2013/11/23
Pipo M9 PRO Brick hard solution
if your tablet will not boot:
1 the maximun load (red light extinguished)
2 AC disconnects
3 usb plugs into the tablet and pc
4 plug the AC adapter into the tablet
5 Pressing the reset 1 second and relaxes
5 remains pressing reset / esc / power 4 to 5 seconds and then relaxes all
6 waits between 20 seconds and 1 minute and tablet to start in download mode.
repeat the procedure several times if it does not. normally this procedure works, and also for the lock to return to android 4.4 4.2 etc ..
j veiled hope this will help.
Whenever there is a hardbrick situation that means a "critical error" has happened in the firmware on your device. The method described here is correct but I would like to add that Press "Reset + Esc + Power" will not solved your hardbricked problem. In most cases press "Reset +Esc +Power" is to enable the device to be RECOGNISED by PC for you to start REFLASH the firmware.
That is my advise if you faced "hardbrick" you SHOULD reflash back the firmware to like formatting your device and getting rid of any corrupt NAND memory address. (you will most likely have to "Reset+Esc+Power" to be able to reflash) since if you really hardbrick the PC will not recognised the device and there is no way for you enable/disable ADB.
Even if the device seems to work it might/will hardbrick again if not reflashed.
70 Guest(s)
Devices in use: Desktop (64), Phone (6)
