[ ROM ] Pipo M9 pro (3G model) custom root Android 4.2.2 firmware (2013/10/11, SMS)
xocolocoxoco
Forum Posts: 54
31
2013/10/17 - 19:48
tomro said
I have just made the upgrade to custom root Android 4.2.2 firmware (2013/10/11, SMS). Can't tell if there is a big progress with radio part of the tablet, now it works more or less, still can observe some minor wifi issues, but seems more stable and faster now.
Still I am interested above wireless display functionality, because there is again no option to switch off wireless display in settings menu. The strange application WiFiDisplay does not response to inputs to button "search displays" and any options like settings are missing.
So if somebody has an idea about wireless functionality and associated topics related to Pipo M9Pro 3g tablet may be it is worth to open new topic in the forum.
Anyway, thank you for help and especially to the author of kasty rom, definitely will send some donation to his account :-)
I created a new topic for the wifi
http://www.arctablet.com/blog/forum/pipo-max-m9/pipo-m9-pro-wifi-problem/#p30910
Igor101
Forum Posts: 18
32
2013/10/19 - 17:04
What does the SMS refer to in this upgrade? Is it related to texting?
nAFaNyA
33
2013/10/20 - 15:38
Screenshot_2013-10-20-17-10-05.pngImage Enlarger
Luck or GPS fixed on our device? :)
Lottoman
Forum Posts: 43
Thanks Received: 10
34
2013/10/20 - 16:12
I can get the same result puttig it alone under a free sky for1 hour. But for normal navigating it is useless. The sattelites disapears the moment I take it up and walk a few steps.
Cry
Lottoman
Forum Posts: 43
Thanks Received: 10
35
2013/10/20 - 16:14
You can send and receice SMS the same way you can on your cellphone as long as you have the 3G activated.
Smile
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
36
2013/10/21 - 09:08
Pure LUCK for you not applicable to most users. Post into the GPS problems threads please.
cracktech
Malaysia
Forum Posts: 432
37
2013/10/21 - 09:11
Cry
read the GPS problems thread to solve the problems.
Lottoman
Forum Posts: 43
Thanks Received: 10
38
2013/10/21 - 09:33
Cry
I have tried all in that thread but it solves nothing for me, having a GPS that needs at leat 30 minutes to get enough sattelites and do not keep them is nothing worth for navigation. This must work without the WIFI on. It must be a hardware problem, probably a bad antenna. That is what we get for bying Chinese goods cheap.
Not really a problem for me, just a dissapointment.
Embarassed
ledba
39
2013/10/21 - 14:13
Lottoman said
Cry
Embarassed
The amazing thing for me is, if I put it in vertical position with the camera to the right side it sees more sats and signal becomes stronger for about 20% Laugh
cracktech
Malaysia
Forum Posts: 432
40
2013/10/21 - 17:14
ledba said
Lottoman said
Cry
Embarassed
Are you really sure that you did the gps fix 100% to the instructions , I dont think so! It has been too quick for your reply.
Lottoman
Forum Posts: 43
Thanks Received: 10
41
2013/10/21 - 20:59
ledba said
Lottoman said
cracktech said
Lottoman said
nAFaNyA said Screenshot_2013-10-20-17-10-05.pngImage Enlarger Luck or GPS fixed on our device? :) I can get the same result puttig it alone under a free sky for1 hour. But for normal navigating it is useless. The sattelites disapears the moment I take it up and walk a few steps.
Cry
I have tried all in that thread but it solves nothing for me, having a GPS that needs at leat 30 minutes to get enough sattelites and do not keep them is nothing worth for navigation. This must work without the WIFI on. It must be a hardware problem, probably a bad antenna. That is what we get for bying Chinese goods cheap. Not really a problem for me, just a dissapointment. Embarassed
Yres, I am absolute sure I put in the conf file the right place after editing it as you suggest. I even tried the conf fiile from my Samsung phone:
NTP_SERVER=north-america.pool.ntp.org
XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin
XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin
SUPL_HOST=supl.google.com
SUPL_PORT=7276
This phone finds 10 sattelites in seconds. But I am very far from North America. That is why I don`t think this ntp trick is so very important. If you have a bad antenna you can throw at it any file you want but it will not help.  I am happy for those who get it to work. I do not. So Ill end my comment with this.
Cool
xocolocoxoco
Forum Posts: 54
42
2013/10/21 - 21:05
somebody else having this problem the tablet turns itself off?
cracktech
Malaysia
Forum Posts: 432
43
2013/10/22 - 08:51
SUPL_PORT=7276
Cool
  Wait a second there! What do you mean you are far away from North America? Are you or are you not in North America. If you are NOT why do you use the north america ntp.server address and where is your locale address like Fl (Florida)?
  You said it rightly that you got a few satellites in a few seconds thas pretty good but IF you are NOt in North America what the hell is that North America ntp.server doing in your gps.conf file? If you are in Europe then it should be europre.pool.ntp.org
 the SAMSUNG gps.conf files is used in conjunction with a gps.folder in its system/etc folder that has its own cert.,gps.hw settings
Lottoman
Forum Posts: 43
Thanks Received: 10
44
2013/10/22 - 09:13
SUPL_PORT=7276
Cool
No, I am NOT in USA, in fact I am in Europe. Why the NTP server is set to North America is smth. you must ask Samsung about. It do not need local NTP either. The  GPS in the phone works very well with these settings. Please read my comments, your NTP trick do not work, at least not for me. End of comments.
zorolili
45
2013/10/22 - 11:50
I have the same problem
Currently Online: sh_sasha
82 Guest(s)
Devices in use: Desktop (76), Phone (7)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
