2013/09/19
Hi there,
i'm searching for ko-modules to use cifs on my XORO PAD 9719QR (Cortex A9 Quad Core 1.6G , RK3188 CPU, GPU Mali 400 )
it run's on 4.2.2 JB Kernel 3.0.36
may someone extract the needed .ko modules from this ROM ? I hope it works...
thanks xtux
you may also write in german
I actually got 2 persons asking for a custom firmware for the XORO PAD 9719QR, so I made one, it has the kernel modules included:
I'll later pack the kernel modules for CIFS in another post if you still need them separately.
2013/09/19
@ gensior - i don't use the OTA Update Center, sorry... Flash with Rockchip Batch Tool version 1.7 again
2013/09/27
thanks for this firmware.
My device is pipo m9 pro 3g.
And I`m having 2 problems:
1. Skype crashed when calling. This problem was in official firmware, but it has been solved in 20130906 version.
2. Wifi often falls asleep. And I need to go to the settings and turn off/on it to get to work again.
Can someone help with my problems?
Thanks.
2013/09/28
Hello.
I just bought and received mine.
I have this issue - when the tablet goes off ( it's been shut down ) for a longer period than 6 hours, it does not start anymore. Black screen, and even Reset button does not help.
Will this ROM ( or anyone else ) solve this issue, and do someone here had this issue, and how did he solver it ?
Thanks in advance.
Just to let you know I have posted a new Pipo M9 pro custom firmware:
It's based on latest update from Pipo 20131011_sms_M9pro_update.img, I suppose it's designed for the 3G model and supports SMS sending, I can't checked as I don't have that tablet myself.
SonicPLD, you can try to flash this new firmware see if it fixes your problem, make sure you use Restore button while Flashing with Rockchip Batch Tool.
78 Guest(s)
Devices in use: Desktop (73), Phone (5)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
