Sorry for the late reply bcoz I was busy with my BLOG this week. It seems that you have successfully installed CWM Recovery.
My question
1) Do you understand my English? (becoz English is NOT my first language).
2) I gave you (see the attachments before) "UnzipMe_RecoveryFlasher rev2.zip" for you to use (unzip it and inside you will find inside RASHR/KANNAN/ACR Recovery flasher) try to use KANNAN first , then if cannot try to use RASHR ect, ect.Why did you go and download TWRP Manager???????? It cannot do anything unless TWRP is already installed. Do you understand my instructions or not? I make things easy for you but you made things difficult for yoursef.
3) I made a bloody blunder by not asking you to unzip the "TWRPRecovery.zip", unzip the file and copy the "recovery.img" file inside it to the sdcard. Then run either KANNAN or RASHR to ask them to install the "recovery.img" to replace the existing recovery. You have a choice right now to eikther use CWM (since it is already successfully installed on the tablet or change to TWRP which I recommend for newbies but with more functions.)
4) If you think that this is getting tougher for you to follow , you dont have to do any of this, since CWM is already installed. Just copy the "PiPoGPSupdate.zip" and "BETA_SuperSU2.50.zip (these 2 files please dont unzip!!) and copy to sdcard and select "INSTALL" with the exception of "SuperSU.zip" which is an official copy, I dont know whether "PiPoGPSupdate.zip" is compatible with CWM or not because I made that zip using TWRP) but it should work.
5) By the way the BACKUP made by using CWM cannot work with TWRP and vice versa. I use a 32Gb sdcard on all my Androids so I have plenty of space. If you change to TWRP you will have to redo your backup again.
FINAL : It is your choice not to do any of this TWRP stuff since CWM is successfully installed already and it is already good for BACKUP and RESTORE and to INSTALL SuperSU update and maybe my GPS update.
bigdaddy63About Me LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
2015/12/10
HI DEEZUL.
THANK YOU FOR REPLYING TO ME , I APPRECIEATE YOUR A BUSY MAN ,
THE ANSWER TO YOUR QUESTIONS ARE YES . I UNDERSTAND YOUR ENGLISH ,I SOMTIMES UNDERSTAND YOUR INSTRUCTIONS BUT NOT UNTILL I HAVE LEARNED TO DO THE THINGS YOU INSTRUCT ME TO DO. BUT I DONT FULLY UNDERSTAND THE NAMES OF THE APPS AND THERE ABREVEATIONS YET , BUT I AM LEARNING .
I DLOADED TWRP BECUASE I DIDENT UNDERSTAND AND THOUGHT THIS WAS WHAT I HAD TO DO .. LOOKS LIKE I GUESSED WRONGLY ..
I NEVER SAW THE DLOADS FOR THE UnzipMe_OptionRecovery-FlasherRev2 OR THE BETA_SuperSU2.50.zip BUT I WILL FOLLOW YOUR INSTRUCTIONS WITH THEM .
I WILL INSTALL RASHR AS I CANNOT FIND KANNAN , AND WILL TRY TO INSTALL THE THE RECOVERY .IMG . BY LOADING IT ONTO MY EXTERNAL 32GIG SD CARD AND TELL RASHR TI INSTALL FROM THE SD CARD .
I WILL TRY TO UPDATE THE OTHER GPS AND THE SUPERSU UPDATES AS WELL AND LET YOU NO HOW I GET ON .
MY TABLET HAS BEEN FREEZING UP AND I HAVE HAD TO REEBOOT A FEW TIMES . HOPEFULLY THESE DLOADS WILL SORT THAT OUT ..
DO I HAVE TO INSTALL THE "SuperSU.zip" DIFFERENTLY ?..
THANKS AGAIN DEEZUL . I AM STILL LEARNING , AND HOPE TO LEARN MORE FROM YOU . REGARDS DAVE..
2015/12/10
hi Deezul. recovery succesfull. android upgrading , backup succsesfull.
i used the recovery flasher to install the recovery img , . then used twrp manager to acsses recovery mode again and install updates . super su wanted to update again , it did this in normal mode .
is there an eseyer way to acsess recovery mode . i did it first with the recovery flasher , but i tried to get to the twrp recovery pages again but it just asked for a recovery img again so i came out of that app.
thanks for your advice and instructions . i think iv done it right this time . thanks again Deezul ,, regards Dave ..
If you have successfully installed TWRP or CWM Please "uninstall" RASHR/KANNAN Flasher and keep it somewhere but not installed.(FYI there is CWM Manager app and your mentioned TWRP Manger app please uninstall them and forget about them forever!) Install one of these "Reboot" app like example : https://play.google.com/store/apps/details?id=com.siriusapplications.quickboot on the Tab and whenever you want to access Recovery/Shut OFF or normal Reboot just select from its options and it will never ask you for "recovery.img" file anymore (it will only confuse newbies that is why I dont recommend using TWRP/CWM Manager to get into recovery). But my statement is only true if you have successfully installed TWRP/CWM. Use "Quick Reboot" and uninstall the apps that we use for preparation of "customs recovery". If ever you were to buy a newer tab please try to find for TWRP/CWM Recovery not "PhilzRecovery" because the original "philz" developer has declared he is supporting TWRP and not his namesake.Good luck to you!
2015/12/10
Hi Deezul,
Thank you for all your help and instructions , if it wasent for you i would have a bricked tablet by now . i uninstalled the apps for custom recovery and will use the reboot app that you suggest .
i like your attachment pic "LOL !!"i no you must have felt like this at times with me . but you must no that you was very much appreciated . live long and have a happy life. regards , Dave.
84 Guest(s)
Devices in use: Desktop (75), Phone (9)
cutierogue
hans41
rickybk
