PiPO M9 PRO GPS performance ?
slackerlx
Forum Posts: 52
Thanks Received: 9
61
2013/10/21 - 02:06
I sincerely believe that it varies from tab to tab.
I cannot render such results yet it's the same tab on the same Rom. Pity
segundus
62
2013/10/21 - 10:18
cracktech said
Mr-Kev said Iv'e downloaded the gps.config now where do i put it on my tablet ? And i changed asia .pool to uk.pool is that correct ? Thanks.
 NO!NO! the asia.ntp.server address ishould be changed to europe! Please change the continent ntp.servers
server 0.europe.pool.ntp.org
server 1.europe.pool.ntp.org
server 2.europe.pool.ntp.org
server 3.europe.pool.ntp.org
and when you see the my.pool.ntp.org (my locale)
change that to uk.pool.ntp.org
Please3 recheck after the editing , when you save it it doesnt change to gps.config.txt if this happens zipped
it up 7zip and edit inside the 7zip to the original extension *.cofg and then unzipped it and put it in the
system/etc folder and make sure the ownership is set to root/root.
Dont forget to use in conjunction with the download app from Playstore NTPSync it will request for root access and will
recheck/synchronise your time after every reboot or periodically.
I have attached the uk gps.conf for you.
  Thank you very much cracktech, I'll do just that.
Hi, sorry not clear on 2 things in your posts:-
1.... place file in system etc. What is etc do you mean put it in system with existing files ?
2. Your posted "UK" gps.config file contains the following which does not appear to be UK settings.
DEBUG_LEVEL=5
DEFAULT_USER_PLANE=TRUE
ENABLE_WIPER=1
DEFAULT_AGPS_ENABLE=TRUE
DEFAULT_SSL_ENABLE=FALSE
INTERMEDIATE_POS=1
ACCURACY_THRES=2500
REPORT_POSITION_USE_SUPL_REFLOC=1
NTP_SERVER=my.pool.ntp.org
NTP_SERVER_1=0.my.pool.ntp.org
NTP_SERVER_2=1.my.pool.ntp.org
NTP_SERVER_3=2.my.pool.ntp.org
NTP_SERVER_4=asia.pool.ntp.org
NTP_SERVER_5=1.asia.pool.ntp.org
NTP_SERVER_6=2.asia.pool.ntp.org
NTP_SERVER_7=3.asia.pool.ntp.org
XTRA_SERVER=http://xtra1.gpsonextra.net/xtra.bin
XTRA_SERVER_1=http://xtra2.gpsonextra.net/xtra.bin
XTRA_SERVER_2=http://xtra3.gpsonextra.net/xtra.bin
SUPL_HOST=sls1.sirf.com
SUPL_HOST=sls2.sirf.com
SUPL_HOST=supl.google.com
SUPL_HOST=supl.nokia.com
SUPL_PORT=7276
C2K_HOST=default
C2K_PORT=0
SUPL_TLS_HOST=
SUPL_SECURE_PORT=7275
SUPL_NO_SECURE_PORT=3425
SUPL_TLS_CERT=/etc/Security/otacerts
CURRENT_CARRIER=
common
Sorry for my lack of understanding but do I need to alter these entries?
Thanks,
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
63
2013/10/21 - 10:39
froc111 said
Yesterday I installed Pipo_M9Pro_RileyROM_1.8 and GPS is better than before!! Did anyone test this also?
Please remember this is the KASTY ROM forum, Yeah I am currently on RILEYS ROM and the GPS is No better or worst than before, i have to do the gps.conf trick to get it going again. I am on RILEYS ROm coz I need the pad badly while we at KASTY sort the "provision error" problem.
cracktech
Malaysia
Forum Posts: 432
64
2013/10/21 - 10:48
DEBUG_LEVEL=5
ENABLE_WIPER=1
INTERMEDIATE_POS=1
ACCURACY_THRES=2500
SUPL_PORT=7276
C2K_HOST=default
C2K_PORT=0
SUPL_TLS_HOST=
CURRENT_CARRIER=
common
Thanks,
I dont know where the gps.conf for my locale got to you I only uploaded the uk_gps.conf for another user maybe you downlaoded an earlier gps.conf as an example for those in the know.
so here it is the uk gps.conf. file and dont forget to use it in conjunction with NTPSync.(down load it from Playstore)
Change the continent to your contimnent Europe,Asia,NorthAmerica
& country like "uk" to your country. Yeah like I said just copy the file into system/etc folder and check for the ownership changed that to root/root. If you dont know where the system/etc/ folder is please dont try this. Familiarised yourself with Android file structure first.Since our ROM are rooted already it is as easy as copying from one  location (your external sdcard) into the sytem/etc folder.
