[ ROM ] Pipo M9 Android 4.4.2 KitKat custom root firmware (2014/06/04)
2014/06/05 - 18:20
Here is latest Android 4.4.2 KitKat rooted firmware for the PiPO M9 (aka Max-M9) tablet.
This firmware based on latest update from PiPO dated 2014/06/04.
Please note this firmware is designed for the older M9 model (1280x800 display) and is not compatible with the newer PiPO M9 Pro models.
(update_DS1006_4.4_20140604.rar)
Build information:
Linux Kernel: Linux version 3.0.36+ (root@lzj-desktop) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #40 SMP PREEMPT Tue Jun 3 16:19:18 CST 2014
Android 4.4.2: rockchip/rk3188/rk3188:4.4.2/KOT49H/eng.root.20140604.100616:eng/opinions-on-teclast-p90hdst-keys
RK3188Loader(L)_V2.10.bin
  • root with latest SuperSU version 1.99r3 (free version)
  • increased space for applications (/data partition) to 4 GB
  • added Google Experience Launcher (GEL) in addition to PiPO's stock launcher
  • use optional package to fix broken apps (Contacts/People and Calendar sync)
  • temporary fix for multi-user support, thanks to didierm
  • optional ClockworkMod (CWM) Recovery easy install package
Notes:
- you should get an error saying "E:failed to mount /metadata (Invalid argument)" on first boot, you should have no problem ignoring the message.
Download: kasty-pipo-m9-442-20140604-rooted4_mu.zip
If you like our work, please support us to keep the site alive and contribute to our efforts.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a PIPO M9 tablet to test the custom firmware.
If you later want to downgrade and flash an Android 4.2 (or older) firmware, please follow this tutorial.
Thanks mattiesragWink
Oma7144, matosribeiro, sahor, oOBladeOo, gncysf, ErBotijo, elkatze, exca, digitaldream, the tester, dtolos, ClaudioPM9, dlkarakashev, xancin
yossiv69
2014/06/06 - 12:13
As I wrote on Facebook of PIPO
I installed this version now
And still have a problem with Hebrew and Arabic (RTL)
I get error "Unfortunately, System UI has stopped."
Is there a patch for this problem?
Thanks Yossi
The following users say thank you to yossiv69 for this useful post:
elkatze, Tai1988, averhoy1
yossiv69
2014/06/06 - 14:17
I installed the above version and got a black screen
I tried three times and still got a black screen
I tried to go back to your previous version and tried to go back to the original version
And I'm now getting its touch screen not working
2014/06/06 - 15:04
yossiv69,
Can you confirm you are flashing this firmware on the PiPO M9 (Max-M9) and not a M9 Pro ?
yossiv69
2014/06/06 - 15:23
I have a tablet-type M9 PRO MAX PIPO
I managed to fix the problem after I installed 10 times in different versions
I returned to version 4.2.2 and everything worked
Then again I installed the latest version before 4.4.2 you have posted on the forum
This version
http://www.arctablet.com/blog/forum/pipo-max-m9/rom-pipo-m9-pro-android-4-4-2-kitkat-custom-root-firmware-20140504/
2014/06/06 - 15:27
We are writing it one more time, the firmware in this topic is for the PiPO M9 (Max) and is not designed for the PiPO M9 Pro. If you have a M9 Pro, don't flash it and use a M9 Pro firmware in from this forum section.
yossiv69
2014/06/06 - 15:51
gabrys666
2014/06/06 - 19:58
Just installed this ROM, seems very promising. Copying files by USB is much faster than on 4.2.2 and the tablet doesn't freeze up completely when installing/updating apps.
mainstream
2014/06/06 - 20:45
Thanks, ill try this anytime soon.
Seems it payed of that everyone complained to pipo about releasing a kitkat version voor de max m9 :D
mainstream
2014/06/06 - 22:21
yossiv69 said
I just downloaded it from the link you gave me
https://www.dropbox.com/s/09dia5a2ozqfw1x/%D7%9C%D7%9C%D7%90%20%D7%A9%D7%9D.png
It explicitly says pipo max m9! Not pro.
orphenreigns
2014/06/08 - 13:04
Hi,this is my problem,when i was updating my Pipo Max M9 with the new Kitkat rom on the forum with RK Tool 1.7,it stopped at "TEST DEVICE START 100%",i can't go further and now the only way my PC recognize the tablet is when i push and hold the power button ( if i stop to push the button my pc don't recognize it anymore )...The tablet don't turn on anymore,just a black screen and i can't do nothing...Some1 can help me? Thx and sorry for my english.
matosribeiro
2014/06/08 - 22:48
Downloaded sucessfully and it seems to be working great. Is the kernel for the kitkat update available as a single download, i would like to overclock the cpu speed in my tablet.
Thanks for your hard work.
coolics
2014/06/09 - 12:25
      I had the same problem too.  Later found out that this ROM is not for all PiPO M9 units.  Some units (older I presume) have single NAND flash chip.  Now your only option to revive your tablet is as follows:
1. Open back cover
2. Connect charger to tablet, press power key and connect USB cable to computer
3. After you see RkAndroid Loader device found in RKAndroidTool, with power key pressed short pints 8 and 9 on the Intel NAND flash chip4. Once the display shows RKAndroid maskrom device found in RKAndroidTool, Erase IDB
5. Then flash any other ROM to get back tablet to life.
c
mrbomb
2014/06/09 - 21:20
coolics said
1. Open back cover
I have the same problem.
I followed step 1 and 2.
Should I see RkAndroid Loader device found in RKAndroidTool before I short pints 8 and 9?
In RKAndroidTool I see: "No Found RKAndroid rock usb".
What do I do wrong?
orphenreigns
2014/06/10 - 00:24
mrbomb said
coolics said
1. Open back cover
What do I do wrong?
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=b7177c4315&post=43078&forumid=157','W4fY5kTX1u',false,'fpN3MKr3JM4');
What are pints 8 and 9,i don't find them,can i have a screenshot or something like that for understand? Thx.
66 Guest(s)
Devices in use: Desktop (59), Phone (7)
