Here is an Android 4.2.2 Jelly Bean rooted firmware for the PIPO M9 tablet (aka Max-M9, not the M9pro version) that should work on both the 3G and WiFI tablet models. It is based on latest PiPO update 1.0.6 dated 2013/10/25 and offers the multi-windows feature.
(update#66_M9_english_1.0.6_NOMMS_20131025.img)
Build information:
Kernel: Linux version 3.0.36+ (root@lzj-desktop) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #66 SMP PREEMPT Fri Oct 25 09:11:19 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20131025.094422:eng/opinions-on-teclast-p90hdst-keys
ro.rksdk.version=RK31_ANDROID4.2.2-SDK-v1.04.00
Notes:
- Certificate Center and original PiPO launchers have been kept in the firmware
- root with latest SuperSU version 1.65 (free version)
- NEW! optional ClockworkMod (CWM) Recovery easy install package
Download: kasty-pipo-m9-422-106_20131025-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a PIPO M9 tablet to test the custom firmware.
sho25, cracktech, zabnat If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
Nope not correct! I never had any problems with writing on sdcard since my first ROM build #274, I amde my backups directly from Titanium or ROmToolbBox on the sdcard from the first day out of the box. Kasty ROm has eliminated all that since, like ever.
I belief you didn't wipe the internal sdcard properly or you used a quick format for the sdcard, that is why I streesed here that I do an sdcard format from the settings menu and then go in and manually delete any left over directories inthe insternal sdcard before I start flashing, belief me. I lost wifi connections for 4 months (on another brand 10inch pad because of the leftover/junks inside the internal sdcard before I update to CM10.2. Only after a deleting and formatting the internal sdcard leftovers and reflashing a fresh copy of ROM did I manage to get back my wifi. the sdcard not being able to be written on KASTY ROM that is a first.Did you read through the forums not one complains regarding this issue. Maybe you have to relook at how your start your flashing procedures.
2013/10/15
hi, sorry for my poor english, i have a pipo m9 PRO.
it has 1920*1200 display. it is good. BUT...
but gpu of this tablet can not handle its hi res. display ass well.
i mean pipo max m9 with 1280*800 display runs clearly faster and smoother than pipo m9 PRO 1920*1200
So...
so i want to install rom of pipo m9 max on my pipo m9 PRO. so i can have a tablet with 1280*800
can i use this rom???? does it break my tablet??
i have already use some apps like "lcd density" and "resolution changer" with no succes.
2013/03/30
Absolutely not. Flashing ROM from different tablets may brick your tablet. There are too many difference in the hardware (LCD, touch controller, etc.)
The following users say thank you to spectra9 for this useful post:
navidx
2013/03/30
Maybe you can try http://dottech.org/112261/android-review-resolution-changer-app/?
2013/10/03
new version on 29/10/2013
The firmware indicated "pure" version, no bloatware added ,no extra apps, no Pipo Launcher, no nothin'......
please create a custom roms rooted whit this
thanks
Duplicate work my friend and you dont order people around like that! It is the same as the just released KASTY 30/Oct ROM.
If you like it so much why dont you flash the ROM yourself and root it yourself! I have attached here the Rooting method for your use.
Like cracktech, I suspect this is not a real update, but just a repack of previous #66 firmware you see in post #1.
If anyone has seen a revision history for that "new version" for 29/10/2013, or tried it and can confirm it works better than previous version (please state which bugs have been resolved) I'll surely do a custom firmware update.
2013/10/03
new update update#81_M9_1006_3188_1.0.8_3G_NOMMS_20131112
please create custom roms with this thanks
2013/04/28
hello I have installed the stock firmware #66 + root.
I have installed the CWM, apparently, always successfully but I just can't enter in CWM?
This is not the first time I do this procedures but this time when I try to go into CWM always get the android logo lying down with the open belly.
I have tried to install rom manager and its saying the I have CWM and TWRP installed.....
The CWM I have installed as usual with a flash tool and in the respective locations. I tries x0001000 and x0001400
Can someone give me a hand here?
Pipo P9
68 Guest(s)
Devices in use: Desktop (59), Phone (9)
