[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (2013/08/22)
leeomendes
Forum Posts: 12
2013/09/03 - 17:35
jpg001 said
i have the answer :
you need to edit build.prop (/system/build.prop) and add :
fw.max_users=3
3 or 2, 3 , 4 ect...
save and reboot
PERFECT! Thank you very much man!
tito2k
Forum Posts: 18
Thanks Received: 4
2013/09/04 - 12:38
It doesn't work in my tablet. I can see in settings the options to add new users, but when I reboot, It is frozen in a black screen saying that "com.android.provision.defaultactivity" proces doesn't work.
More people have the same problem -> http://www.flashmyandroid.com/forum/showthread.php?4424-4-2-2-Multipe-users-Won-t-work
seecp70
2013/09/04 - 15:25
Hi all
Just got my Pipo M9pro Wifi,
The build number is dated 08082013
i run the rKtools  ver 1.7
connect the Pipo(turn on)  to the computer, it shows as pink, i click the switch button and it turns to green, can i update this way or i need to press the ESC and POwer button as in the manual?
Thanks Received: 3171
2013/09/04 - 15:27
If the Square turns green, you are good to flash the firmware, just press Restore button and let Rockchip Batch Tool flash your tablet.
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2013/09/04 - 20:17
Does this change the boot up screen? and bootanimation of the stock ROM. I like the "PiPo" startup screen, I have heard of other horrible startup screens complains by other users (cant recall whether it is on this forum or another.)
I like to support this ROM coz it has 4Gb data space and comes pre rooted. i hav ethe version with product name #270 dated Fri Aug 9
 BUold number : rk30sdk-eng 4.2.2 JDQ39 eng.root.20130808.43740 test.keys.
The only worries I have is if it changes the startup and bootanimation screen (mine is a non 3G multiwindow version).
2013/09/04 - 20:24
Like most of our firmwares, we have our own logo picture displayed at boot, it shows for a second or so, it's a rather simple not aggressive design that most users should be able to live with. We do that to watermark our firmwares as they were found to be redistributed by retailers or under different names.
Judging on your build number version, our custom firmware in post #1 should be more recent.
cracktech
Malaysia
Forum Posts: 432
2013/09/04 - 21:30
Thanks for the quick reply, I will replace the boot up animation with the original PiPo boot up animation lleaving the startup/power up screen from yours (anyway I dont know how to do it, except the bootup animation screen only.)
If satisfied a donation is on the way.
leeomendes
Forum Posts: 12
2013/09/04 - 21:49
could you please upload the original bootanimation.zip for me please? you need to go to /system/media and it will be there :)
2013/09/04 - 22:36
I did not specify it, but it may need to be clarified, our custom firmware only has the boot logo changed, the boot animation is stock, so you'll have the default one PiPO has installed.
Paul2482
2013/09/05 - 13:29
Great rom update, but how can i get the PIPO desktop back ( Pipo Launcher)
Paul
beppedomani
Forum Posts: 20
2013/09/06 - 00:17
Dear Kasty,
if i want put Pipo launcher or Kid launcher(pipo) what files i have to transfer from firmware stock rom (i have unpack it all) to your rom?
With root browser I have tried to put in:
/system/app
the files
- LauncherManager_pipo_family.nm
- Launcher2.apk
- KidLauncher_pipo_family.nm
reboot
...nothing...
please excuse my beginner android dev level
Many thanks
2013/09/06 - 00:19
beppedomani,
That should work. Have you checked the files have been copied successfully and they are still there after the reboot ?
Since adding back PiPO launchers is a frequent request, I'll leave them with the next builds of our custom firmwares or make an easy way to add them back.
beppedomani
beppedomani
Forum Posts: 20
2013/09/06 - 00:50
The files are in /system/app
then on tablet i tap >setting >App  scroll to ALL, search basic launcher and unchek "default"
reboot
after bootanimations PiPO ask what kind of launcher I want to run  Basic or Retina Launcher.
But not happen tap Retina Launcher...
Only basic launcher run.....
maybe there are some .bin files somewhere to transer too?
cracktech
Malaysia
Forum Posts: 432
2013/09/06 - 01:03
Apart from the **.nm files i the system folders (with correct permissions) you need to install the .apk files as well I am sure it is install as a normal apk but as a pair with the apk files in the system folders , becomes a system files. unless after you have installed the *.nm files in the system folder and try to install the apk files as a normal app as was the factory ROm you could give it a try. I am quite sure that without the *.nm files in the system folders the *.apk files will install successfully (failed to install)
I have attached my backed up files for you.
beppedomani
leeomendes
Forum Posts: 12
2013/09/06 - 01:26
reboot
Only basic launcher run........
try to change the permissions to rw-r--r--
57 Guest(s)
Devices in use: Desktop (55), Phone (2)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
