PiPO M9 PRO GPS performance ?
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
136
2013/12/29 - 15:57
NO OFFENCE taken, just perplexed that you said your device (any RK3188) has got no improvement in GPS fix.
Have you tried using my installation through ADB yet there are many files that need to be added and I am worried if newbies who have no knowledge of Android system installs the files manually they will screw the thing up.
Just for your sake I attached the files that I am talking about not just gps.conf file and afterwards dont use FasterFix (GPS) or any other GPS faster fix app from Playstore.
I dont think you have downloaded this particular files :
The ADB installation scripts and Country reference.
Go to this linkfor downloads : http://www.arctablet.com/blog/forum/pipo-tablets/improving-the-gps-fix-on-rk3xxx-devices/#p35207
nik2670, Mr.BlueSky
nik2670
Forum Posts: 11
137
2013/12/30 - 10:53
gpsconfig.xmlScreenshot_2013-12-30-13-08-48.pngImage EnlargerScreenshot_2013-12-30-13-09-38.pngImage EnlargerScreenshot_2013-12-30-13-12-11.pngImage Enlarger
nik2670
Forum Posts: 11
138
2013/12/30 - 11:08
gps.confScreenshot_2013-12-30-13-40-00-1.pngImage EnlargerScreenshot_2013-12-30-13-38-50-1.pngImage EnlargerScreenshot_2013-12-30-13-39-15-1.pngImage Enlarger
cracktech
Malaysia
Forum Posts: 432
139
2013/12/30 - 23:08
nik2670,
Wow! Is that what you have got after the installlation? Accuracy shoud be less than 35 under a clear blue sky.
I am interested in the signal test app(the one in Russian)  can you zipped me a copy?
nik2670
Forum Posts: 11
140
2013/12/31 - 04:44
1 message-only gpsconfig.xml (spb. at the window)..2 message-gpsconfig.xml+gps.conf(spb.к.у window)Navigator-navitel 8.05.35
nik2670
Forum Posts: 11
prp
142
2014/01/01 - 06:14
Please
GPS-HELP for Thailand
thks
cracktech
Malaysia
Forum Posts: 432
143
2014/01/01 - 07:58
for Thailand please read the instructions in both zip file carefully.
prp
Beto82
144
2014/01/04 - 13:41
Hi, first of all cracktech thx for all your effort to help us.
I have the same problem, have the last Kasty ROM and i use your script to Install GPS fix, but GPS dont work.
I only can see between 1 or 4 sats but anyone on use :(
Any Idea??
cracktech
Malaysia
Forum Posts: 432
145
2014/01/04 - 14:55
Okay lets do a trouble shooting quick check on what is installed.
First go into the ROOT directory, search for system and then go into etc folder.
 1. view/read the gps.conf file , it should read as follows (xx= your country ID)
the permission of the file should be (rw-r-r) and ownership (root:root) check for typo errors.
ENABLE_WIPER=1
DEFAULT_AGPS_ENABLE=TRUE
DEFAULT_SSL_ENABLE=FALSE
INTERMEDIATE_POS=1
ACCURACY_THRES=5000
REPORT_POSITION_USE_SUPL_REFLOC=1
NTP_SERVER=xx.pool.ntp.org
NTP_SERVER_1=0.xx.pool.ntp.org
NTP_SERVER_2=1.xx.pool.ntp.org
NTP_SERVER_3=2.xx.pool.ntp.org
NTP_SERVER_4=asia.pool.ntp.org
NTP_SERVER_5=1.europe.pool.ntp.org
NTP_SERVER_6=2..pool.ntp.org
NTP_SERVER_7=3..pool.ntp.org
XTRA_SERVER=http://xtra1.gpsonextra.net/xtra.bin
XTRA_SERVER_1=http://xtra2.gpsonextra.net/xtra.bin
XTRA_SERVER_2=http://xtra3.gpsonextra.net/xtra.bin
SUPL_HOST=sls1.sirf.com
SUPL_HOST=sls2.sirf.com
SUPL_HOST=supl.google.com
SUPL_HOST=supl.nokia.com
SUPL_PORT=7276
SUPL_TLS_HOST=supl.google.com:7276
SUPL_SECURE_PORT=7275
SUPL_NO_SECURE_PORT=3425
SUPL_TLS_CERT=/etc/security/SuplRootCert
SUPL_TLS_CERT_1=/etc/security/gps.cer
CURRENT_CARRIER=common
2. go into system folder look for int.d folder
there should be "gps-daemon" file permission should be set to (rw-r-r) ownership (root:root) maybe this file permission is not set correctly by my script.
