[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2014/03/19)
garbuya
Forum Posts: 11
46
2014/04/28 - 02:10
futzmaster said
deepsleep fix over the arctools app...
I tried this and this is what I see:
Installing arctools-run-script-1.dh
Installing libril-rk29-dataonly.sp
Running script (1)
And that's it!
I left tablet alone for more then hour and still there is no messages that script ended.
Is it ended and it just no messages, or it is still running?
futzmaster
Forum Posts: 37
Thanks Received: 4
47
2014/04/28 - 12:37
I can't tell you the exact messages, but normaly it's finished within a few seconds....
Do a restart an try again.
If the same messages show up, do another restart and leave it.
Need to check if it's just not displaying if it went OK and that a restart can be done....
(Or someone else knows ist)
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
48
2014/04/28 - 23:27
futzmaster said
just try one thing...
read the how to flash carefully again and reflash the rom...
then, just install cracktechs gapps and if needed, the deepsleep fix over the arctools app...
(if you want, try cracktechs build.prop, he did some changes there)
(but i would say, don't change too much, and just try the "empty" system)
nothing more...
and try it for one day....
Thanks futzmaster for the vote of confidence but to butt in where I dont belong.....I think the anomalies faced by GARBUYA is more likely a corrupted downloaded firmwares (I used to faced this problems when downloading a big "'123xyz.img" file which is sometimes nearly 400Mb in size for some phones. Everything seems fine until you notice that the icons on the task bar dont appear and things like that. That is why I have been saying over and over again (is it in this Forum or another?) to downlaod at LEAST 2 copies of the firmware that has big "123xyz.img" files at different time of the day. I normally solved my STRANGE ANOMALY when I flash from another copy of the firmware file. And after that I deleted the other copy and kept the "good" copy as my backup and that strange anomaly never appears again everytime I flash to other users devices over and over again. Please remember that the files are a big contiguous ISO image file they look Ok  even with checksum included. (dont ask for checksum it still resides in the same folder when you download it) Unless it is in a CWM/TWRP zip format then the checksum makes sense.
Try to redownload the firmware agin on any high speed internet link (mostly these errors occurs when on slower internet access (sharing bandwidth). Sorry to say GARBUYA but you have to reflash the device all over again to prevent future anomalies (unseen/unknown).
BOZ77
Forum Posts: 15
49
2014/05/01 - 12:41
Hello everyone and thank you for this wonderful rom.
here is my experience
fluidity ecceptionnel
Performance ecceptionnel
stability: ecceptionnel
autonomy ecceptionnel (unlike the version m7pro does not discharge in sleep)
GPS: Not tested
wifi: like all other Roma (fair)
3g: not tested
Chrome: a bug of afichage aparet red frame
browser: great except that the page still not in the same place when you open another page
youtube and streming: not terrible (can see improvement in build prop craktek)
Overall rating: 9/10
AnTuTu performance execptionnel 19818 :
http://hpics.li/0166954
http://hpics.li/3304cb5
http://hpics.li/2381500
No sorry I was unable to put the pictures on the forum so you will have them in links
cracktech
Malaysia
Forum Posts: 432
50
2014/05/01 - 16:41
Thanks for the info, that you see some streaming videos improvements with the correct "build.prop" setttings. But the build.rpop is only valid for KitKat build#404 not for JellyBean you can edit and add the additions I made into your JB build.prop.
As for the other problems like Chrome having RED frame showing up, I have never experience that before, YouTube also I have not faced any problems with videos streaming from US to Asia (where I am). It is the problems with ur (local ISP bandwidth?).
navidx
51
2014/05/02 - 09:35
Hi. This rom is the best for my m9pro till now
But
I have a big problem with it.
My tablet can't go to deep sleep mode. I use CPU spy and wakelock detector.
Wakelock detector shows that 1013 and audiomix prevent the tablet to go to deep sleep. What should I do? Please help me.
futzmaster
Forum Posts: 37
Thanks Received: 4
52
2014/05/02 - 13:32
Maybe you try the deepsleep fix mentioned in this thread?
cracktech
Malaysia
Forum Posts: 432
53
2014/05/02 - 16:47
But
Funny I was having a conversation with admin just a few days back regarding my screen doesnt switch-off and therefore never shutdown/sleep. (I really dont know the meaning of deepsleep coz when I let the PiPo shutoff itself on my table and come back after 3-4 days , pressing the power button wakes it up and battery is still 90+%)
But there was my problem recently when my screen doesnt want to shutdown and goes to sleep. I thought aboiut what to do and decided to do a maintenance of my pad checking all drivers are there and checking cache/dalvik cahe. I found out that i have nearly 600Mb of hidden cache!
So i decided to clear up all the cache and rebuild the dalvik-cache using various tools from China and playstore and after satisfied I reboot and set the screen shutdown time to 30 secs and it worked ! No more wide awake PiPo how such a simple matter can effect the sleep mode I dont know why (but it did solve my problem) i Suspect since forever I had notice that when we flash a new ROM, the script doesnt format the system sector, unlike some of the devices I previuosly own it does format the whole pad INCLUDING the system sectors.so maybe after awhile rubbish tends to accumulate there. especially after admin adjusted our data segment to 7GB. Some of these are left behind files from previous ROMs.
Only god knows best.
futzmaster
Forum Posts: 37
Thanks Received: 4
54
2014/05/02 - 22:00
thx cracktech
so it looks like to get a better (or different) formating script / routine before flashing....
by the way:
anyone tried / running ART instead of Dalvik?
navidx
55
2014/05/04 - 15:30
Excuse me, where?
navidx
56
2014/05/04 - 19:38
Sorry I'm not expert. Can you help me please? What should I do?
cracktech
Malaysia
Forum Posts: 432
57
2014/05/05 - 14:46
navidx said
Excuse me, where?
Run Archtools and seek from within it the deep sleep fix >> download and install the patch, it may or may not sove the problems but I dont face the pproblems anymore after the current flash and after I cleared all my cache/dalvik-cache, I recommend you not to enable ART as it  will cause alot of apps which was made to rely on dalvik to either crash or not run at all.
pankozin
58
2014/05/09 - 19:12
Hello folks.
I have a problem with streaming on youtube on this ROM. Streaming videos are working only 10 or smth seconds and then are freezing.
Somebody had such a problem? and how can i resolve it? I need streaming videos alot. Thanks.
cracktech
Malaysia
Forum Posts: 432
59
2014/05/09 - 19:53
Go to 1st page of this thread and download my "PiPoUpdate.zip" in it contains a modified "build.prop" which improves the video streaming, I dont have video streaming problems even on 5Mb connections shared with an IPTV/5 PC at home for YOuTube or otherwise.(it was reported in another thread that it solved or improves a users streaming problems too). And solves certain quirkiness with this firmware which is really an excellent version (the 3rd version)
It has to be flashed through CWM recovery by the way
RoyalWulf
60
2014/05/10 - 00:28
I also have the RED frame on chrome, not all the time but most of the time.
I have no issues with YouTube, I haven't done the changes to build.prop yet.
83 Guest(s)
Devices in use: Desktop (74), Phone (9)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
