2013/12/17
Hallo,
I buy for my Pipo Max M9 new Sandisk micro sdhc 64gb class 10 memory card. But i have problem using it. Tablet is rooted newest Kasty rom, memory card formatted Fat 32 slow.
Tablet recognize memory good - as 64gb, but if i want write on card i see error message : Broken pipe or I/O error.
Please can you help me ?
Nice day Marek
Hell Marek,
If you copy files to the card on a computer, can you see and access the files from on the card when you put it in the tablet ?
Which application on the tablet is giving you the error message ?
I dont think M9Pro can access 64Gb sdcard. It is stated only upto 32Gb is expandable/accessible.You should not have problems accessing 32Gb. repartition the sdcard to 2 32Gb partition from your PC using EASUs Partition Master then at least it can access the first 32Gb partition.
Marcus333 said
It dont work. Tablet say : Damaged card try formatting. Cant format card in tablet
Didnt I say to repartition it on the PC using EasUS Partition Master you cant format or repartition it on the device itself , thats a formula for a disaster to your sdcard.
Now reformat (full format NOT quick format) on the PC and then repartition it using EasUS Partition Master (google it and download the free version) into 2X 32 Gb partition.
OR Did you mean AFTER you repartition it into 2X 32Gb partition , THEN it gives you the error message??
I assume that you are well verse in Windows, we dont give up that easily. As I was made to understand it the problem lies with Win not letting us format FAT32 to anything higher than 32Gb , that seems to be the problem.
So you have to repartition the card back to a single partition of 64Gb using either FAT32/NTFS first, to get a single 64 Gb partition back. Then usse the GUI Format.exe file in the attachement (includes instructions) to format to FAT32 64Gb (the author uses this for his Android which also is limited to originally 32Gb now he is can access 64Gb minus a few Mb)
So there is a trick to getting Android to recognise a 64Gb sdcard not that straight forward.
See video of the author doing his stuff (instructional video):
asagy, adminAbout Me LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
Try a low level sdcard format apps from Windows (I had it it somewhere in Clouds storage).
Try to google for it. If you managed to do low level format of the sdcard then you redo as in the video and the attached app.
Did I understand you correctly, that you can format upto 16Gb and access it? No it is not the sdcard reader if your device can read 16Gb sdcard. Upto this point I think the card is not damaged but the 2nd 16Gb partition is not accessible as the video says.
2013/12/17
Hallo,
I tryed another memory cards in capacities 16gb and 32gb - no problem using it.
If i insert 64gb memory card - formatted low level fat 32 (64gb) or card is divided 2 partitions fat 32 ( 2x32 gb) tablet write Card is damaged try reformatting it.
I read in forums Pipo max M9 pro can work with SDXC 64 gb, but my experience are bad.
Is here somebody with working Pipo and 64gb memory card ?
2013/08/28
In W7 - put sdcard (I´got a Sd 64gb like you) - Open EaseUS Particion master - select all partitions in your sdcard and erase all, apply changes - sure sdcard don´t have any partition - select sdcard and push format like a Primary FAD32 and put any name at your sdcard and apply changes. It work to me sdcard.
2013/08/28
Jumm sdxd car... If it work in pc it's not the problem and if pipo works with 32gb, it is not a problem... I install 442 android last week but in 422 sd card works too... The diferent is that I got a pipo pro and it would be the difference.
It's a lot of work but you could try to reinstall rom, in my pipo with 442 there is a bug, ram sdcard and 64gb sdcard have the same root name (both seems like sdcard in file explorers but works) and in last rom 422 the root was dificult to find those was my problems. Sure when flash rom, your pipo format the ram memory and does not a error message while install.
You can install clockmod recovery before install new rom and make a copy of your present rom to recover it if you need.
Heyy first, are you try to conect sdcard in usb host port and format in android or in other android device? It would work and is easy to try.
55 Guest(s)
Devices in use: Desktop (49), Phone (6)
