Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M9 PRO (aka Max-M9pro) new tablet hardware that is equipped with a GPS. This firmware is designed for the model with the 3G module, it is based a latest official update dated 2013/09/09.
(M9pro_3G_OTA_chinese_update_20130909.img)
Build information:
Kernel:Â Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #312 SMP PREEMPT Mon Sep 9 13:06:15 CST 2013
Android 4.2.2 JB:Â rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20130909.130659:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU version 1.60 (free version)
- removed most Chinese and unnecessary applications, removed Certificate Center asking for product key
- increased space for applications (/data partition) to 4 GB
- NEW! kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma & Crew RKTablets, thank guys!
Download:Â kasty-pipo-m9_pro_3G-422-20130909-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a PIPO M9 pro 3G tablet to test the custom firmware.
nimrod, rifkin, wattie, ipovrixiotriton, diego.m, G B, johanfr, cpetrea1, zorrinho If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/08/29
Thanks for your hard work, it's amazing that you can do a custom rom without the tablet. The firmware works pretty well (the things that I had time to verify) but the tablet says me that there is an OTA (I thought that this firmware had the OTA included).
I've checked what happened when you try to update and this is the result: the installation begins but, suddenly, the tablet displays the Android robot dying. If you press the reset button the tablet starts perfectly again.
And I have a question, how can I mount a folder shared through nfs? I've tried it with Cifs Manager and Mount Manager but they can't mount it. Although, Xbmc mount it without any problem.
And the last question, can I edit any parameter in any file to get better reproduction? I've downloaded several players (mx player, xbmc, bsplayer) and the best for me is BsPlayer but the video jumps a little bit when camera moves fast.
Thanks again for all!
PS: English isn't my native language, so sorry for the syntax and the words wrong used.
2013/08/26
If someone wants to add multi-user on this rom, here's the how-to:
> Delete Provision.apk from /system/apps;
> Add "fw.max_users=x" on build.prop (/system), being "x" the number of users you want to add;
> Reboot and its done.
When the tablet boot up again you just go to Settings > Users > Add new user and that's it!
The following users say thank you to leeomendes for this useful post:
johanfr
2013/09/04
my pipo m9 pro 3g firmware has been upgrade to 6th september release, internet connection using wifi was excellent but i'm having problem with gsm sim card detection, any body has same experience as mine ?
if i upgrade to this release 9th september, will it resolve the problem ?
thanks in advance...
2013/09/16
rifkin said
When it comes to XBMC and getting hw decoding the solution for RK3066 chip was to run xbmc libstagefright. I tried the latest stable version and to be honest i thought it would work with RK3188 which it clearly doesnt... still runing on CPU power instead of GPU.
Source
2013/08/26
I can confirm that the rom works with M9pro 3g, antut 19200 really great progress compared to 18500 from the august release. I dont know if the 3g part works since my tablet seems to be defective, no matter how i enter my simcard it doesnt lockdown..
to make it work you have to insert the sim card and reboot
diego.m
2012/11/18
I have a Pipo M9 Pro 3G!!! Yes...It does that at times. But you need to use something FLAT to push and insert the 3G Sim properly into the slot.
The following users say thank you to G B for this useful post:
Zeggi
2013/09/04
thank you for the clue, now the sim card was detected , but still it takes to long for me, is this because hardware behaviour or can be improved by software/firmware upgrade ?
by the way, when you make a new APN and it won't save, just after input APN parameter press recent operation icon (righ side of home icon) it will save the APN you create
2013/09/16
G B said
I dont know if the 3g part works since my tablet seems to be defective, no matter how i enter my simcard it doesnt lockdown..I have a Pipo M9 Pro 3G!!! Yes...It does that at times. But you need to use something FLAT to push and insert the 3G Sim properly into the slot.
Haha seriously, i tried everything and i couldnt get it to stay... thanks for the easy help
2013/09/13
Build information:
Don't know whether you got this earlier as the forum was down. Would it be possible to make this download with a "resume" function as in Internet Download Manager. My connection is interrupted from time to time so I always end up starting again. I have not managed to complete this download yet. Thanks in advance.
That's a feature we are looking to add to our "download zone". In the meantime, you may try and find on the 3 links from the download page which is the fastest for you.
78 Guest(s)
Devices in use: Desktop (72), Phone (6)
