[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2014/03/19)
spaceboy1
Forum Posts: 30
61
2014/05/10 - 21:46
A serious problem in that Very often makes restarting the tablet can be automatically corrected?
www.madradio107.net
Alex_Sharp
62
2014/05/10 - 23:53
After FW flash and restart I'v got Unknown Device on my PC (WinXP). Now I can't  load to bootloader at all, PC does not recognizes Pipo. Tablet, as itself work's nice and boot to CWM, but I can't connect it to my PC via USB: I am getting Unknown Device. Tried many drivers and combination w/o any success. I think problem with bootloader. Can I fix it using CWM only ?
Thank you
spaceboy1
Forum Posts: 30
63
2014/05/18 - 17:14
No way change to imei?12345678 shows me another problem is that is makes restarting,you can correct them?
www.madradio107.net
Mr.BlueSky
Germany
64
2014/05/24 - 09:44
Here is latest Android 4.4.2 KitKat rooted firmware for the PiPO M9 PRO (aka Max-M9pro) tablet based on an update from PiPO dated 2014/03/19.
Please note this firmware as some recent firmwares from PiPO probably have a fake 3.4.0 Linux version displayed while the Kernel is actually an old 3.0.36.
(20140319_DS1007_M9pro_4.4.2_#404.rar / 20140319_DS1007_M9pro_4.4.2.img)
Build information:
Linux Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #404 SMP PREEMPT Wed Mar 19 15:31:44 CST 2014
Android 4.4.2: rockchip/rk3188/rk3188:4.4.2/KOT49H/eng.root.20140319.153242:eng/opinions-on-teclast-p90hdst-keys
pipo_m9_pro_android442_kitkat_20140319_about.pngImage Enlarger
  • root with latest SuperSU version 1.94 (free version)
  • increased space for applications (/data partition) to 7 GB
  • added Google Experience Launcher (GEL) in addition to PiPO's stock launcher
  • temporary fix for multi-user support, thanks to didierm
pipo_m9_pro_android442_kitkat_20140319_storage_apps.pngImage Enlarger
Notes:
- you should get an error saying "E:failed to mount /metadata (Invalid argument)" on first boot, you should have no problem ignoring the message.
- while previous firmwares for the PiPO M9 pro were mosly beta software, it seems this release is one of the first stable KitKat update for the tablet.
Download: kasty-pipo-m9_pro-442-20140319-rooted7c_mu.zip
If you like our work, please support us to keep the site alive and contribute to our efforts.
This firmware was successfully flashed on a PiPO M9 Pro, thanks sclstore.fr for their support.
pipo_m9_pro_android442_kitkat_20140319_home_b.pngImage Enlarger
pipo_m9_pro_android442_kitkat_20140319_apps_c.pngImage Enlarger
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=8e8a2aae15&post=41272&forumid=157','W4fY5kTX1u',false,'i8hTBaxkXfs');
Hello again,
a new Pipo M9pro Rom release....
http://www.pipo.cn/index.php?m=About&a=gujian_show&id=185
Changelog german/english:
M9pro chinesischen generische Version Updates Firmware-Upgrade:
Upgrade auf Android 4.4 System-Update neue UI-orientierte Schnittstelle zur Leistungssteigerung
M9pro Chinese generic version of the firmware upgrade
Update: Upgrade to Android 4.4 system
Updated with new UI interface
Increase boot guide
So, can you do it again.... ;-)
Best reagrds
Mr.BlueSky
The following users say thank you to Mr.BlueSky for this useful post:
davidhq
Thanks Received: 3170
65
2014/05/24 - 10:43
Thanks for the note Mr.BlueSky, a custom firmware will be prepared shortly Wink
davidhq
Forum Posts: 14
66
2014/05/24 - 10:54
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=921345139f&post=42559&forumid=157','W4fY5kTX1u',false,'Gs6AVhBP3Yk');
Previous Kasty ROM is working reasonably well for me except for a occasional reboot.
After installing Kasty last time, I also had to install GAPPS update to fix freezing and lags. Does this new ROM include this changes already built-in? Also is the cursor back? And if you know - could this also fix reboots that happen to me once every few days?
PS: ehhh sorry - there is actually no new Kasty ROM yet, I already have the one from 19/3... so I wait for the new one.
PPS: maybe my question / concerns could apply to the next version that is being prepared, so: admin: do you think reboots and lack of cursor could be fixed in the next update? Also GAPPS update to be included...
david
67
2014/05/24 - 15:06
stultorum
68
2014/05/28 - 10:40
hi i have installed this rom using bach tool , and now my pipo m9 pro says that i only have 21 gigas , i have lost 10 gigas sudently , what i have done wrong , how can i fix this? thank you!
69
2014/05/28 - 10:49
No space should have been lost, there are 7 GB dedicated to applications (/data partition) some space is used by Android system and cache, the rest goes for the media/documents storage space.
stultorum
70
2014/05/28 - 17:10
Ok thanks, now i see that 7gb in the internal storage of the pipo, but they are almost completly empty so , for what is this or how can i use them? ty!
EDHUNTER
Forum Posts: 22
71
2014/06/29 - 23:48
I do not know if this area is destined to that question but I would like to know which firmware 4.4.2 more stable for the tablet M9 pipo'' pro'' and 3g if someone already tested the same on a pro 3g m9 pipo
Ambiorix
72
2014/12/22 - 10:51
Hi All,
Yesterday I flashed my Pipo m9 pro using the batch tool and the kasty rom 442-20140504-rooted7.
Since I did this the pipo continously resets himselfs... I tried to do "esc+reset" but this doesn't work...
Any suggestions?
Thx!
88 Guest(s)
Devices in use: Desktop (73), Phone (15)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
