[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2014/05/04)
trellosgavros
Forum Posts: 11
76
2014/06/27 - 12:41
bouz said
Hello, I've tried this FW on 2 PiPO Max-M9 Pro 3G, and the both don't work anymore : the flashlight of the camera stay alway brighting and the screen stay black, but with backlight.
When I try to go back to old FW, same problem...
Anyone know what I can do ?
Yep ! You updated an M9 Max with the M9 Pro Firmware. I have done this before and had exactly the same behaviour. The good news is that you can revert. Download the M9 Max firmware from http://www.arctablet.com/blog/forum/pipo-max-m9/rom-pipo-m9-android-4-4-2-kitkat-custom-root-firmware-20140604/ and the official Batch Tool 1.7 from the PIPO Site. Run the tool, select the M9 firmware and the tool will erase the IDB and overwrite the bad one. That's what I did...
The following users say thank you to trellosgavros for this useful post:
bouz
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
77
2014/06/27 - 13:40
Yep! sounds about right. You have just flash the wrong firmware on your device! It is either you flashed the M9 firmware on  M9Pro device or an M9Pro firmware on a M9 device. Please check for god sakes and watch what you are doing! We are lucky that we can still recover an RK3188 device it is a bit rugged and can be reflashed. Some device if you do this you will end up with a heavy /expensive paper weight.
bouz
78
2014/06/27 - 13:49
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);
b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};
O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};
O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=
new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};
O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};
N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();
pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=5fa4feb7c3&post=43857&forumid=157','5Czn0lsVdP',false,'ljK0Ihy0VvA');
Thanxs, it works :)
trellosgavros
Forum Posts: 11
79
2014/07/02 - 07:42
Glad for it !!
EDHUNTER
Forum Posts: 22
80
2014/07/07 - 02:25
This firmware works for the M9 Pro 3G model?
Maniac1979
Germany
81
2014/07/07 - 02:41
The following users say thank you to Maniac1979 for this useful post:
EDHUNTER
Tablet:
Pipo M9 Pro 3G
Archos 101 G9 Turbo + Archos G9 3G Stick
EDHUNTER
Forum Posts: 22
82
2014/07/07 - 02:59
I recently installed the ORIGINAL FIRMWARE 4.4.2 KITKAT, TESTED ON IT ALL, ALL WORKS WELL BUT VERY SLOW IF COMPARED WITH OTHER ROMS HERE SITE, DID NOT SATISFIED FOR THE DOWNGRADE FIRMWARE kasty-pipo-m9_pro-4.2.2-ota_2013 / 12/09.ESTA YES WAS THE BEST AND MOST STABLE UNTIL TODAY, FOR BOTH GAMES AS FOR APPLICATIONS AND DOCUMENTS, WILL GO TO TEST THIS UPDATE AND PUT THE RESULTS LATER
karimus100
83
2014/07/09 - 16:21
Hi sorry for my poor English, i want to moove from the Katsy Pipo M9 Pro 442  19/03/2014 to this one (the 04-05-2014)
I read in some poste thy
R-E-S-T-O-R-E !!     R-E-S-T-O-R-E !!   R-E-S-T-O-R-E !!
but in the http://wiki.radxa.com/Rock/flash_the_image
Click the "Upgrade" button to begin flashing and when the flashing process finishes successfully you will see the following interface.
Flash image 10.jpgImage Enlarger
So shall I Uprage ou restore ?
thanks a lot for your help
EDHUNTER
Forum Posts: 22
84
2014/07/09 - 16:46
YES,ALWAYS USE THE RESTORE BUTTON
The following users say thank you to EDHUNTER for this useful post:
karimus100
cracktech
Malaysia
Forum Posts: 432
85
2014/07/11 - 08:35
Your English is NOT that BAD! What is it that you do not understand when I put RESTORE, RESTORE, RESTORE!!! You dont have to ask the question again! If we follow the Chinese instructions which is (always outdated in English) then we all will be be having alot of broken devices. There are horror stories that some people they brick their devices when they use UPGRADE. (Go to Slatedroid.com , I was from there)
karimus100
Viklander
86
2014/07/14 - 23:39
Folks,
first hello you all as this is my very first post.
I own a PipoM9 Pro with original firmware, and would like to install the Kitkat mentionned herabove.
From Windows Seven X64, when I start RKBatchTool, I can load and see the firmware, but I can never see the Pipo as a devive known to RKBatch.
As soon as I plug the Pipo to the computer using USB cable, I am asked by the tablet if I accept to enable it as a USB drive for the computer. If I do so, I can see all my files, but that's it.
I believe that there is an issue with the drivers lying in the BatchTool directory, but I cannot clearly see what to do.
So if anybody is willing to give me a hint, this would be greatly appreciated.
TIA,
EDHUNTER
Forum Posts: 22
87
2014/07/15 - 00:31
Viklander said
Folks,
TIA,
with the tablet connected to the pc go into settings on the tablet'''' and turn on usb debugging and their drivers will install automatically..if still the problem persists, the device manager on the pc and update the driver'''' unknow automatically, even here on the site they PROVIDE drivers pipo m9 pro, I have helped
Viklander
uli-hh
Forum Posts: 31
Thanks Received: 8
88
2014/07/15 - 00:39
Viklander said
Folks,
TIA,
I also recommend to use the Rockchip easy driver installer for installing the drivers correctly.Cool
The following users say thank you to uli-hh for this useful post:
Viklander
Viklander
89
2014/07/15 - 09:52
Will try all these valuable inputs over the next week end : I'm now on the road (again ...)
Thanks !
DarKsandr
90
2014/07/16 - 11:28
hi this question. Do pixels in your version, but they appear in games especially in Badland
67 Guest(s)
Devices in use: Desktop (59), Phone (8)
DAK78
wheaten156
luislx
algua
Twotrains
alexanddercrb
