[ ROM ] Pipo M9 pro (3G model) custom root Android 4.2.2 firmware (2013/10/11, SMS)
Lottoman
Forum Posts: 43
Thanks Received: 10
61
2013/10/24 - 12:34
eskizara said
Thanks for the reply Mattiesrag.
However, the 'switch' button just turns off the tablet for me... Then the tablet is off and the color turns to grey - not connected...
Thank you
Try reset your tablet by pressing a paper clip or similar in the small hole besides the camera in the back. It will reset your tablet and you can restart. That should help.
The following users say thank you to Lottoman for this useful post:
eskizara
gerfalcon
62
2013/10/30 - 16:52
Hello friends
I have a problem with 3G modem
If I try to search for networks it says "Error while searching for network"
If I click search automatically it says "Your sim card does not allow connection to this network"
Its problem became 2 week ago on riley rom. I try any sim cards and  roms,stock, Kasty 10-10 and 23-10 but i havet fix this issue.
Can you help me?
Thanks Received: 3170
63
2013/10/30 - 16:59
It may be a bug on this 2013/10/11 firmware. Have you tried more recent firmwares, like this one which is supposed to be compatible (I don't think anyone confirmed yet) with the PiPO M9 pro 3G version ?
gerfalcon
tomro
64
2013/10/30 - 17:04
I had also this problem. Now on kasty-pipo-m9_pro-422-ota_100_20131023-rooted4 it is OK (but still have a problems with freezings, shaking screen and similar behaviour when the signal is weak).
Robert
The following users say thank you to tomro for this useful post:
gerfalcon
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
65
2013/10/30 - 18:27
Hello gerfalcon,
IF you are adventorous enough please copy the file "spn.xml" from inside the /system/etc/ folder and put it on your PC. it is a list of overrides for certain cellphone services from around the world inside it. maybe your service providers is one of those that is listed on the "override" keep an original copy somewhere safe and try to delete the name of your service provider if it is found inside the spn.xml file and put it back again on the tablet to see whether it will work. I suspect the override is to blacklist the service providers.
The other is the "operator_table" inside the system/etc folder which defaults to India (TATA, MTS and idea network) and CHINA TELECOM network. You can read this from within a text viewer in RootExploer and edit it accordingly (please keep a copy of the original file safe.)
For example the inside of the operator_table looks like this
#########China Telecom########
46003
CT-CDMA
CHINA TELECOM
##########India  MTS##########
40589
MTS
MTS
##########India TATA ##########
40400
TATA
TATA
If you are adventerous you could try to change this settings to point to your service providers.
Just keep the originals somewher safe (this will not brick your device the worst case scenario is it will make your 3G not able to find a network.)
Good luck in trying its better to do it yourself than to ask others.
gerfalcon
cracktech
Malaysia
Forum Posts: 432
66
2013/10/30 - 18:48
Thank you
eskizara,
have you successfully flashed your device yet? If not please read the cooments from this post :
http://www.arctablet.com/blog/forum/pipo-max-m9/rom-pipo-m9-pro-custom-root-android-4-2-2-firmware-ota_1-0-0-20131023/page-3/
Post number #37 onwards it should help you.
eskizara
Lottoman
Forum Posts: 43
Thanks Received: 10
67
2013/10/30 - 19:20
eskizara said
Thanks for the reply Mattiesrag. However, the 'switch' button just turns off the tablet for me... Then the tablet is off and the color turns to grey - not connected... Thank you
eskizara,
If you are using Win 8.1, forget ir, it do not work. Win 8 do work for some. Use a win7 or XP machine and it works as supposed. We need new drivers for Win 8.1.
Lottoman
eskizara
eskizara
68
2013/11/01 - 12:15
Thank you
eskizara,
Hi Cracktech,
I was away for a few days so did not attempt the flashing until yesterday.
However I am pleased to post here that I was able to flash my tablet.
I started with the 'reset' suggested and then followed the post above.
After pressing the 'reset' button and re-starting the tablet I connected it to a Win 7 Pro 64 bit, pressed 'Switch' and in a couple of seconds I had 'green' light...
All seems to be working fine.
Thanks everyone for your help.
jjjefff2000
69
2014/02/01 - 01:02
xocolocoxoco said
somebody else having this problem the tablet turns itself off?
