2013/05/03
Since I installed this rom, 2 days ago my Antutu (benchmark) score is 20257 (pipo m9)!!!:D:D
This version is included multi window function, and I can tell you it works fine!
No more lag's and everything is running very smooth!
Till now, I'm happy and having no problems for waiting till 4.4.2 is released on the M9 (not the Pro version).
Thanks admin!
You don't understand the KitKat mounting. All app game data will be stored within data. So with 1GB data you will not been able to install Asphalt 7 or other games like this. Next build will come without intSD (originally for app2sd) as this partition is useless now
2014/03/06
Issue: Status bar and Nav bar went away 3 days after flashing my M9 with this firmware. I use my M9 in a "corporate" BYOD mode which requires an "unroot". After loading the firmware, I performed the unroot process per the instructions (SuperSU). All worked fine for a couple of days then I opened the browser and away go the status bar and nav bar. How do I get the nav bar and status bar to display? I am lost without them...
2013/11/03
Are you sure you are just not confused about the hiding feature. You can hide status bar and nav bar by pressing button with double down arrows and get them back by swiping from the edge towards middle of screen. Unfortunately in some apps that swiping doesn't work and sometimes those bars disappear when I don't want them to. If swiping doesn't work you can try exiting app with hardware back-button or as last resort rebooting.
2014/03/06
Hi zabnat - I do not know where to find a button with double down arrows. I tried swiping from the edge towards middle of screen per your suggestion - nothing happened. I have rebooted countless times and no status or nav buttons ever return. I am going to reload the Pipo firmware to see if that fixes the issue.
2013/10/26
rone5811 said
zabnat said
Are you sure you are just not confused about the hiding feature. You can hide status bar and nav bar by pressing button with double down arrows and get them back by swiping from the edge towards middle of screen. Unfortunately in some apps that swiping doesn't work and sometimes those bars disappear when I don't want them to. If swiping doesn't work you can try exiting app with hardware back-button or as last resort rebooting.Hi zabnat - I do not know where to find a button with double down arrows. I tried swiping from the edge towards middle of screen per your suggestion - nothing happened. I have rebooted countless times and no status or nav buttons ever return. I am going to reload the Pipo firmware to see if that fixes the issue.
the double arrows are in the right down corner,if not ,something is wrong
2014/03/06
rone5811 said
I have loaded the Pipo firmware. All is working, but I must run this device "unrooted" in order to use it on my corporate network. I tried to install SuperSU, but it fails during the "upgrade". I have manually deleted bin/su but not able to delete xbin/su. Any thought on how to get where I need to be on this?Â
Currently Online: migfafe
78 Guest(s)
Devices in use: Desktop (63), Phone (16)
Kaydc__
jessicapeterson
Riki111
andre92
firmwarefile
mongol