3. go to system folder search for bin folder system/bin
search for  a file  "gpsd" permission should be (rwxr-xr-x) and ownership (root:root)
4. go to system folder search for "lib" folder system/lib folder
search for 2 files "libwiperjni" and libwiperjni_v02" permission should be (rw-r-r) and ownership (root:root)
5. go into system folder search for etc folder then "security" folder
there should be "gps.cer" and "SuplRootCert" permission should be reset to (rw-r-r) and ownership (root:root)
these are the errors I found inside my scripts and dont forget to install NTPSync (go to NTPSync "settings" --->NTP server "choose NTP server" it must be set to the same country code like "xx.pool.ntp.org" inside your gps.conf file.
Apart from that which I did not install through the script are these files that "should" be install inside system/etc/permissions folder (this is optional) the files is attached "add_xml_files" nzipped them and copy the file into the permission folder ALL the files should be set to permission (rw-r-r) and ownership to (root:root)
If you are in the US please tell me and I will provide you with additional files and another version of gps.conf file that has references to T-Mobile certificate. The script shall be undergoing revision version3 as I experiment some more.
If any of the files are missing you can copy them manually into the systems folders from inside the GPS Install folder
 UPDATED Scripts as of Jan 2014 : http://www.arctablet.com/blog/forum/pipo-tablets/improving-the-gps-fix-on-rk3xxx-devices/#p35207
pipotablet
ludoke
Forum Posts: 85
146
2014/01/04 - 18:41
Hi, first of all cracktech thx for all your effort to help us. I have the same problem, have the last Kasty ROM and i use your script to Install GPS fix, but GPS dont work.   I only can see between 1 or 4 sats but anyone on use :(   Any Idea??
Try NTPsync from the Play store ,it will set the correct time four your region which is important.
I'm on Filess 1.5
GPS after 2 min =10 in view and 2 in use   accuracy 39 feet  INDOORS
Great battery life
Beto82
147
2014/01/04 - 22:20
Thx for your fast response, but i Try all your steps with the same result... (all permissions were correct)
3 or 4 sats but anyone in use.
Tomorrow i try in a open field because today i try in a city. And i try to add a screenshot of Gpstest.
cracktech im from spain. I need a different config of gps.conf??
ludoke
Forum Posts: 85
148
2014/01/05 - 10:37
Try Finless 1.5 in combo with NTPsync + FasterGps
cracktech
Malaysia
Forum Posts: 432
149
2014/01/05 - 18:47
DO NOT USE FASTERGPS with the gps.conf file I gave you. I am also having problems with locking ON to satellites right now, just happened about a day or 2 ago.. It is not the script messing up the gps lock . I suspect the SuplRootCert (for Google Cert) has expired the one that is prevalent (many,many) in the various forums are signed by Verisign Inc and was supposed to expire a long time ago. The current Google Cert (SuplRootCert) in now signed by Thawte Inc.
I am looking for the certificate that is signed by Thawte Inc.and will update accordingly.I am in the process of rerwiting the gps.conf and all the other installed drivers.
If you are not happy with the current performance , first you have to delete all the installed drivers except for the gps.conf file (never,ever use FasterGPS with the gps.conf file I gave you all) and then go into root directory search for data folder/ then find gps folder and delete ALL the files you find in the gps folder. leaving an empty gps folder. It will rewrite the files when you reboot and restart any apps that uses gps automatcally.
I am scratching my head bald becoz of the NO GPS fix issue. I will post a new install files when it is done.
ludoke
Forum Posts: 85
150
2014/01/05 - 19:00
I get good GPS results as i stated above and this without the config files.
I'm using Faster GPS and NTPsync .I have Finless 1.5 JB
198 Guest(s)
Devices in use: Desktop (187), Phone (11)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
