Pipo Max M9 + Sandisk micro sdhc 64gb
Error using 64gb memory card
Marcus333
Forum Posts: 11
2014/01/04 - 20:18
Ok
I tryed connect memory card via usb host (external card reader) and formatted in my tablet.
No problem read and write to this card. After inserting this memory card to tablet (internal card reader) grrrrrrrrrrrr
I see Damaged card ( try reformatting)
Thanks but still dont work :-(
hmsr21
United Kingdom
Forum Posts: 12
2014/01/05 - 03:09
Hi guys, sorry to be the bearer of bad news but after reading through your posts I can spot 2 problems with what Marcus333 is trying to do.
First of all and the most basic problem is that FAT32 cannot read anything larger than 4GB.
Go on google and search for FAT32 wiki.
The second problem is that, according to the tablet specs, it can only have an expansion card up to 32GB.
It doesn't say anything about 32gb partitions on a 64GB card.
My guess is that if you have tried everything to make this card work on your tablet and if you tried to read it on your computer successfully, the problem must be in the tablet's limitation of working with anything larger than 32GB.
If I were you I would just get a 32GB SD card and be done with it.
Hope this helps!
Pipo M9 Pro WiFi + 3G rooted JB 4.2.2
Marcus333
Forum Posts: 11
2014/02/11 - 11:04
I tested this card in PC - it seems the card is faulty.
Is here anybody who is using 64gb card in Pipo Max M9?
Marcus333
Forum Posts: 11
2014/02/23 - 09:06
Hallo all,
The problem with my card is resolved - the card is Fake - the card capacity seems as 64gb but after special testing is only 8gb - another Sandisk 64gb works perfectly without any problem.
Thanks for support and nice day Marek :-)
asagy
2014/07/03 - 15:30
The video is great and the idea valid. I just downloaded the software and formatted a 64MB card, loaded it and inserted into my Pipo M9.
Will try a 128card next...
Thanks cracktech CoolCoolCool
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2014/07/03 - 23:18
Most welcome, I almost forgot about this topic, it has been a while since anybody brought this topic up. Good that you read most of the postings in the Forum before embarking on a new thing unlike some people who just went in blindly and then scream  for help!
Just out of curiosity arent you pushing a bit for 128Gb storage since that is an expensive card and if it fails you are going to be left it to use only on your PC?
Excellent!
69 Guest(s)
Devices in use: Desktop (60), Phone (8), Tablet (1)
yung1961
ondateste
lilila3
Anatrop
antoniors021
wemiy54158
