[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2014/03/19)
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2014/04/16 - 03:57
I had the NO freezes even without these Gapps but then I work fast before I even connect to Google server change my Android ID to my previous ID (since 4.2.2 same ID). Update SuperSu if it is not upto date, Update Gmail added Maps ,Talk Velvet and (and check whether Google Plus can be added into /system/app folder most of the time it cannot be added will cause FC)check Google ServicesFramework/LogIn service is present or not and added the full AOSP build including in the build.prop. and found out that some build.prop statements cannot be added it will cause crashes  and not boot up. So my modified build.prop are guaranteed to work on M9Pro.
For those that needs video streaming to be good and device properly registered on google servers for full compatibility flash this modified build.prop file through CWM or for those that are adventerous just copy over the build.prop into /system folder and set permission "rw-r-r" and ownerhip "root-root" (as if you all dont know already)
It is a small file but it does its job but I have very few incompatibilities throughout using my build.prop from 4.2.2 till 4.4.2. REMEMBER TO REBOOT AFTER UPDATE>
Mr.BlueSky
Germany
2014/04/16 - 09:25
Hello again,
Pipo just released a new firmware: M9peo_1.0.7_20140414-update.img
Is it 4.4.2 or 4.2.2  ---> i dont now....
Direct-Link:
http://www.pipo.cn/En/index.php?m=Product&a=show4&type=2&id=286
I think, it´s time for a new kasty rom.... Wink
Best regards
Mr.BlueSky
The following users say thank you to Mr.BlueSky for this useful post:
arcrsc
cracktech
Malaysia
Forum Posts: 432
2014/04/16 - 11:06
It looks like 4.2.2 JellyBean since this is OTA version.
futzmaster
Forum Posts: 37
Thanks Received: 4
2014/04/16 - 12:37
@cracktech
your gapps update is dated to 2008? (some classes.dex are 8.2013)
ok, it seems to work and fixes the problem, but shouldn't be used the newest pakage?
@admin
what version will be installed if we use the option in arctools?
davidhq
Forum Posts: 14
2014/04/16 - 13:46
Today something happened - tablet rebooted itself after I tried to simply wake it... anyone seen something like this? If it happens once a month or less, I don't care that much but if there is osmething that can fix it easily, I'd be happy to try it. That and the missing cursor and then I think my system is perfect for some time.
It happens once in a while on M9Pro since JB versions nothing to panic about. I have a LENOVO phone A880 6inch that reboots 4-5 times a day until I updated to a newer firmware. The stable firmware came from Russian sources and the original factory ROM(the auto reboot 4-5x/day) is from China factory sources (LENOVO)
netventure
2014/04/16 - 19:03
Anyone has any success with kitkat with flash player? I tried Dolphine with Jetpack and the cracked flash player from XDA site but no success. Can't play some facebook games that require flash player and website that required flash player to playback some clips. Any resolution to browser supporting flash player?
By the way, I'm still on older 4.4.2 dec version.
TIA
cracktech
Malaysia
Forum Posts: 432
2014/04/17 - 12:27
futzmaster said
@cracktech
@admin
Some GApps package are dated like that they are not the outdated 2008 version they are most probably of CM origin which in my previous Forum(Slatedroid) CM10.2/11 are dated as such. It is for uniformity with other system files/drivers and such by the GURUs.(Christian Troy) and on the CM firmware if any files date is out of sync with the rest of the firmware it will either not be installed or the flashing process is aborted by the recovery flashing in Christian Toys case for my other device it is TWRP recovery.
I can assure you those are for the KitKat version and are upto date, if they are NOT they wouldnt even get installed (rejected by KitKat).
I have attached here the newest GoogleCamera (it is shown as not being compatible with M9Pro but I assure you that it is , this is the Playstore link to the Google camera (that is said not to be compatible with M9Pro)
https://play.google.com/store/apps/details?id=com.google.android.GoogleCamera
This is the GoogleCamera version 2.1.037 (All our current Camera versions are 2.0++ irregardless) but still it cannot solve my barcode reader problem in KitKat (it can read the BarCode but the frame is static, you have to aim the camera to be directly opposite code when opening the app)
netventure
2014/04/17 - 17:47
restore the new version but hang/ freeze a couple of time. It has the very sympton with the initial stock version when I 1st purchased it. Unlike the version m9_pro-442-20131226-rooted4c_mu, it had not freezed on me a single time since installed early Jan. I find it more stable and I am falling back to the version.
Thanks anyway. Hope the next newer version can be as stable.
futzmaster
Forum Posts: 37
Thanks Received: 4
2014/04/17 - 18:12
Cracktech, i belive that it's for KK and working :)
But there are other gapps updates (newer ones) around and my thougt was: is yours with a special fix?
(or maybe just an older version of those, and the newest one would fix the problems too?)
I haven't had any problems yet...
Just installed the fixes with arctools direct after flashing...
Mr.BlueSky
Germany
2014/04/18 - 12:25
New custom root firmware in progress... ???? Laugh
futzmaster
Forum Posts: 37
Thanks Received: 4
davidhq
Forum Posts: 14
2014/04/18 - 17:41
I found another problem... not sure if it was like that on original firmware too:
https://www.dropbox.com/s/vaah5vufe20x5v6/Video%20Apr%2017%2C%2020%2018%2007.mov
it also happens in Facebook app menu for example... so it's selecting things when I just want to scroll.
miguelb
2014/04/18 - 17:58
Did somebody please tell me if this custom rom runs on the pipo m9 ( i don t have the pro version) ty
Dereck
Forum Posts: 15
2014/04/18 - 18:12
I tryed to flash this rom, but during flashing after format I got error "Wait for loader Fail" and now my pipo not working. How do I restore it?
UPD. Restored.
arcrsc
2014/04/19 - 00:52
Aqui funcionou 99,99%, faltou somente o cursor no campo de digitaçÃo. GPS ok, 3G não foi testado (sem cartão)
Muito obrigado
Roberto
99.99% worked here, missed only cursor input field. Ok GPS, 3G was not tested (no card)
thank you very much
Roberto
81 Guest(s)
Devices in use: Desktop (69), Phone (12)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
