the row from interner be enjoined after a while of using the consequent need to disable and enable wifi to get me going but not always linia
  -------- Upgrades
  1 - reinstate the multiple windows that came in android 4.2.2 but with additional features which brings PIPO P1 tablet with resizable windows and bar laterar
  2 - Remove the limit of 32gb reading 128gb microsd card as a minimum
  Grace, please please please fix these probremas. thanks in advance for the good work.
   I hope that soon you will also be able to upgrade to android l
 Confused
teretzis
100
2014/07/24 - 16:31
I have been using this ROM since 5/27. I had only 2 restarts firmware is very stable and good thanks
c_shekhar
Forum Posts: 12
101
2014/07/25 - 05:22
Follow this procedure:-
1. Connect the tablet to PC through USB port (whichever mode)
2. Launch the rockchip RKBatchTool. the colour may be pink or no-colour. don't worry.
3. Now press power+Escape button (two buttons together) for few seconds. The display of the tablet goes off.
4. Release the two buttons for one second and again press the two buttons together for few seconds.
5. The colour turns green in connected in RKBatchtool. Now select the firmware and flash by pressing upgrade or restore button as suggested by the developer.
..cheers
The following users say thank you to c_shekhar for this useful post:
papamopps, Welcome
mattiesrag
Forum Posts: 39
Thanks Received: 5
102
2014/07/26 - 12:47
Here is latest Android 4.4.2 KitKat rooted firmware for the PiPO M9 PRO (aka Max-M9pro) tablet based on an update from PiPO dated 2014/05/04.
The fake Linux 3.4.0 version display from previous firmwares has apparently been removed as the Kernel is listed again as 3.0.36.
(PiPO M9pro_update_andriod4.4_20140504.img)
Hi Admin & all interested parties,
Sent a message to Anna via facebook. Quoted below is my question & her reply.
Hi Anna, I have both the M9 & M8 Pro 3G, and I would like to know if you will still be supporting these models with future firmware upgrades. It really would be great to have a "stable" firmware ie 4.4.4 as what we have at present (4.4.2) is far from stable. Looking forward to your response.
Anna Ye Our technicians are working on RK3288 device at the moment, I am not sure we will have newer 4.4 firmware for that or not.
In light of her answer it looks like support has been terminated. How possible would it be to "port" a 4.4.4 firmware from another device for use on Pipo M9 Pro.
Regards
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
103
2014/07/28 - 02:51
I have a device with Android 4.4.4 and the only difference I can see to the 4.4.4 is the version number. As for stability any version of Android that is not stable will remain not stable until the factory "stabilised" it, so in our case we have a KitKat firmware which I think is 98% stabilised already and there is no point in  pushing the factory for a 4.4.4 version since there is little difference between 4.4.2 and 4.4.4 except the other one being the "latest" version and with our experience with newer firmware especially from Chinese manufacturers the first few release will be a heartbreak for users.
Lets just wait and buy a good RK3288 device from this brand or another brand.
BliND123
104
2014/08/06 - 03:44
Having trouble with the wifi, what do I do?  Everything else seems fine, just wifi doesn't seem stable.
Edit:  Well, found a hardware fix for the wifi on another forum and gave that a shot as I was reading that there is a specific way to downgrade that I couldn't find it.  So did the hardware fix and so far so good, stronger signal than before too.  I'm also now finding out KitKat doesn't have GPS?  I didn't know and hadn't noticed, next update will have it?
papamopps
105
2014/08/09 - 20:05
cracktech said
To trellogavros (or whatever)
First you must edit this line in your build.prop file (/system/buiild.prop) first copy the file out to sdcard anywhere would do then editing on the copied build.prop because I think it will not successfully edit the file build.prop "in-situ" after (due to some rooting problems on our firmware)finishing the editing only then you copy it back to the original location and you MUST SET THE PERMISSION and OWNERSHIP RIGHT (permission rw-r-r / ownership root:root) or your device would not boot up!! CAREFUL!!.
FIND and EDIT these lines
ro.com.android.dataroaming=true ( change to = false)
ril.function.dataonly=1          (change to =0)
wifi.supplicant_scan_interval=180 (change to 360 double the delay in scanning rate for wifi )
then ADD these lines to the build.prop (if you are upto it)
hw.nophone=true
hw.hasdata=false ( careful if later you want to use a 3/4G dongle you have to change this to= true)
persist.backgrounddata.enable=false
pm.sleep_mode=1
ro.ril.disable.power.collapse=0
ro.config.hw_fast_dormancy=1  (CORRECTED /edited)
ro.config.hw_quickpoweron=true
Test to see the battery consumption IF you are still not satisfied then do this next thing;
Go into /system/priv-app/  rename the Telephone.apk to (.Telephone.apk) put a dot in front the name and TelephoneProvider.apk also. Android will ignore any file with a dot "." in front of its name.
Since this is your main concern to want to disable modem/opinions-on-teclast-p90hdlephone ( I have the same model as yours without 3G but my battery last about 4 days in sleep mode only with the build.prop lines, I dont disable the Telephone services apps because sometimes I need to use them.
Just tried these on my fathers tablet...
after rebooting I still have to disable 3G-Modempower. ist that RIGHT??
And on Power usage still "Mobile standby" is listed?
Did I miss something or is it right like this.
By the way ...after runnig 24h still have 70% Batttery. My Pipom8pro §g only reaches 24h with luck and 0% battery left :D
May be i should charge und Start Wirth New Batterie Staats... :)
82 Guest(s)
Devices in use: Desktop (72), Phone (10)
DAK78
wheaten156
luislx
algua
Twotrains
alexanddercrb
