PiPO M9 PRO GPS performance ?
Beto82
151
2014/01/07 - 20:59
Bad luck...
Y try Finless 1.5 in combo with NTPsync, and the same result, no GPS.
But another bad notice Wifi signal is bad, i have full power but i lost signal every 10 or 20 segs...
skippie
Forum Posts: 17
152
2014/01/10 - 19:10
same here, can't get it to work on Fingest 1.5
Viljar70
153
2014/01/10 - 21:57
I have a PIPO M7 Pro (3G) (running: kasty-pipo-m7_pro-422-ota_106_20131130.img)
and also the same problem - It can find max 1-2 satellites and never fixes a location.
I tried the gps.conf file (modified it for Estonia) but it did nothing for Me, if anything, made it worse..
also tried to use the GPS-HELP-File-Auto-install-via-ADB.zip but it said Device Not Found
Tried the NTPSync program - nothing
Should I try to copy over the other files (like in the GPS-HELP-Files_FINLAND.zip - posted on Page 6 of this thread)
Any other suggestions ?
Edit: Here is a video of how to resolve the M9 WiFi connection and reception issues:
Wonder, if same method could be used to fix the GPS issue ?!
I would use coax cables for both wires tho (using only middle strand)
ludoke
Forum Posts: 85
154
2014/01/11 - 11:34
My GPS is very good now on my Finless 1.5
I've installed:
NTPsync
Gps status
Gps test
Faster Gps
No config files or what so ever,quicker fix than ever before for me
trel0s
155
2014/01/18 - 16:13
So right now the cracktech gps fix files given in post #143 do not work?
If it works, when I travel form Greece (xx=gr right?) to Italy and then to France I will have to change the gps.conf file every time?
 thank you in advance!
ludoke
Forum Posts: 85
156
2014/01/18 - 17:16
See post 154,i have a fix i 1 minute ,in view :10 and in use :6 after 2 minutes INDOORS !!!
On my Samsung Galaxy S4
23 in view after 1 sec.
11 in use after 3 secs also indoors
What a difference,altouch i think my PiPo is good about GPS considdering the problems people have with it
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
157
2014/01/18 - 19:58
You can try Finles 1.5 but we are on the Archtablet forum and using KASTY ROM arent we? Please go to this updated link to download the latest script for those that have used my previous script and see a very bad GPS fix, I think this will correct the mistakes I made in the previous version.The gps.conf file doesnt work that way it will adjust to your location when you shutdown in your new location and will startup by reference to your new location.(that is if you get a sat fix )
http://www.arctablet.com/blog/forum/pipo-tablets/improving-the-gps-fix-on-rk3xxx-devices/#p35207
lew247
158
2014/01/18 - 20:09
Can you include UK to the gps config please?
cracktech
Malaysia
Forum Posts: 432
159
2014/01/18 - 20:39
Heres for UK the updated one.Please use this in conjunction with my script which can be found on other postings.
trel0s
160
2014/01/19 - 12:31
I've installed:
NTPsync
Gps status
Gps test
Faster Gps
I don't wish to install finless 1.5 because of various stability problems.
I have installed faster GPS & NTP sync but I don't see a considerable improvement. See 8 use 4 compared with the Samsung galaxy phone see  10 use 8.... Clearly poor signal
so I will try the crack tech method to see if it works
Faster GPS &
ludoke
Forum Posts: 85
161
2014/01/19 - 12:49
trel0s said
I've installed:
NTPsync
Gps status
Gps test
Faster Gps
Faster GPS &
I don't see stability problems with Finless 1.5,so do it your own way.
ludoke
Forum Posts: 85
162
2014/01/22 - 15:35
People,
I believe this is the solution for the GPS issue,i have tried it en it's working for me
Thanks to manao from Freaktab !!!!
Regarding the GPS, I would like to share a little information.
Chinese dealers test the GPS before shipping your tablet.
If you look in the folder root /data / GPS you will see that there is a gldata.sto file.
This file is created at the first use of your GPS, but as it has been tried before in China, the gldata.sto (glonav data?) Is configured for China...
Just simply remove gldata.sto file and reboot. This file will be created again at the first use of your GPS and will be modified each time you use your GPS.
The gps.conf file is useless with the latest Pipo models.
For the first fix, you must hold the tablet vertically, connectors at right.
Mobius48
Forum Posts: 12
Thanks Received: 4
163
2014/01/22 - 16:35
ludoke said
People,
Forgive my ignorance, but I do not see the folders specified.  I see folder Android / data but no GPS and no gldata.sto file.  Does the tablet need to be rooted first?
ludoke
Forum Posts: 85
164
2014/01/22 - 16:52
Mobius48 said
ludoke said
People,
Yes,it must be rooted ,without root you have no entry to those files you have to root and install root explorer or ES explorer.
And i can tell,it's WORKING after the first fix (takes a while) fix in secs, INDOORS
skippie
Forum Posts: 17
165
2014/01/22 - 17:45
on finless : sees 4 says but none is on use.
What am I doing wrong? Am I close to have it working?
49 Guest(s)
Devices in use: Desktop (45), Phone (4)
thanhgom2006
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
