To trellogavros (or whatever)
First you must edit this line in your build.prop file (/system/buiild.prop) first copy the file out to sdcard anywhere would do then editing on the copied build.prop because I think it will not successfully edit the file build.prop "in-situ" after (due to some rooting problems on our firmware)finishing the editing only then you copy it back to the original location and you MUST SET THE PERMISSION and OWNERSHIP RIGHT (permission rw-r-r / ownership root:root) or your device would not boot up!! CAREFUL!!.
FIND and EDIT these lines
ro.com.android.dataroaming=true ( change to = false)
ril.function.dataonly=1Â Â Â Â Â Â Â Â Â (change to =0)
wifi.supplicant_scan_interval=180 (change to 360 double the delay in scanning rate for wifi )
then ADD these lines to the build.prop (if you are upto it)
hw.nophone=true
hw.hasdata=false ( careful if later you want to use a 3/4G dongle you have to change this to= true)
persist.backgrounddata.enable=false
pm.sleep_mode=1
ro.ril.disable.power.collapse=0
ro.config.hw_fast_dormancy=1Â (CORRECTED /edited)
ro.config.hw_quickpoweron=true
Test to see the battery consumption IF you are still not satisfied then do this next thing;
Go into /system/priv-app/Â rename the Telephone.apk to (.Telephone.apk) put a dot in front the name and TelephoneProvider.apk also. Android will ignore any file with a dot "." in front of its name.
Since this is your main concern to want to disable modem/opinions-on-teclast-p90hdlephone ( I have the same model as yours without 3G but my battery last about 4 days in sleep mode only with the build.prop lines, I dont disable the Telephone services apps because sometimes I need to use them.
trellosgavros, admin, papamopps, NordoAbout Me  LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
2013/11/20
For anyone that have issues with reboots and freezes. Do you guys happen to use SwiftKey? Cause after the latest update of SwiftKey (and the build.prop edits that cracktech provided) I don't have any issues (at least not for the past 12 hours or so) considering that the freezes would happend between 1st minute of turning on device up to 15 minutes of use.
I just want to know if we all have that in common, or if it is cracktech's solutions that actually helped.
PS. Cracktech, this build.prop line you provided was incorrect:
ro.comfig.hw_fast=dormancy=1
It should be ro.config.hw_fast_dormancy=1
2014/01/14
CybeRNerO said
For anyone that have issues with reboots and freezes. Do you guys happen to use SwiftKey? Cause after the latest update of SwiftKey (and the build.prop edits that cracktech provided) I don't have any issues (at least not for the past 12 hours or so) considering that the freezes would happend between 1st minute of turning on device up to 15 minutes of use.Â
No, I'm using google's keyboard.
2014/04/08
hw.nophone=true
pm.sleep_mode=1
Thank you so much !!!
I will try it today !! You are awesome.
thanks it was aa typo, it was 4 am in morning my time. Thanks again before any damaged is done!
hw.nophone=true
pm.sleep_mode=1
In order not to cause any errors I have prepared a CWM flashable zip to DISABLE the "ril" and "telephony" functions. You just flash thro CWM the attached file to your device. This is for KitKat M9Pro build #407 (latest) version. (Dont flash this on other models and build version) If anybody want to use the modified build for other models they will have to manually edit it into their own build.prop
trellosgavros said
Thank you for your offer !I flashed successfully the file. However, going to Mobile settings I saw that the modem power check is still on. Is this a fake toggle or something and the whole module is disabled now or I failed ?
Thank you anyway !!
This my status everyday even with the modem ticked (enabled it seems) my build.prop is different than yours you just flashed  where all telephony service and data service is OFF whereas mine is ALL ON. You can see that there is no data (modem) running, it only shows the screen consuming power
2014/06/14
give it a little prorblem in the "mobile network name" (carrier name)!
In Germany.
Can you help to fix?
Operator / Network Name
Germany   26201   D1 (T-Mobile)
Germany   26202   D2 (Vodafone)
Germany   26204   D2 (Vodafone)
Germany   26209   D2 (Vodafone)
Germany   26203   E-plus
Germany   26205   E-plus
Germany   26277   E-plus
Germany   26207   O2 (Viag Interkom) @me is "Kabeldeutschland"
Germany   26208   O2 (Viag Interkom)
Germany   26211   O2 (Viag Interkom)
Tablet:
Pipo M9 Pro 3G
Archos 101 G9 Turbo + Archos G9 3G Stick
2013/09/03
In Germany.
I've tested nearly all the Roms (Pipo, Kasty & Riley) on my M9pro 3G in Germany and all the time the mobile network name was shown as a number 262XX. It's not a bug, it's a feature!
For me it's no problem.
Really important is, that you have the APN-Data for your carrier configured right.
67 Guest(s)
5 Guest(s)
Devices in use: Desktop (61), Phone (5), Tablet (1)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