Yes I have the same problem. What to do?
shirinyan
70
2014/02/22 - 17:06
Hello friends,
I am new here but I need some help.
I tryed almost all stock and rooted firmware but I had problem with 3G. Can't access to the Internet.
Only with this SMS version after first boot after install it for the first time I had succesfull send SMS to my phone number. But after restart tablet the problem was the same. When try to on/off Modem Power for some second appears icon near to clock in top (in notification bar) and then it is gone.Very strange. Then try to search network it's find my mobile operator and connect with him but that all.It's take APN setting automatic but that all.
I am from Bulgaria.
Regards
Dstephan
71
2014/03/06 - 14:37
I flashed my Pipo M9 with this Rom on Sunday, at today they works very good, only problem are the GPS, they don't work! :(
3G --> OK
WIFI --> OK
USB --> OK
HDMI --> OK
I found my Pipo M9 very very fast, I love this Rom, at today the only problem are the GPS, I don't find to activate this.
Very good work!
cracktech
Malaysia
Forum Posts: 432
72
2014/03/08 - 22:10
This is a problem with fashing. My 2 cents worth of advice here,when you download ANY ROM please download at least 2 copies of it (I normally download 3 copies) at different times of the day and kept it in separate folders on separate drives. WHY?
I had this experience in flashing my LENOVO A880 phone - all flashing went smoothly with NO error indicated but when booting up it went into boot loop. I scratched my head bald trying to figure out the problem.
Then I downloaded a fresh copy of the same ROM from the same source and reflashed, only the latest copy worked without a flaw. There was another successful flash everthing worked well except that the notification bar doesn't show any icons except for Wifi/3G network icon. I downloaded another fresh copy  and reflashed and everything went back to normal.
So the moral of the story is not trust the success in flashing message if it doesn't work 100% as it should. The ROM version that you flashe doesn't have any reprted GPS problems (except fot the inherent poor GPS signal on most M9Pro).
So since you know already how to flash, download another fresh copy (2X) and reflash it there could be a minor corruption of a file in the *.img file (remember it is 300Mb not 300kb) any hardisk glitch on the HDD sector will cause this problems.
REFLASH with a FRESH copy is my advise.
EDHUNTER
Forum Posts: 22
73
2014/03/09 - 12:59
yesterday downgraded this kasty firmware 4.2.2 on my pipo m9 pro (3g version)
but I found an error in the reading sd card 32G (SAMSUMG CLASS 10), constant crashes arise from the Settings menu and explorer menu card, formatted the card but the problems persist ... kasty other firmwares 4.2.2 for pipo m9 3g pro also has the same problem reading the card, I tested all and they have the same problem when using this sd card, when I remove the sd card and restart the tablet it works normally ...
obs: the kasty 4.4.2 rom is the only working perfectly in (pipo m9 pro 3g)
the only problem was the incompatibility of some games: NFS mosted wanted no wheel, the audio is garbled real racing 3, among other ... the way now is to wait for an update from 4.2.2 to come kast fix these small details. ..
Dstephan
74
2014/03/09 - 14:10
Thank you Cracktech,
2 days ago I needed to reflash again my Pipo, because I was changing configurations and they restarted alone, and the restart was a only a looploop cyclus.
The reflash was with the same ROM, but Gps dont work againagain. Thats not a big problem for me, I only tries to inform my diffulties.
Sorry my English, I make my better erfort. Thanks a lot again.
cracktech
Malaysia
Forum Posts: 432
75
2014/03/09 - 21:26
It is very sad to hear another user not having his device perform 100% as it should. (although some of you can accept it) but for me I would like it to work 100%.
There is another way to do this BUT you still have to REFLASH. Since your device is working 99% OK  go into the /data/dalvik-cache/ directory and delete ALL the files in dalvik-cache (it is like doing a CWM erase dalvik-cache)
Then reboot the device again (it will be a bit slower on start up) and check whether GPS works or not.If it doesnt work..........then REFLASH it with another copy of your downloaded *.img file. BUt before a reflash delete the dalvik-cache again.
I had another experience losing the use of WIFI for 4 months on a ZENITHINK AML device, and I did the dalvik-erase and reflash(I did the reflash  about a dozen times) after that it work flawess until today (7 months ago)
Currently Online: mogabi
81 Guest(s)
Devices in use: Desktop (73), Phone (8), Tablet (1)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
