[ ROM ] Pipo M9 custom root Android 4.2.2 firmware version 1.0.9 (2013/11/30)
Thanks Received: 3177
2013/12/05 - 11:45
Here is an Android 4.2.2 Jelly Bean rooted firmware for the PIPO M9 tablet (aka Max-M9, not the M9pro version) that should work on both the 3G and WiFI tablet models. It is based on latest PiPO update 1.0.9 dated 2013/11/30.
(update#85_M9_3188_PIPO_1.0.9_NOMMS_20131130.img)
Build information:
Kernel: Linux version 3.0.36+ (root@lzj-desktop) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #85 SMP PREEMPT Sat Nov 30 09:29:40 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20131130.092954:eng/opinions-on-teclast-p90hdst-keys
ro.rksdk.version=RK31_ANDROID4.2.2-SDK-v1.04.00
Notes:
- Certificate Center and original PiPO launchers have been kept in the firmware
- any update received thru OTA may interfere with our custom firmware, we recommend not to apply any OTA update
  • root with latest SuperSU version 1.80 (free version)
  • disabled OTA updates (may cause problems, see Notes above)
  • NEW!  optional ClockworkMod (CWM) Recovery easy install package
Download: kasty-pipo-m9-422-109_20131130-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a PIPO M9 tablet to test the custom firmware.
Charly26, julz24, danielp, remix65, schuessm, BigMihca, pcnM9tab
julz24
Forum Posts: 31
2013/12/07 - 21:41
thanks for the updated FW. it seems faster and i like the reboot option and the fact that we mask the taskbar. One thing is that some downloaded games are not working and they where before. maybe i a am missing some certificates ?
thank you
The following users say thank you to julz24 for this useful post:
rover75
Mr.R
Forum Posts: 25
2013/12/15 - 22:17
Just installed this after being majorly dissapointed by the cm10 build that's out there with WiFi broken :-( was perfect besides that.
Anyway, very happy with this ROM especially after trying the other ones out there, issues I've found are that upon modifying anything in read only areas fails the first time but works the second , it's nothing I can't live with tho. A very irritating problem however is that the external memory card is read only and nothing ive done has yet to resolve this issue :'(
oh, have a few questions also....
If I update in the future will I have to reinstall everything? All depends how you do your image I assume
Any plans on doing cwm flashable Zips in the future?
Any plans on carrying on or doing your own cm builds in the future? I'm hopeng yes as I'm not at the stage to do my own just yet 😉
2013/12/15 - 22:51
Yes, future custom firmware builds should be available as CWM zip in addition to current update.img style package.
jbouv55151
2013/12/24 - 08:55
Very good rom, I am very happy with it.
Just a question, I use to hide control bar (at bottom) but I can't show it again. Any idea to do that ? Anywhere I can change seetings for that ? By restarting tablet, the bar doesn't come up anymore.
ludoke
Forum Posts: 85
2013/12/24 - 10:26
Flashing with CWM would be nice if the touch screen worked properly with it !! Not everyone has an usb keyboard.
vitha77
2013/12/27 - 20:10
I was wondering if the kernel from this would work if imported in to the new 4.4.2 M9 Pro rom, then flashed to the M9 Max? They both use 3.0.36+
Mr.R
Forum Posts: 25
2013/12/29 - 13:44
ludoke said
 Cwm works just fine for me, cwm generic flashed from arctools app 🙂
I swipe up from the bottom with a finger in each corner to bring it back, only way it seems to work
Meegolo
2013/12/31 - 11:21
Hello, Y did he quickboot for this version because my pipo m9 max starts 1.32mn
ludoke
Forum Posts: 85
2013/12/31 - 11:48
Mr.R said
ludoke said
Mr.R said
ludoke said
 Cwm works just fine for me, cwm generic flashed from arctools app :-
With physical volume buttons or touch ?
Thouch isn't working well for me,it's nearly impossible to select an option with my finger and to swipe to an other option.
Mr.R
Forum Posts: 25
2014/01/02 - 00:38
Touch, haven't even tried with buttons
educuritiba
2014/01/14 - 16:57
Any kernel for PIPO M9 Max that makes possible to overclock it? Thanks!
ludoke
Forum Posts: 85
2014/01/14 - 17:13
ludoke said
Mr.R said
ludoke said
Mr.R said
ludoke said
That's what im talking about,it's not usable whithout phisical buttons and without usb keyboard.(with keyboard it's workingbut it's not the intension)
zabnat
2014/01/22 - 22:19
I'm experiencing really weird behavior. I'm not exactly sure if it is this firmware or something else, but previously I was using kasty-pipo-m9-422-106_20131025-rooted4 and didn't notice these things.
Problems arise when I connect the charger and put the device in sleep mode (press power button once). Device seems to randomly wake up (screen comes on) and the battery is charging very slowly or not at all. When I set the display to stay always on when charging the battery charged with normal speed.
satmel
2014/01/23 - 04:41
Hi guys,
Any screen shots?
Does it support multi-screen?
Cheers.Laugh
37 Guest(s)
Devices in use: Desktop (33), Phone (4)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
