Hello !
I too am facing the GPS dilemma I cant seem to get a decent fix on GPS especially with the KitKat ROM, this is a double whammy on the part of firmware and hardware the last time I had a very good fix on GPS was on the October 2013 4.2.2 version that was like eons ago! But get the gps.conf file handy somewhere I am on MTK 6582 LENOVO phone using the same gps.conf file (for my country) and it is instantaneous in the house or outside! . Now I use the LENOVO for travel since it is a 6inch phablet with SygicMaps very accurate.
I would say that the PiPo is hopeless since it is using a seperate module for GPS/WiFi and the metal cover at the back is making it worse.
Sorry buddy I am at a lost here to help out on the GPS, unless the kernel for the October 2013 which is a 4.2.2 is ported over to the current version. the drivers are basically the same drivers and I suspect it is kernel issue.I bought this devive becoz it has GPS now it is useless so now I only buy 6inch phablet with MTKÂ SoC, the next purchase will be at the end of this month LENOVO S939 Octa Core and modify/root the ROM. I gave away my current phablet to my daughter after completing the ROM modification and posted the ROM on NEEDROM already.
About Me  LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
2013/09/05
Hi, I seem to be having a problem with the touch screen after installing this Rom, it works fine until I restart and then the touch screen does not work, I then have to reboot using the reset button two or three times to get the screen to work.
If I go back to the 4.2.2 rom all works well, also the Riely Rom based on the same rom from PIPO but with the #406 and not #407 works.
I prefer your roms, but it would seem that my Tab does not like the #407, or am I doing something wrong.
gone back to 4.2.2 until a fix can be found.
2013/11/18
trellosgavros said
Hi to all !!Can someone answer if this specific firmware causes random reboots of tablet, and how often? Because I have installed the previous version and I have one or two reboots max in day. What's your experience until now ?
Thanks and keep up the good job !!
Haven't seen single reboot in about week of use with this SW. Previous SW rebooted about one to three times a day.
2014/01/14
Hi.
I've tested all official roms from pipo and unofficial roms from arctablet based on android 4.4.
With All of them, i get random reboot. About every half hour.
No problem on android 4.2.
I have been on KASTY ROM since 4.2.2 from mid 2013 until today 4.4.2Â (15-may 2014 #407) mostly I faced a mising GApps to my liking like Talk/Maps/etc but so far I have no random reboots it is a either
: the copy of firmware being downlaoded has a slight error iin it (it is a big contiguous *.img file)
: or your hardware issue.
Nope no random reboots since last year (I was lucky since I bought through a seller who visits Taiwan/Chian once a month to select the quality pieces from distributor)
2013/11/20
Hi.
// <![CDATA[(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=25e16db559&post=43157&forumid=157','W4fY5kTX1u',false,'5kK6Mr1Rnno');
Exactly the same issue with me... 4.4, any kind of rom, reboots frequently or even freezes to black screen (could not find a pattern on this behaviour to isolate it and debug it).
4.2 is not affected by this issue, again, with any ROM used, but it's considerably slower than 4.4!
2014/04/08
I have the PIPO M9 PRO NON-3G tablet. How difficult it is to completely remove the modem power module, so not to drain the battery? I tried the arctools solution for deep sleep but it doesn't work. Every time I boot the tablet the modem power is on and battery stats indicate that cell phone service eats battery. Thanks for your answers !
The following users say thank you to trellosgavros for this useful post:
papamopps
2014/04/15
// <![CDATA[Â
que intentaste hacer los datos acabar? mi hijo nunca ha tenido reiniciar estafa kasty m7
71 Guest(s)
Devices in use: Desktop (60), Phone (10), Tablet (1)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
