2013/09/27
haha, now out version 10/30. I'm finishing downloading. I also like vodka, but mixed with lemon and sugar, nicknamed "caipirinha". I have a welding apparatus and maintenance tools (hammer). I will test this last update, hence my next procedure will be that. Because I bought two tablets. One for me and one for my father. Mine is white and he is black, and both with the same problem.
2013/09/27
muop said
qnx123 said
1. remove the cover and check the wires
Can you post the procedure to remove the cover for Pipo M9Pro.
Thx
I found this video. specific tools will be necessary to not end up damaging your tablet. Updated my tablet to the latest firmware, not shifted much, but the principle seems more stable
2013/10/31
I did not recommend you to do any modification. Subject should be investigated further. Because only with one antenna 3+4 - it's wifi - the wifi itself works perfectly, but without other antennas 3g and gps are useless
so if you have only wifi variant, check the wires, of have 3g, stay tuned...
2013/09/27
qnx123 said
I did not recommend you to do any modification. Subject should be investigated further. Because only with one antenna 3+4 - it's wifi - the wifi itself works perfectly, but without other antennas 3g and gps are uselessso if you have only wifi variant, check the wires, of have 3g, stay tuned...
I took apart my tablet. It has 3 wires, I still did not understand. Gotta fix the three?
2013/11/08
After having tested differents setting on by box and other, my problem of slow speed, disconnexion or no connexion with WIFI are still here. So, I have decided to open my tablet and check if there is a short cut on or not. There are the result :
1-2 : not concerned because I dont have : I think this one is 3G because my tablet is without 3G (only WIFI)
3-4 : OK, no short cut
5-6 : short cut
My problem is that I don't know between 3-4 and 5-6 wires, wich one is WIFI and GPS. I think 3-4 is WIFI and 5-6 GPS. Someone is able to confirm me ?
If it is so, why have I got WIFI problems because short cut is on 5-6 (GPS ?).
Thanks for your help.
2013/09/27
After having tested differents setting on by box and other, my problem of slow speed, disconnexion or no connexion with WIFI are still here. So, I have decided to open my tablet and check if there is a short cut on or not. There are the result : 1-2 : not concerned because I dont have : I think this one is 3G because my tablet is without 3G (only WIFI) 3-4 : OK, no short cut 5-6 : short cut  My problem is that I don't know between 3-4 and 5-6 wires, wich one is WIFI and GPS. I think 3-4 is WIFI and 5-6 GPS. Someone is able to confirm me ?  If it is so, why have I got WIFI problems because short cut is on 5-6 (GPS ?).  Thanks for your help.
1-2 GPS
3-4 WI-FI
5-6 3G
2013/11/08
Thanks for your answer, but I'm talking about the picture posted by qnx123, and I'm afraid you are wrong
Because my tablet is only WIFI and GPS (no 3G), there are 2 wires connected :
3-4 : GPS
5-6 : WIFI
I just have found this info
SO, that mean my my problem is on the WIFI wire )
Now, I will try to fix it
2013/09/27
Thanks for your answer, but I'm talking about the picture posted by qnx123, and I'm afraid you are wrong Because my tablet is only WIFI and GPS (no 3G), there are 2 wires connected : 3-4 : GPS 5-6 : WIFI I just have found this info
) Â Now, I will try to fix it
zizou0029 said
Thanks for your answer, but I'm talking about the picture posted by qnx123, and I'm afraid you are wrongBecause my tablet is only WIFI and GPS (no 3G), there are 2 wires connected :
3-4 : GPS
5-6 : WIFI
I understand. Look at this link here, is a forum of the same pipo. I put here as was specified by him. If you look at where each wire goes, you will desobrir who is who. The smaller antenna that sits in a corner is the GPS (1-2). The middle, where it goes on the side of the tablet is WIFI (3-4). And finally, where will the other side, near the battery or LCD is 3G (5-6)
http://www.pipo.cn/bbs/forum.php?mod=viewthread&tid=4207&extra=page%3D1
2013/11/08
OK but look at this topic : http://www.arctablet.com/blog/forum/pipo-max-m9/pipo-m9-pro-gps-performance/Â on post 14 and 16. Tito2k has asked to PIPO and they have answered wich one is WIFI.
So who is wrong, who is right ?
2013/09/27
zizou0029 said
OK but look at this topic : http://www.arctablet.com/blog/forum/pipo-max-m9/pipo-m9-pro-gps-performance/Â on post 14 and 16. Tito2k has asked to PIPO and they have answered wich one is WIFI.Â
weird. I'm basing as I told you. In the first post is the two antennas gps and wifi welded together. But after this the regular photo. Tomorrow I will see it better and redo all the wiring of these antennas. But as I passed him that link the Chinese forum, the Xingling dismounted and told who was who. So I believe the antenna corner is the gps and the middle is the wifi.
2013/09/23
I had the same problems with wifi and I solved by changing the settings of my router tp-link, I changed the bandwidth of the wifi channell from 20/40 MHz to 20MHz and wifi problems are gone. It is clear that this solution is only valid with the router with 802.11n if you have any problems with the 802.11g standard try to change from short to long preamble.
77 Guest(s)
Devices in use: Desktop (67), Phone (10)
sidor
houssmen
qarolus
dav512
tgergely2012
avv2011
