2013/08/01
Last year about September I bought Pipo M9 Pro 3g. 3 months ago I upgraded the OS from 4.2.2 to 4.4.2 till now. For the last 1 month I have noticed that the battery is drained somehow and the tablet does not last more that 1 hour open. I have down a battery stats app and I will show you the ScreenShot. What Can I do  to fix the battery issue. I wish you can understand something from the pics bellow! Thanks in advance for your help!Â
It is a good practice that after each new ROM flash to recalibrate your battery. Your 1 hour battery drain sounds like the battery was not calibrated properly and is not normal for M9Pro . If your customs recovery has option to wipe battery stas please do that, if not please use 3rd party apps such as : https://play.google.com/store/apps/details?id=com.nema.batterycalibration
About Me  LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
2014/07/01
Nimn said
Thank you for your fast reply, I did what you said but I still have the same problem! I have downgrade to 4.2.2 following the instruction on another post and I will check if I will still have the same problem!
Have you been able to arrest battery drain after downgrading to 4.2.2?
84 Guest(s)
Devices in use: Desktop (61), Phone (23)
Riki111
andre92
firmwarefile
mongol
country822
vovandolgan
