[ ROM ] Pipo M9 pro (3G model) custom root Android 4.2.2 firmware (2013/08/22)
Thanks Received: 3177
2013/08/26 - 20:15
Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M9 PRO (aka Max-M9pro) new tablet hardware that is equipped with a GPS. This firmware is designed for the model with the 3G module, it is based on latest official update dated 2013/08/22.
(update_M9 pro_3G_20130822.img)
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #279 SMP PREEMPT Thu Aug 22 10:36:00 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20130822.110054:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU version 1.51 (free version)
  • removed most Chinese and unnecessary applications, removed Certificate Center asking for product key
Download: kasty-pipo-m9_pro_3G-422-20130822-rooted4.zip
mguau, FeyoMx, leeomendes, DreamCast, pepito33, wheelman, Loetz, frank10, ppc256
FeyoMx
2013/08/27 - 06:31
hello, congratulations for the excellent work, I wanted to ask how xpad.ko module is loaded, at the terminal since I get the error (exec formar error) thanks in advance.
2013/08/27 - 10:42
The modules are normally build for Kernel 3.0.36+ so they should load properly on this firmware.
If you have an adb connection or a terminal running can you please post the output of dmesg after running the insmod command ?
FeyoMx
FeyoMx
2013/08/27 - 14:42
Sorry
2013/08/27 - 14:51
I've editing your post so it doesn't display long pages for debug info.
Actually it's not complete and I just need the last line that will appear after the insmod.
So you just need to do the insmod, then dmesg, then copy here the last line from this log.
leeomendes
Forum Posts: 12
2013/08/27 - 23:03
I've just created a account to thank you for the ROM! keep it up man, nice work!!
Terryfried
2013/08/30 - 14:53
could anybody tell me if this rom is compatible with multi-windows. as per
http://blog.geekbuying.com/index.php/2013/08/07/the-multi-window-system-of-android-4-2-2-comes-to-tablets-pipo-m9prom9pro-3g/#.UiCTPDashcZ
is there another site for rockchip mult-iwindow software ?
tripp
2013/08/30 - 16:27
can somebody send me build.prop file from this firmware?
please
rifkin
2013/08/30 - 21:48
Thank you so much for your hard work. I would like to know if exists the possibility of install the pipo launcher in this rom. Thanks again for all.
tripp
2013/08/31 - 08:07
It's good rom, but there is only one bug. Tablet goes not to the deep sleep, when 3g modem is switched on. I think, there is something to do with ril-rk29-dataonly wakelock, which don`t let the tablet go to the deep sleep. Is there something to do with this?
tharsa57
2013/09/02 - 17:01
Hello, was trying to root the Pipo M9 Pro 3G and managed to brick it! When I connect the device to the PC it shows that RockusbDriver is successfully installed however after pressing the reset and Esc together the device indicator does not change color to Green. Pressing Restore the message "The operation ... no Device" appears. Any ideas? Thanks, Theo
venso
Азербайджан
2013/09/03 - 12:59
Thank you very much!
A great custom!
4GB plus removed all excess out of the system!
SUPER!
I take off my hat to you.
Thank you again!
Good luck to you!
bonicole
2013/09/03 - 23:03
Great job on this one. Hats off, sir!
One thing though, it seems like the Bluetooth is not working. When I tried to turn it on, it didn't work.
Help is appreciated. Wink
leeomendes
Forum Posts: 12
2013/09/04 - 02:18
Hi. To fix your problem:
>> Go into Settings > Apps,
>> Scroll left until you get into "All apps",
>> Find bluetooth app and click on it,
>> Click on "clear data" and after "force close" and "ok".
Done, your bluetooth is now working :) If it helped you, please click "Thanks" on my post.
The following users say thank you to leeomendes for this useful post:
marek.w
trontxo
2013/09/04 - 21:54
Hi
I installed this version and really goes well in comparison with the original one, but i have a big problem, 3g is not working anymore. I insert my simcard reboot the system and when i enter my pincode it doesn´t accept it i tried three simcards and the same.
Do you know what happen?
Thanks for the great job done
164 Guest(s)
Devices in use: Desktop (160), Phone (3), Tablet (1)
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
hoholms
rammaiden
