[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2014/05/04)
Piperos
Forum Posts: 13
2014/05/25 - 09:11
cracktech said
Piperos said
I flashed the ROM and after the boot the tablet now shutdown itself :(
Any hint on what could be the problem?
If your PC can still recognised the device try to reFlash it again this time make sure you use the factory supplied USB OTG cable (it has slightly longer mini metal connector than standard) once flash starts do not move the device lay it flat on your table without any movement. [...]
The problem was I'm too dumb :)
I din't check the battery and it was empty, so after recharging it and reflashing the rom everything went fine!
Thanks to Kasty for the work, really appreciated: do you have a bitcoin donation address?
dagamo32
2014/05/25 - 12:12
So, it works or not 3G?
Piperos
Forum Posts: 13
2014/05/25 - 13:42
I'm sorry I don't know: mine has no 3g
uli-hh
Forum Posts: 31
Thanks Received: 8
2014/05/25 - 14:21
On my Tab 3G is working fine!!Smile
I've a pre-payed rate. When I start the Internet I'm redirected to the provider website to choose a surf package.  When done I'm able to surf the net without problems!
Did you see  that there is a new switch in the system settings: At "Data usage" is a switch "Mobile Data"! This must be in "on" position! Also at More/Mobile Networks/ the "Modem power" and "Data enabled" switches must be on!
Good luck!
The following users say thank you to uli-hh for this useful post:
admin, dagamo32
onesky
2014/05/25 - 14:46
3g (italy) is working great, official and kasty
GPS is lost, official and kasty
The following users say thank you to onesky for this useful post:
dagamo32
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2014/05/25 - 15:50
I SEE A MAJOR PROBLEM ON THIS UPDATE - (update to version #407 problems)
My SYGIC Navigation refuses to run
My Microsoft OneDrive doesnt run
My local TV on demand app doesnt run on this #407 KitaKat version it was OK on the #404 version.
I am going to back to #404 version anyway theres NOT much difference in this version.
onesky
2014/05/25 - 17:58
can i add somethingelse? i am experiencing multiple reboots with this kasty and with the official release as well
while with the 4.2.2 everything is stable
uli-hh
Forum Posts: 31
Thanks Received: 8
2014/05/25 - 19:26
GPS is working!!LaughAfter 10 minutes he did a fix! Not really strong but it's working!
Screenshot_2014-05-25-19-09-38.pngImage Enlarger
Please add in a "gps.conf" file in your /system/etc/ folder you can find it in my previous postings to ensure you get a quick fix . The gps.conf file is to tell the device to lock on to your nearest local satellite and ntp server in your country (most countries in the world have them) but the "TIME" MUST be synchronised with local ntp server that is why first you need to install an app named "NTPSync" from Playstore. This is applicable to ALL Android version since most Chinese firmware dont have "gps.conf" file or if they have it points to Chinas satellite/ntp server.
dagamo32
2014/05/25 - 19:53
Still missing cursor on #404? I have not tried any of the two yet
onesky
2014/05/25 - 21:27
yes gps is working but very slow to fix
random boots make me go back to 4.2.2 :(
cracktech
Malaysia
Forum Posts: 432
2014/05/26 - 12:21
Yes I can confirm that on #404 the cursor in TYPING mode is missing but it is solved in #407 and I have to decided to stick to #407 since I dont have any problems since Android 4.2.2 (like random reboots except during last year when we had Wifi problems ,NOW WIFI is NO problem/GPS is No problem if you followed by installing my "gps.conf" file) I am having GPS problems right now NOT because of firmware but hardware limitation of PiPo (it was determined that the metal backing is the main cause) I have heard that newer PiPo M9pro has plastic backing now, as was told by a Greek user(i cant confirm that)
The reason why I am sticking to #407 even with FC apps is because I have read somewhere that Microsoft OneDrive for Android doesnt perform well on KitKat it is well only upto 4.2.2 (maybe 4.3), I have a 4.3 awaiting repair (I just dont have the time yet). I dont know about Sygic problems but I have problems with many apps such as my TV on demand IPTV (on Android) when I upgraded from 4.1.2 to 4.2.2 I was not able to access my IPTV and had to terminate the service since my lowest is 4.2.2.
admin, dagamo32
twingo16s
Forum Posts: 48
2014/05/26 - 14:09
after installing 4.4 I can go back to 4.2.2?
twingo16s
Forum Posts: 48
2014/05/26 - 14:49
If it cant be recognised you will have to use Power + Esc key combinationand hold while the other hand mouse click the Batchtool buttons on PC (after the PC is forced to recognised the device by the key combination)
try to redownload the firmware agin using a second copy to flash 9sometimes theres a glitch in the firmware during download , I had many, many experienece with corrupted download ROM for my 8 Android devices)
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=ed6d31b725&post=42608&forumid=157','W4fY5kTX1u',false,'IBlJH90sx8g');
You can help. generic Chinese tablet. RK30SDK. change rom and brick
Kermel 3.0.8
No of Compilation: RK30 SDK 4.1.1 android v1.00.00
rvifu_v2_60. 20121103.849b40a
stay brick. reconose not pc. screen does not turn on.
anyone can help or not serve more
Thanks Received: 3170
2014/05/26 - 14:54
Please read post #1.
twingo16s
Forum Posts: 48
2014/05/26 - 15:23
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=ed6d31b725&post=42678&forumid=157','W4fY5kTX1u',false,'FEvCrnb_YuM');
ok thanks. but I see that is not well explained?
69 Guest(s)
Devices in use: Desktop (59), Phone (9), Tablet (1)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