Igor101
slackerlx
Forum Posts: 52
Thanks Received: 9
65
2013/10/23 - 11:59
I've been wondering if Archos tablet 10.1 has the same issues with GPS performance. It also has an aluminium back cover. Does it disturb the signal? Or it just PiPO thingarchos_101platinum_back_hidef_6.jpgImage Enlarger
Thanks Received: 3170
66
2013/10/23 - 12:09
slackerlx,
You may ask in the Archos Platinum forum section Wink
Usually tablets with aluminum back have lower "radio" performance with things like WiFI or GPS, but this also highly depends on the quality of the components, chipset used and antenna placement.
ludoke
Forum Posts: 85
67
2013/10/31 - 19:31
Also very bad GPS .I have used a GPS bluetooth mouse and i get fix instantly.
My conclusion is ,the problems are due to the antenna or the alu backcover or a combination of those  2.
Mobius48
Forum Posts: 12
Thanks Received: 4
68
2013/11/05 - 17:15
Just got a Pipo M9 Pro (without 3G) and came looking for answers to the poor GPS performance problem.  Interesting reading in this thread.  I'm a retired GPS engineer so here are some clarifications.  First, the GPS satellite signals are very weak and are affected by atmospheric conditions, signal path obstacles, antenna orientation, and reflections off of surrounding buildings.  As pointed out, the M9 design is the basic problem.  The surrounding electronics and the aluminum shell attenuate the signal.  From what I gather, the gps_config file really just sets your home location.  This will not help with the satellite signal problems but will help the software to focus its search for satellites.  I'm assuming that there is some sort of satellite almanac data embedded in the software otherwise the position config file wouldn't help at all.  And knowing your home location won't help as much if you travel any distance.  I've only tried the built in GPS Info program so I don't know if other programs work better but there are a couple of software features that would help.  First, the software should have a way to save the last known position fix in non-volatile memory.  That would eliminate the need for a position config file and would allow the GPS to start faster even when you are not at your home location.  Second, the software should save the downloaded satellite ephemeris data in non-volatile memory.  That would also result in faster position fixes.  As for hardware fixes, the antenna would really need to be external to show very significant improvement.  For those who really want to use the tablet for navigation in their car, you might consider buying an inexpensive USB GPS mouse.  Personally, I just use a car GPS when I travel.
The following users say thank you to Mobius48 for this useful post:
admin, cracktech, Dstephan
beppedomani
Forum Posts: 20
69
2013/11/05 - 17:35
M9 pro + PIC GPS fix (a italian script to fix gps.config and gpsconfig.xlm file (need root)) in Italy fix satelite very well and with Copilot europe has a HIGH PRECISION navigation!!
No need hardware modifications or external gps usb key.
ludoke
Forum Posts: 85
70
2013/11/05 - 19:19
Please ,link to this fix please
ludoke
Forum Posts: 85
71
2013/11/05 - 19:28
When i use GPS TEST after awhile i got fix (6 a 7 sats in use) indoors . The next day when i start GPS TEST it takes approx 10 minutes to get fix again. As you stated i also think that the fix is not be saved.
When i connect my gps bluetouth mouse i get instant fix
worldofandroid
72
2013/11/06 - 17:01
link pls ... thx
ludoke
Forum Posts: 85
73
2013/11/06 - 17:50
M9 pro + PIC GPS fix (a italian script to fix gps.config and gpsconfig.xlm file (need root)) in Italy fix satelite very well and with Copilot europe has a HIGH PRECISION navigation!! No need hardware modifications or external gps usb key.
If you makes us hungry we like to have the link to it
beppedomani
Forum Posts: 20
74
2013/11/06 - 19:42
The tool is able to: root, fix gps, reboot bootanimations.
Pleas wait for ending beta testing...
The following users say thank you to beppedomani for this useful post:
ludoke
bernie7
75
2013/11/21 - 14:30
Keeping in mind that your tablet has root access, place the file into /system/etc Note: If you use ES file manager you'll need to enable Root explorer there under tools category, then pressing on Root explorer takes you into submenu where you choose to Mount R/W = select RW. Do remember to deselect the option when you finish copying your files. You don't want write root access for everyday work
When I click Root Explorer in ES File Explorer, the message " Sorry, test failed. This feature cannot run on your phone". What did I miss?
41 Guest(s)
Devices in use: Desktop (36), Phone (5)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
