PiPO M9 PRO GPS performance ?
Mr-Kev
Forum Posts: 21
31
2013/10/03 - 18:40
Just bought my pipo m6 pro hope i don't get problems with this one...
slackerlx
Forum Posts: 52
Thanks Received: 9
32
2013/10/04 - 01:01
ANDever said
Like this??
NTP_SERVER=europe.pool.ntp.org
NTP_SERVER_1=0.europe.pool.ntp.org
NTP_SERVER_2=1.europe.pool.ntp.org
NTP_SERVER_3=2.europe.pool.ntp.org
NTP_SERVER_4=pl.pool.ntp.org
NTP_SERVER_5=1.pl.pool.ntp.org
NTP_SERVER_6=2.pl.pool.ntp.org
NTP_SERVER_7=3.pl.pool.ntp.org
Looks right to me. I would also change ACCURACY_THRES to 5000. Although you might contact cracktech for details Wink
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
33
2013/10/04 - 14:53
Yup! If it is your locale YES!
cracktech
Malaysia
Forum Posts: 432
34
2013/10/04 - 15:03
Mr Kev,
ALL of PiPo's M9Pro tablet have this one issue with the GPS, this gps.cfg  isnt end it all solution but it did help in solving someones gps fix problem. So I recommend you use it . This is not an isolated case, it is also because of the metal backing that shields the signal from the satellites.
The long term solution would be  for PiPo to redesign their antenna and placement of the antennae.
ANDever
35
2013/10/05 - 14:10
Still no luck finding ANY satellite.. I will try to change that ACCURACY too. but i dont think it will help. Is it only me who cannot find literally ANY satellite even for a second? Maybe my tablet is broken..
Mr-Kev
Forum Posts: 21
36
2013/10/05 - 15:14
cracktech said
Mr Kev,
Thanks cracktech, iv'e ordered myself the pipo m6 pro (retina display) 3g gps wifi bluetooth etc...will let you know what the gps is like on this one when it arrives Thursday hopefuly sooner.
gskde8dse
37
2013/10/11 - 12:11
i can find some satellites when test
cracktech
Malaysia
Forum Posts: 432
38
2013/10/13 - 04:25
I just obtained another trick to make the GPS capture faster and more accurately. I just tried the trick out and got GPS fix in my house (it could never do that before)  and not just outside flat under the sky.
But first you must know which NTP server you are suppose to be ON. you will have to fill this in the NTP server input like mine "my.pool.ntp.org" it needs you to fill in only the first character and then set the time. While writing this msg to you all it is still locked to at least 3 sat out of the 6 I can see.It will be full 6 sat if I am outside the house.
Google playstore links : https://play.google.com/store/apps/details?id=org.ntpsync
The time need to be sync with the NTP server time to get the GPS to lock on.
slackerlx
Forum Posts: 52
Thanks Received: 9
39
2013/10/14 - 09:14
Would you, please attach your own GPS.conf file here so we can copy that success?
Do you also use wifi flag on or off?
cracktech
Malaysia
Forum Posts: 432
40
2013/10/14 - 14:30
Here for the second time I attached the GPS files and by the way the WiFi is "on".
beppedomani
Forum Posts: 20
41
2013/10/14 - 16:55
slackerlx
Forum Posts: 52
Thanks Received: 9
42
2013/10/14 - 19:43
Is Wi-Fi on? So, it's assisted GPS then. Without Wi-Fi it may not catch any. Thanks nonetheless
cracktech
Malaysia
Forum Posts: 432
43
2013/10/15 - 10:24
The Faster GPS app will delete all of the settings that you have made according to my gps.conf and leave it a very basic ntp.server settings only, ALL it does is it will write what I have wrote in the gps.conf file and deletes ALL other settings that we have set-up for ourselves. ALL other additional settings will be deleted. Not too good if you are rooted and can manipulate the gps.cfg settings to your hearts content.
Mr-Kev
Forum Posts: 21
44
2013/10/15 - 13:26
Thanks cracktech & slackerlx That should be the gps sorted, now how exactly do you get it to use data via your sim card what settings do you have to use ? As there is no English instruction manual available.
froc111
45
2013/10/15 - 22:18
I did the gps.conf an now the gps is nice. Neary lLiving_roomSamsung.pngImage EnlargerSamsung_Garden_bearbeitet-1.pngImage EnlargerGarden_Screenshot_2013-10-15-21-31-30-1.pngImage EnlargerLiving_RoomScreenshot_2013-10-15-21-35-27-1.pngImage Enlargerike other tablets!Look at the photos - the second tablet is a new galaxy tab 3 7". Thank you cracktech! Great Job.
83 Guest(s)
Devices in use: Desktop (73), Phone (10)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
