2013/07/02
Sorry, could you be more specific - what type of app? Presently the file is read only...here is the content:
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=JDQ39
ro.build.display.id=DS1006-eng 4.2.2 JDQ39 eng.ljh.20130506.105106 test-keys
ro.build.version.incremental=eng.ljh.20130426.105106
ro.build.version.sdk=17
ro.build.version.codename=REL
ro.build.version.release=4.2.2
ro.build.date=2013�?04�?26�?星期�?10:51:47 CST
ro.build.date.utc=1366944707
ro.build.type=eng
ro.build.user=ljh
ro.build.host=mid-Porsche
ro.build.tags=test-keys
ro.product.model=M9
ro.product.brand=PIPO
ro.product.name=rk30sdk
ro.product.device=rk30sdk
ro.product.board=rk30sdk
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=rockchip
ro.product.locale.language=en
ro.product.locale.region=GB
ro.wifi.channels=
ro.board.platform=rk30xx
# ro.build.product is obsolete; use ro.product.device
ro.build.product=rk30sdk
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=rk30sdk-eng 4.2.2 JDQ39 eng.ljh.20130426.105106 test-keys
ro.build.fingerprint=rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.ljh.20130426.105106:eng/opinions-on-teclast-p90hdst-keys
ro.build.characteristics=tablet
# end build properties
# system.prop
#rild.libpath=/system/lib/libreference-ril.so
#rild.libargs=-d /dev/ttyUSB2
# Default ecclist
ro.ril.ecclist=112,911
# ADDITIONAL_BUILD_PROPERTIES
ro.com.android.dateformat=MM-dd-yyyy
ro.rk.systembar.voiceicon=true
ro.config.ringtone=Ring_Synth_04.ogg
ro.config.notification_sound=pixiedust.ogg
ro.carrier=unknown
ro.config.alarm_alert=Alarm_Classic.ogg
dalvik.vm.heapstartsize=8m
dalvik.vm.heapgrowthlimit=64m
dalvik.vm.heapsize=384m
dalvik.vm.heaptargetutilization=0.75
dalvik.vm.heapminfree=512k
dalvik.vm.heapmaxfree=8m
ro.config.facelock=enable_facelock
persist.facelock.detect_cutoff=5000
persist.facelock.recog_cutoff=5000
ro.sf.lcdc_composer=0
keyguard.no_require_sim=true
ro.com.android.dataroaming=true
ril.function.dataonly=0
persist.sys.strictmode.visual=false
dalvik.vm.jniopts=warnonly
sys.hwc.compose_policy=6
sf.power.control=2073600
sys.rkadb.root=0
ro.sf.fakerotation=true
ro.sf.hwrotation=270
ro.rk.MassStorage=false
ro.rk.systembar.voiceicon=false
wifi.interface=wlan0
ro.tether.denied=false
ro.sf.lcd_density=160
ro.rk.screenoff_time=120000
ro.rk.def_brightness=128
ro.rk.homepage_base=http://www.google.com/webhp?client={CID}&source=android-home
ro.rk.install_non_market_apps=true
ro.default.size=100
persist.sys.timezone=Europe/London
ro.product.usbfactory=PIPO
wifi.supplicant_scan_interval=180
ro.opengles.version=131072
ro.factory.tool=0
ro.kernel.android.checkjni=0
ro.rk.bt_enable=true
ro.rk.btchip=mt6622
ro.factory.storage_policy=0
persist.sys.usb.config=mass_storage
testing.mediascanner.skiplist=/mnt/sdcard/Android/
ro.product.version=1.0.0
ro.product.ota.host=www.rockchip.com:2300
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
# Hejira Additions
# Multi user selection 4.2
fw.max_users=5
globula_neagra said
Use an application from Google Market or, extract the build.prop to your pc, use a text editor like TextPad, save what you want, re-push the file to the tablet, setting the appropriate permissions.
On a rooted firmware the file is rewritable (that`s why you root the tablet, to have access to the system partition)
Apps like ROM Toolbox Pro or Build Prop Editor can be used to modify the build.prop
YOU WILL NOT BE ABLE TO MODIFY THE BUILD.PROP IF YOU DON~T USE A ROOTED FIRMWARE
Another firmware update has been posted:
http://www.arctablet.com/blog/forum/pipo-max-m9/pipo-m9-custom-root-android-4-2-2-firmware-20130814/
70 Guest(s)
Devices in use: Desktop (64), Phone (6)
