[ ROM ] Pipo M9 pro (3G model) custom root Android 4.2.2 firmware (2013/10/11, SMS)
2013/10/14 - 15:45
Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M9 PRO (aka Max-M9pro) new tablet hardware that is equipped with a GPS. This firmware is designed for the model with the 3G module, it is based a latest official update dated 2013/10/11.
( 20131011_sms_M9pro_update.img )
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #327 SMP PREEMPT Thu Oct 10 19:13:01 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20131010.191317:eng/opinions-on-teclast-p90hdst-keys
Notes:
- please uncheck "en_apk.install" for this firmware to work, thanks udio80
  • root with latest SuperSU version 1.65 (free version)
  • removed most Chinese and unnecessary applications, removed Certificate Center asking for product key
Download: kasty-pipo-m9_pro_3G_SMS-422-20131011-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a PIPO M9 pro 3G tablet to test the custom firmware.
Terryfried, Mr.BlueSky, Dreamboy4, diego.m, maryontour, ledba, mattiesrag, vbpian, moli, colossalelf@hotmail.com
udio80
2013/10/14 - 18:18
I can not get it started after upgrading, after you press done, the pipo does not start and tells me unfortunately, has stopped com.android.provision
Lottoman
Forum Posts: 43
Thanks Received: 10
2013/10/14 - 18:38
Confirm: It do not start. Com.android.provision stopped.
Embarassed
udio80
2013/10/14 - 19:19
I understand what the problem is you have to uncheck en_apk.install
The following users say thank you to udio80 for this useful post:
Lottoman
Forum Posts: 43
Thanks Received: 10
2013/10/14 - 19:40
Yes, it works! Thanks!
Smile
darioM85
2013/10/14 - 19:50
OK.thanks
spaceboy1
Forum Posts: 30
2013/10/15 - 01:06
before I install the firmware must remove this file; yes if you find it
FILE  en_apk.install that you can find to remove
www.madradio107.net
mattiesrag
Forum Posts: 39
Thanks Received: 5
2013/10/15 - 08:39
Smile
Being a novice at this - HOW DO YOU GET TO THIS FILE ???
Lottoman
Forum Posts: 43
Thanks Received: 10
2013/10/15 - 09:13
You don`t get to it to remove it. You get a choice when you install the ROM, just untick it, thats all. Good luck!
Lottoman
The following users say thank you to Lottoman for this useful post:
Mr.BlueSky, Terryfried, mattiesrag
xocolocoxoco
Forum Posts: 54
2013/10/16 - 02:44
Hi
I am frustrated with the problem of wifi
I've done update, searched the internet for firmware compatible, and so far nothing!
I buy two tablets PIPO M9 PRO with 3G, and both have this problem.
The problem is, when I connect to wifi, the tablet works for a few minutes or even hours.
And in the notification bar wifi, after a time it shows only upload and not download, and not browse more. I turn on and turn off wifi and do not connect more.
I am forced to restart the tablet, and does not always work.
Please, help me :/
look my video
Dereck
Forum Posts: 15
2013/10/16 - 08:23
A lot of people have the same problem. Given the massive problem, I think that the problem in the firmware (kernel).
Lottoman
Forum Posts: 43
Thanks Received: 10
2013/10/16 - 08:41
FYIO: I have the same problem but it always help turning off and on Wifi but it takes a little time before it reconnects. I don`t have to restart the tablet. Hope they fix it in an update it is really frustrating.
shockyou
2013/10/16 - 09:17
I have noticed a NAND flash problem with this firmware. Sometime the tablet recognizes the nand flash and sometime it does not.
Please reply if same to anyone of you.
tomro
2013/10/17 - 12:44
I also suffer from WiFi issues as well as 3G connection which sometimes causes frozen display (especially when the signal is weak or only connected as edge), shaking or "mad" cursor which jumping through the display and randomly switches applications.
I made my first flash with RileyROM 1.7b, at the first moment it looked that problems were solved, but then again raised and it behaved in almost same manner as I described above. After some googling I found that forum and flashed my PIPO M9Pro 3G 32Gb with kasty-pipo-m9_pro_3G rom from September release.
No success, still with wifi and 3G connection issues.
My direction is now heading me to wireless display. From the first moments I was surprised that there is no option to switch off wireless display in the display settings menu. Then I went to an application which is named wirelessdisplay which is not listed among installed application list from settings menu but found it among running applications. The application has short cut among (an icon) and when I tap that it starts running but there is missing menu for setup.
My suspicion is that wirelessdisplay is somehow responsible for issues with radio part of the Pipo tablet.
I have tried to find some information or source of that application (wirelessdisplay apk), but no success.
May be somebody has some ideas and better understand these relations and can investigate in that heading.
Thank you and nice day to all android users :-)
mattiesrag
Forum Posts: 39
Thanks Received: 5
2013/10/17 - 14:59
Just loaded this ROM and it is working perfectly - including wifi and 3g. I wonder if you perhaps have a hardware problem.
96 Guest(s)
Devices in use: Desktop (80), Phone (16)
hans41
rickybk
soniya07
ironmangitar
